Author Topic: New firmware Rigol DS1000Z 00.04.04.03.05 2018-05-09 (2018-02-28)  (Read 25849 times)
Offline David Maddison
Re: New firmware Rigol DS1000Z 00.04.04.03.05 2018-05-09 (2018-02-28)
« Reply #125 on: September 12, 2018, 11:07:03 pm »
Hi, thanks for all the valuable information in these posts. I have now joined the blog and this is my first post. Unfortunately it's a cry for help.
A couple of days I unlocked the extra features on my 1054Z using the unlock code generator posted elsewhere. I used the option code DSER. All features were shown as "official".
The existing firmware which came with the scope, purchased about a year ago, was 00.04.04.SP3. Today I tried to upgrade the firmware to the latest version which I downloaded from Rigol. I had a few attempts at loading the firmware and the scope said it was unsuccessful several times until it finally seemed to work. However, the firmware version in system information still shows the original version, not 00.04.04.03.05 which is what the scope recognised as the version number when I inserted the USB drive.
Thinking the download was corrupt I downloaded the firmware again and when I inserted the drive in the scope it warned that that version of firmware was already in the machine and I said to upgrade anyway and then it said the upgrade failed. Additional attempts at turning the scope on and off resulted in the same behaviour.
My question is, is the firmware upgraded or not? What's going on? Is it the case that the actual firmware version is not displayed in the System Info?
Thanks.
Online MarkF
« Reply #126 on: September 12, 2018, 11:32:52 pm »
Look at the extended system info by
Pressing MENU, MENU, FORCE, MENU, Utility, (soft button) System, (soft button) System Info quickly one after the other.
« Reply #127 on: September 13, 2018, 12:11:42 am »
Thanks. I've tried that and still get the same original firmware number.
Online MarkF
« Reply #128 on: September 13, 2018, 12:17:23 am »
If you are still seeing  00.04.04.SP3, you did not do the MENU, MENU, FORCE, MENU buttons fast enough.
The last version digit is NOT displayed on the normal status page.  Indicated by seeing SP# in the version.
Example extended system info
« Last Edit: September 13, 2018, 12:22:56 am by MarkF »
« Reply #129 on: September 14, 2018, 08:48:36 am »
I have tried this many times both using the menu button on the left and the menu button above the force button. No matter how fast I press them I do not get the extended system information. When using the menu button above the force button the screen menu goes into a different mode that doesn't include any system information options.
« Reply #130 on: September 14, 2018, 08:58:36 am »
Ok, I have worked it out now. I was looking for the screen utility button, not the physical utility button.
It says I have the firmware 00.04.04.03.05.
Thanks for the help.
Offline rob040
« Reply #131 on: October 06, 2018, 08:44:52 pm »
I can make this happen.
Did only Pluses.
DS1000Z_00_04_04_03_05.zip
Hi janekivi,
The file is no longer available, can you replace it please? I just found out there was new FW introduced (but still with the spelling error  |O )
Regards, Rob
Online Adrian_Arg.
  • Country: ar
« Reply #132 on: October 06, 2018, 11:54:24 pm »
Here I uploaded it, it's that of the janekivi friend, I had it downloaded.https://mega.nz/#!dFZAHQoK!T-I56b2R3sNJmvYrswF6zMD9ewUzs3Xt-aTfK_BoVss
The following users thanked this post: Vtech, rob040
Offline frozenfrogz
  • Having fun with Arduino and Raspberry Pi
« Reply #133 on: October 07, 2018, 11:55:22 am »
That leads me to the question: Is there a github / bitbucket / ... for the firmware hacking resources?
Alternatively I could offer to host compiled files on my web server.
He’s like a trained ape. Without the training.
Online TurboTom
« Reply #134 on: February 28, 2019, 10:15:20 am »
Seems like 04.04.04.02 is out: http://www.rigol.com/File/ProductSoftWare/20190228/DS1000Z(ARM)update.rar
Changelog specifies new encoder drivers. So far, I didn't install it. Maybe finally a usable acceleration or Rigol addresses the multi-function knob without indents?... Who's the first one to find out?  ;)
Offline Fungus
« Reply #135 on: February 28, 2019, 02:43:26 pm »
A big firmware day at Rigol!
The release notes only mention one change:
[Updated Contents]
v00.04.04.04.02  2018/02/26
     - Add new encoder drivers
(Wrong year? We're in 2019 now...)
« Last Edit: February 28, 2019, 02:48:52 pm by Fungus »
Offline Fungus
« Reply #136 on: February 28, 2019, 03:06:20 pm »
Just installed it.
I can't see much difference so far.
Offline metrologist
« Reply #137 on: February 28, 2019, 03:10:50 pm »
The encoder reference is just a distraction. You need to find what they broke!
Offline Fungus
« Reply #138 on: February 28, 2019, 06:01:55 pm »
pluses fixed?
