Author Topic: New MicSig/EEVblog DP10007 HV Differential Probe  (Read 58693 times)
Offline ceut
Re: New MicSig/EEVblog DP10007 HV Differential Probe
« Reply #175 on: June 14, 2024, 04:34:43 pm »
I have finished my own package with some accessories , and cut some of the foam inside the box to fit them  :)
Again, here are photos, if my ideas would be usefull for some of you  :-+
Offline TomKatt
« Reply #176 on: July 12, 2024, 06:27:56 pm »
Hello,
Sorry to dig up this topic, I have posted into it in 2022, then I have gave up the idea to buy this DP10007 (and other diff. probes).
For 2024: again I'm looking forward to buying a Differential probe, and I don't know if they have fixed the CMRR problem since ?
Maybe someone has bought a new one recently ?
I saw that a new model has come up (MDP700) but I don't like the big BNC part, to use on a portable DSO.
The output cable are really short.
And also, I think the "UI" is not as good as the DP series (leds seem to be very small to see them, and the button seem not to be as great).
So, thanks for any information/advice someone can give me (even on other brands)  :-+
Micsig just sent me an MDP series probe. Haven't tried it yet. I think they just gave up on the DP series.
I'm a little confused - the Micsig website identifies the DP series as the 'new' products, and has the MDP series listed under their 'History (old)' product section...  But the 'new' DP series looks nothing like DP1007 probe I have - the new ones look like the MDP series.
I hate it when vendors swap products around but leave the model number the same.
Several Species of Small Furry Animals Gathered Together in a Cave and Grooving with a PICt
Offline TomKatt
« Reply #177 on: July 15, 2024, 03:06:57 pm »
I also just noticed that the new MDP series output signal is 1/2 of the prior DP series (7V -> 3V), which equates to the DP10007 10X/100X probe now equivalent to the MDP701 20X/200X probe - both have 70V / 700V ranges.  The change in attenuation from 100X to 200X for the same voltage rating is a bit confusing to me.  I would have originally guessed that a larger output signal would provide better S/N measurements - ie 0-3V (seems like it should be 3.5V ?) now represents 0-700V at the 200X setting.  That means that every 1V at the scope equates to 200V measured...
I'd really be interested in a review video on these new models - especially how they compare to the old models and also how they compare to the Sapphire probe.
« Last Edit: July 15, 2024, 03:08:48 pm by TomKatt »
Offline EEVblogTopic starter
« Reply #178 on: July 16, 2024, 04:19:02 am »
FYI, the DP10007 with x10/x100 was made at my request to match the specs of the Sapphire HVP70 I sell. Seems they did't bother doing that again for the new MDP range.
Offline TomKatt
« Reply #179 on: July 16, 2024, 08:06:04 pm »
I recall you mentioning they produced the original at your request...  Odd that they apparently decided to continue offering a model with the 70V/700V ranges but changed the output scale from 10X/100X to 20X/200X by cutting the output signal in half.  Either they had trouble meeting your original specs or perhaps they standardized on their new amplifier platform that seems to be an offshoot of their "SigOFIT" isolated fiber optic probes  - I note all their other models for higher voltage ranges also output a ~3V signal (I still think 3.5V must be the actual output level).   Given the lower output headroom, I wonder if this is an area where new 12bit scopes might provide some advantage?
Offline AndreyS
« Reply #180 on: August 22, 2024, 01:57:31 pm »
What is it about new types of DP10007 appearing on amazon ? while micsig claims dp10007 are discontinued ? What the..?
New ones differs from old ones by crocodile clips by the looks of it.
I've got dp10013 version and it didn't had those regular multimeter probes.
« Last Edit: August 22, 2024, 02:03:49 pm by AndreyS »
« Reply #181 on: August 23, 2024, 01:34:45 am »
Both of those things could be true.
Offline dorkshoei
« Reply #182 on: September 11, 2024, 09:44:35 pm »
The model I currently see on Amazon (USA) -- see attached -- looks nothing like your two images and more like the two part MDP700 which on the Migsig website is now marked "High Voltage Differential Probe MDP series(Old)".
The Amazon product is clearly marked DP10007 but if I look at the Micsig webpage [products -> High Voltage Differential Probe DP series (new)] I see it states "The previous model DP10007 has been upgraded to DP700".
I'm confused, clearly :D
I was in the market for my first differential probe (for use with Siglent SDS1104X-E).   I see the Amazon seller is offering a $30 promo bringing the price down to $159.99
« Last Edit: September 11, 2024, 09:53:01 pm by dorkshoei »
Offline MF-jockey
« Reply #183 on: October 31, 2024, 10:39:41 pm »
At the end of May I ordered a DP10007 from Banggood. The offer initially showed the new version but further back the old one was shown. The delivery arrived in mid-June and it was the old beige version. I also wanted the divider factors 10X and 100X because you can set these on my OWON DS7102.
I first installed the "Basic Upgrade"  (Thanks to ExaLab) with capacitors 1.2 pF and 1.5 pF. Later I carried out the CMRR measurements, once before and then after calibration. The CMRR values ​​from the data sheet were only achieved after the "Simplified Calibration Procedure".
(Table see Appendix 5)
After watching a video by David , I think the conventional DP10007 is the best choice for me.
I think the new version will only be available as DP700 or MDP700, Micsig writes: "The previous model DP10007 has been upgraded to DP700" and also "The previous model DP10007 has been upgraded to MDP700". Marketing is probably still in the clarification phase.
« Last Edit: October 31, 2024, 11:09:51 pm by MF-jockey »
Offline RogerG
« Reply #184 on: November 15, 2024, 03:28:44 pm »
2 days ago I ordered a DP10007 from Banggood. Tony Albus gave a hint via Youtube that if you order with delivery from CZ they will send the latest version in DP700 design instead of DP10007. Today was delivery time.... and tataaa ... I really got the new one!
Interesting that on the front of both of the device cases there is no DP700 text. Just Micsig. On the back of the part with the BNC there's a sticker with "DP10007". But every piece of hardware is exactly as what you see on a normal DP700. It comes with the black plastic carrying case and the normal hooks, alligators, banana extension cables and USB PS and a nice long USB A to C cable. Attenuation is 20x/200x, too.
The datasheet is clearly showing the values of the new DP700:
Attenuation, CAT rating, noise, CMRR, output voltage, power and power supply are all the values from the new device.
Nice bang for the buck, with some coupons I just paid 128€  :-DD.
I just hope that the rubbery coating of the probe case is no ordinary soft coating which becomes sticky after some years...
« Last Edit: November 15, 2024, 04:17:49 pm by RogerG »
Offline dorkshoei
« Reply #185 on: November 15, 2024, 03:32:56 pm »
I ordered from Amazon US on Sept 23rd and got the new style. US$140
It's also marked DP10007.  The marketing confusion re: model versions on micsig's site is unfortunate.
« Last Edit: November 15, 2024, 03:38:29 pm by dorkshoei »
The following users thanked this post: RogerG
