At the risk of being censored, we did discuss problems with the switch. I wonder with it now being intermittent if they did not reduce the spring pressure.
Joe, I am not censoring anyone. I didn't want people constantly discussing stuff in the thread that is only for reporting and confirming issues.
Having an "issues" thread that's a 30 page long discussion kinda make it hard to find the issues for all involved...
I hope you can understand that.
And yes we improved the switch wear issue after you reported it, but the pre-production units that came after that were fine, and we have never had this "wobble" or intermittent contact issue. Not even the first "wobbly" prototype back in April 2016 had intermittent contacts. This seems to be a new issue.
I assume you pulled my post when you bold texted me. Maybe you have a different definition of censorship. Really no matter. I certainly understand that it is your site and you are free to do as you wish with it.
On the switch, I just wanted to be clear that your comment
"We have had no problems with the range switch since then.
was not entirely true. I will say that I never saw the wobble on the prototype. If people watch the video where I had repaired it, I ran it outside the case. The rotating spring contact holder what held in place by its locking barbs where it fits through the board. Even then I don't think it was intermittent. This is why I wonder if they had loosened the tension maybe to help reduce the wear. If so, maybe they went too far with it. Hard to say but it would be easy enough to compare them at some point. With you unboxing a fair number of them to test, I would think if there was a major problem you would have come across it.
Also, just an FYI, with as many meters as I have looked at, I have ran into problem with switches not working right from the factory. One was a CEM. I showed some pictures of it where one of the wiper contacts was lower than all the rest. The plastic that it fits over was a bit wider for some reason spreading out the spring causing it to ride a little low. A razor blade solved that one. People seem to expect a lower level of quality from CEM. They are a bit of a hit an miss company from what I see and it explains why they get a bad reputation.
