Author Topic: New EEVblog BM786 Multimeter  (Read 147598 times)
Offline Kleinstein
Re: New EEVblog BM786 Multimeter
« Reply #650 on: March 10, 2023, 06:04:38 pm »
In most case NiMH should work with a nominal voltage under low load of 1.25 V. This should be just enough to stay above the low bat level. The actual level may vary and some meters may woork OK while others don't.  It still depends on the use. Rechargible mainly make sense for really heavy use with plenty of backlight (should be some 10-25 hours of battery life with backlight). Otherwise the Lithium cell are the better choice. With heavy use, so that the batteries don't get old (e.g. < 6 months) even the normal alkaines could be OK.
Offline FIRage
« Reply #651 on: April 24, 2024, 05:02:53 pm »
Just received firmware version 78611, MFR# 2411*****. I had no idea there have been so many firmware releases. Wonder what’s new in recent versions.
Offline EEVblogTopic starter
« Reply #652 on: April 24, 2024, 10:10:05 pm »
I'll ask them.
