Author Topic: New EEVblog BM786 Multimeter  (Read 69611 times)
Offline Andrew McNamara
Re: New EEVblog BM786 Multimeter
« Reply #250 on: January 17, 2021, 11:21:05 pm »
Dave - the soft case seems to have disappeared from the store - are we going to see that return (particularly one suited to the larger BM786)?
Offline EEVblog
« Reply #251 on: January 18, 2021, 09:20:55 pm »
Are the calibration procedures documented for this meter?
No they aren't.
They usually only release this to trusted major dealers.
Offline EEVblog
« Reply #252 on: January 18, 2021, 09:21:44 pm »
I don't particually want to carry multiple cases, so I might look into if it's possible to get one that suits all meters.
Offline EEVblog
« Reply #253 on: January 20, 2021, 12:38:35 am »
If you are wondering why your new BM786 multimeter didn't come with batteries, it's because DHL Express took it upon themselves to open every package and remove them & send them back. Alkaline batteries. Freak'n ALKALINE BATTERIES.
The following users thanked this post: tom66, HerbTarlek, rernexy, hmscott
Offline Kean
    • Kean Electronics
« Reply #254 on: January 20, 2021, 12:39:50 am »
WOW!  |O
Offline tautech
« Reply #255 on: January 20, 2021, 12:40:37 am »
Muppets !  :palm:
Avid Rabid Hobbyist
Online 2N3055
  • Country: hr
« Reply #256 on: January 20, 2021, 12:42:49 am »
 |O :palm:
Offline Ed.Kloonk
« Reply #257 on: January 20, 2021, 12:44:48 am »
-sigh-
Online wolfy007
« Reply #258 on: January 20, 2021, 01:19:18 am »
Did they say why they removed alkaline batteries??? Or did the guy at the Xray machine just figure they should have them removed after spotting batteries...
Offline ve7xen
    • VE7XEN Blog
« Reply #259 on: January 20, 2021, 01:42:43 am »
DHL's policy appears to prohibit the international shipping of Alkaline batteries, in all cases. The document is US-based, but presumably the International provisions apply network-wide. See page 7.
https://www.dhl.com/content/dam/dhl/local/us/dhl-ecommerce/documents/pdf/us-ecommerce-battery-shipping-policy.pdf
73 de VE7XEN
He/Him
The following users thanked this post: Kean, wolfy007
Online Kleinstein
« Reply #260 on: January 20, 2021, 09:21:24 am »
For international shipping it makes sense to not include standard batteries. They only add to the weight and there is a small risk of the batteries to cause trouble: An unintentional short in a smashed parcel may start a fire - not very likely but alkaline cells often have quite some power. The other problem is leakage  :horse: - reduced air pressure in an aircraft can accelerate this.
Another point about not having batteries is that it makes it easier to spot a possible bomb from xray pictures.
There is no real need to have standard AA batteries shipped with the DMM. These are better bought locally in most places.
Offline Brumby
« Reply #261 on: January 20, 2021, 10:52:37 am »
So Dave - what are you going to do with a few kilos of alkaline batteries?
Online BU508A
« Reply #262 on: January 20, 2021, 12:01:31 pm »
Leaking tests ...
Offline schwaggins
« Reply #263 on: January 20, 2021, 03:51:44 pm »
At least they didn't reject the entire package i suppose. I received batteries with mine locally though
Offline NoisyBoy
« Reply #264 on: January 20, 2021, 08:09:09 pm »
Saw it is back in stock, placed order for one.
Offline EEVblog
« Reply #265 on: January 21, 2021, 12:46:11 am »
Looks like I'll have to rmeove the batteries for all international DHL shipments. Local will still have them.
Offline symp
« Reply #266 on: January 21, 2021, 09:27:45 am »
Thanks for the decent energizers Dave, I shouldn't have to change them for a year or more if its as good on batteries as the 235
Offline ian.ameline
« Reply #267 on: January 21, 2021, 04:52:05 pm »
The link to the manual here https://www.eevblog.com/files/BM789-Manual-Original-Final.pdf is broken...
Offline drussell
  • Hardcore Geek
Offline ian.ameline
« Reply #269 on: January 21, 2021, 08:08:12 pm »
Woo Hoo -- just arrived! (3 days to travel to the other side of the globe) It's a thing of beauty. Calibration out of the box is pretty damn good. Here is a recently calibrated 34401 (by Keysight at the end of November 2020) (warmed up for an hour along with the source. showing 5.00000V from a DMMCheck+. The EEVBlog Brymen is 1 count high. (it's been on for 30 minutes. It was 5 counts high for the first minute, then quickly settled at 5.0001V, and it hasn't budged since then.
Offline ian.ameline
« Reply #270 on: January 21, 2021, 08:34:03 pm »
on DC milli-amps (@1.0mA), it is 2 counts higher than my 34401 . Resistance, 600ohm range (100ohms) it's 3 counts higher, and the 6k, 60k and 600k ranges (using 1K, 10K, and 100K resistors), the EEVBlog meter is within 1 count of the calibrated 34401.
For AC volts (5V AC, square wave @ 100hz), it is 24 counts lower than my 34401.
Pretty much spot on -- I don't think it could be any closer.
I'm very happy with my purchase.
Offline ian.ameline
« Reply #271 on: January 21, 2021, 08:42:08 pm »
The batteries were in the package (3 energizer aaa in a small ziplock bag) but not installed in the meter -- so I guess DHL didn't remove all of them...
Offline hopski
« Reply #272 on: January 21, 2021, 08:57:38 pm »
Mine came with batteries too. maybe the battery checker was on his break
Offline ian.ameline
« Reply #273 on: January 21, 2021, 09:13:51 pm »
This soothes my OCD :-) (dialed in a random number :-) )
The following users thanked this post: EEVblog, Kean
Offline ian.ameline
« Reply #274 on: January 21, 2021, 09:38:27 pm »
One very minor error in the manual -- on page 16, where it depicts a north-american style outlet -- it has the neutral and live sides reversed. If the ground min is on the botom, the live side is on the right (and is slightly shorter than the neutral that is to the left). In that diagram on that page, the manual shows the live side is on the left.
