2 days ago I ordered a DP10007 from Banggood. Tony Albus gave a hint via Youtube that if you order
with delivery from CZ they will send the latest version in DP700 design instead of DP10007. Today was delivery time.... and tataaa ...
I really got the new one!Interesting that on the front of both of the device cases there is no DP700 text. Just Micsig. On the back of the part with the BNC there's a sticker with "DP10007". But every piece of hardware is exactly as what you see on a normal DP700. It comes with the black plastic carrying case and the normal hooks, alligators, banana extension cables and USB PS and a nice long USB A to C cable. Attenuation is 20x/200x, too.
The datasheet is clearly showing the values of the new DP700:
Attenuation, CAT rating, noise, CMRR, output voltage, power and power supply are all the values from the new device.
Nice bang for the buck, with some coupons I just paid 128€
I just hope that the rubbery coating of the probe case is no ordinary soft coating which becomes sticky after some years...
