Author Topic: New Der EE LCR+DMM  (Read 17418 times)
Offline PedroDaGr8
  • A sociable geek chemist
New Der EE LCR+DMM
« on: March 13, 2015, 07:50:11 pm »
Der EE just released a new meter DE,-5003/5004. It's a solid mid range DMM with decent safety specs but also has a built in real LCR (selectable frequencies up to 10kHz, can read ESR, phase angle, 0.5V test voltage, etc). Neither part are ground breaking specs wise but it's nice to see an all-in-one that isn't entirely a freaking toy. The LCR specs should be good enough for most hobbyists, not for pros though. I wonder what you guys think about it.
 http://www.deree.com.tw/prod141001162828.htm
My biggest wonder will be price. Will it be cheaper than buying a solid meter and a DE-5000(which as we all know is damn good) separately.
« Last Edit: March 13, 2015, 07:53:50 pm by PedroDaGr8 »
The very existence of flamethrowers proves that some time, somewhere, someone said to themselves, "You know, I want to set those people over there on fire, but I'm just not close enough to get the job done." -George Carlin
Offline DAIRVINE
Re: New Der EE LCR+DMM
« Reply #1 on: March 13, 2015, 07:56:26 pm »
If this is really cat 111 to 600V for LCR that is really good. It would be helpful to have an LCR that could withstand accidents with charged capacitors.
Offline PedroDaGr8
« Reply #2 on: March 13, 2015, 07:58:53 pm »
Just saw on another forum, the slated price is $150 or less. Which actually seems like a smart price point based on the features and specs. It's about a $120 meter with about a $50 LCR. So together it's pretty reasonable. A good price point I think for hobbyists with a bit of savings.
Online TimFox
« Reply #3 on: March 13, 2015, 08:08:40 pm »
Who distributes these units?  The DER website does not have prices.
Offline Lightages
  • Canadian po
« Reply #4 on: March 13, 2015, 08:35:01 pm »
If it sells for less than $120, then it will quickly become the most recommended meter for those looking for something close to $100 as their first meter for electronics.
Offline wiss
« Reply #5 on: March 13, 2015, 08:53:52 pm »
Hummm, I want one! :)
Offline jimon
« Reply #6 on: March 13, 2015, 09:36:38 pm »
Just got DE-5000 a week ago, go figure :palm:
Offline PedroDaGr8
« Reply #7 on: March 13, 2015, 09:42:16 pm »
Relax, the DE-5000 is a much better LCR. This one though is a capable one for hobbyists, just not nearly as nice as the DE-5000.
Offline Wytnucls
« Reply #8 on: March 14, 2015, 01:02:07 am »
It's not that new. It has been on my spreadsheet list for quite a while.
Supposedly 6,000 count, but it shows 5 digits on the display (4 1/2 really).
« Last Edit: March 14, 2015, 01:37:45 am by Wytnucls »
Offline dadler
« Reply #9 on: March 15, 2015, 10:06:08 pm »
DE-5000 goes to 100kHz
Offline pcbroute
  • Country: ru
« Reply #10 on: October 20, 2016, 07:01:11 pm »
Hi all. Got DE-5004 a few months ago...
i think is really good.
some photos.
The following users thanked this post: chickenHeadKnob
Offline pcbroute
  • Country: ru
« Reply #11 on: October 20, 2016, 07:04:06 pm »
with another LCR...
Offline Lightages
  • Canadian po
« Reply #12 on: October 20, 2016, 09:27:17 pm »
Thanks for the images. This looks like a well built and it might actually meet its CAT ratings. Like I said before, this looks like the perfect meter for electronics.
Offline omgfire
  • Country: ru
« Reply #13 on: October 21, 2016, 06:03:30 am »
ES51930?
pcbroute, do you think you could shoot other pcb side, switch and instruction manual?
Offline WackyGerman
« Reply #14 on: October 21, 2016, 07:35:54 am »
On the first glance it really looks nice and tidy . But I don t like the design at all . Why did they put the 10 A at the middle right and the small one at the bottom and not the other way round ??? So the COM trace on the board for the 10 A range is very long and the shunt is straight over the control circuits of the multimeter . Then I don t like the cheap trimmer pots on the board . It seems that they trimmed the multimeter into the specifications . The fuses are the right choice so  :-+ for the fuses . The design is not that good so  :-- :-- for the design . the idea to combine a multimeter with a lcr meter is a good idea  :-+ . But unfortunaltely this meter is too much built down to the price
Offline omgfire
  • Country: ru
« Reply #15 on: October 21, 2016, 08:54:16 am »
It seems that they trimmed the multimeter into the specifications . But unfortunaltely this meter is too much built down to the price
Gossen MetraHit 30M has trimmers. Is it also "too much built down to the price"?
« Last Edit: October 21, 2016, 08:59:58 am by omgfire »
Offline pcbroute
  • Country: ru
« Reply #16 on: October 24, 2016, 09:50:47 am »
ES51930?
ES51930 looks very similar.
Sorry, i don't shoot other side, may be a later if i broken it)
Here is a user manual, i scan it and make PDF file.
DEREE-DE5004.pdf
The following users thanked this post: kripton2035, omgfire
Offline kripton2035
« Reply #17 on: October 24, 2016, 11:48:36 am »
thinking of buying one sooner or later... already have a deree de5000 but this small meter is cute...
Offline omgfire
  • Country: ru
« Reply #18 on: October 24, 2016, 12:21:18 pm »
Peakmeter PM8246 looks inferior, but with same concept. I wonder how much cheaper it would be.
Offline kripton2035
« Reply #19 on: October 24, 2016, 01:11:15 pm »
the input of the de5004 seems protected to 600v ?
on the pcb there are some big resistors, fuses, mov and the input is the same for volt and lcr.
on the peak8246 on the contrary there is a separate input for the lcr, there is not far to say that this input is not protected at all ...???
Offline kripton2035
« Reply #20 on: November 15, 2016, 07:46:02 pm »
just received a deree de5004 today, first impression is : really not as good as the deree de 5000 !!!!
can be used as an esr meter, will have to check that better but it seems ok for that use.
definitely not an lcr meter.
Offline rjardina
« Reply #21 on: January 05, 2017, 11:26:30 pm »
ES51930?
DEREE-DE5004.pdf
Offline rjardina
« Reply #22 on: January 05, 2017, 11:45:37 pm »
I'm probably one of the last people that needs to review this meter, due to my lack of knowledge of using a LCR meter or even really knowing how to use one. That is why I bought this one and the 5000 to learn some more. The Auto on the LCR frequency part is very erratic and never get the same results.
Offline 1937
  • Country: ru
« Reply #23 on: March 02, 2017, 05:47:47 pm »
For those guys who are interested what is under the display. There is TI MSP430F4371. The same bracket as in some LCR tweezers like AKIP-6107.
Has anyone tried to activate an IR optical link with the PC? The 75 leg of MSP430F4371 gives no signs of life. :horse:
Not found a complete datasheet with schematic for ES51930.
May be someone knows, what is purpose of the missing components on DE-5004 board? :-/O
Think that the resistors RC13, RC14 and op. amp. U3 are responsible for contactless electric field measurement.
It would be cool if DER EE implemented all functions.
« Last Edit: March 03, 2017, 12:58:55 pm by 1937 »
Offline shteii01
« Reply #24 on: March 03, 2017, 01:52:20 am »
If I recall correctly, DMM version does not do pF.  That is why I got DE-5000 LCR Meter.
