Products => Test Equipment => Topic started by: tunk on August 20, 2023, 09:55:26 pm
Does it never stop?
Another handheld DSO+DMM+SG, Mustool MDS9208:
- 12MHz, 50MSps
- 50mV-20V/div
- 200ns-10s/div
- no BNC-connector
- 6000 count DMM
- DMM rotary switch
- 2.4" screen
- signal generator
From Banggood at $64:
https://m.banggood.com/2023NEW-MUSTOOL-MDS9208-3In1-Oscilloscope-Multimeter-Signal-Generator-12MHz-50Msps-Portable-High-Storage-Capacity-Low-Power-Consumption-p-1995183.html
Does it never stop?
Apparently not.
- 50mV-20V/div
Useless for much scope work.
The purpose of this type of device is not entirely clear to me.
It is neither a particularly accurate multimeter nor a "real" oscilloscope (it doesn't even have a BNC connector or anything like that).
Mustek has many similar models with very similar specifications.
I don't even think they're "bang for the buck".
If you want such an all in one device, I would spend $30 more for a Dso3d12 (https://de.aliexpress.com/item/1005005920059835.html) which offers much more in every way (And unlike other brands, two oscilloscope probes are included btw).
However, I prefer separate gear. In the entry level segment, a AN870 plus a DSO2512G, for example, is a good value, in my opinion.
Looks like it's also sold as GVDA GD188:
https://youtu.be/watch?v=eJGYTWS5Zuc (https://youtu.be/watch?v=eJGYTWS5Zuc)
https://www.gvda-instrument.com/electronic-instruments/digital-multimeter/3-in-1-digital-oscilloscope-multimeter-signal.html (https://www.gvda-instrument.com/electronic-instruments/digital-multimeter/3-in-1-digital-oscilloscope-multimeter-signal.html)