I thought they already 'fixed' that in the previous one, I don't remember.
But the new one says "Pulses"  :(
(I was quite fond of that typo)
Online tv84
  • Country: pt
« Reply #139 on: February 28, 2019, 06:14:45 pm »
The pulses is correct.
00000000 - File Type: DS1000Z
00000010 - Software Branch/Version: 00.04.04.04.02
00000020 - Bitmask: 00000700
00000024 - # Sections: 10
Offset    Section Name                SectiSz   StartAdr  CRC32     Type
00000028  /sys/SparrowAPP.out         001092C5  00000280  A6399A25  00000001  [00000280-00109544]  CRC OK
00000064  /sys/SparrowFPGA.hex        000C4372  00109545  53615D42  00000005  [00109545-001CD8B6]  CRC OK
000000A0  /sys/SparrowDGFPGA.hex      00046F04  001CD8B7  C26BCA0B  00000006  [001CD8B7-002147BA]  CRC OK
000000DC  /sys/logo.hex               000BB818  002147BB  BE511060  0000000A  [002147BB-002CFFD2]  CRC OK
00000118  /sys/guiResData.hex         000B6B34  002CFFD3  979D9186  0000000C  [002CFFD3-00386B06]  CRC OK
00000154  /sys/guiPicData.hex         0001E6BF  00386B07  E31015E7  00000011  [00386B07-003A51C5]  CRC OK
00000190  /sys/SparrowConfig.hex      000BB818  003A51C6  A8ACDE94  00000010  [003A51C6-004609DD]  CRC OK
000001CC  /sys/SparrowWaveTable.hex   000020E8  004609DE  45F4045B  0000000B  [004609DE-00462AC5]  CRC OK
00000208  /sys/SparrowCalFile.hex     00022EFD  00462AC6  DA1B1AD2  0000000F  [00462AC6-004859C2]  CRC OK
00000244                              00000118  004859C3  00000000  00000032  [004859C3-00485ADA]
Offset    CRC32     Flags     Filesize  Endianes  Branch/Version
00000280  F2A44DB6  00000003  001092AD  AA5555AA  00.04.04.04.02  [00000298-00109544]  CRC OK
00109545  C9AF5D56  00000000  000C435A  AA5555AA  00.04.04.04.02  [0010955D-001CD8B6]  CRC OK
001CD8B7  138E13B9  00000000  00046EEC  AA5555AA  00.04.04.04.02  [001CD8CF-002147BA]  CRC OK
002147BB  9B4EA177  00000000  000BB800  AA5555AA  00.04.04.04.02  [002147D3-002CFFD2]  CRC OK
002CFFD3  271E3AB5  00000000  000B6B1C  AA5555AA  00.04.04.04.02  [002CFFEB-00386B06]  CRC OK
00386B07  01873014  00000001  0001E6A7  AA5555AA  00.04.04.04.02  [00386B1F-003A51C5]  CRC OK
003A51C6  5DEF7058  00000000  000BB800  AA5555AA  00.04.04.04.02  [003A51DE-004609DD]  CRC OK
004609DE  27F4C06F  00000000  000020D0  AA5555AA  00.04.04.04.02  [004609F6-00462AC5]  CRC OK
00462AC6  1E61A8F6  00000000  00022EE5  AA5555AA  00.04.04.04.02  [00462ADE-004859C2]  CRC OK
  File Processed OK
Offline JohnPen
« Reply #140 on: February 28, 2019, 06:28:07 pm »
Also upgraded to new Version 04040402 successfully.  With regard to 'Pulses' the left side Menu was updated to Pulses in last years update but the bottom of screen stats displays remained with 'Pluses'.  This update has corrected that so all Pulses are as they should be. :)  Now waiting for a complete warm up to run Self Cal and then see if I can notice any other changes in this Version.
Online Adrian_Arg.
  • Country: ar
« Reply #141 on: February 28, 2019, 07:37:58 pm »
I just updated v00.04.04.04.02  and calibrated the D1054z rigol, the presses were corrected (pulses) the calibration was fine.The good thing about all this is that they are still working on the DS1000z series :clap:
Offline JohnPen
« Reply #142 on: March 01, 2019, 08:49:13 am »
Self Calibration ran successfully and all appears well.  On limited testing the response time to adjusting Vertical gain and TB speed appear to be greatly improved. No noticeable lag.  Perhaps others can confirm as it does seem radically faster almost instant.  If just my scope perhaps the Self Cal recovered how it used to be as I haven't run Self Cal for over a year. ;D
Offline Fungus
« Reply #143 on: March 01, 2019, 09:34:22 am »
I can't imagine calibration is even needed after an update like this. It would only need recalibration if they change the code that manages the vertical gain amplifiers, which would be, like, never.
OTOH you're supposed to do it a few times per year to compensate for summer/winter/etc.
Offline perieanuo
« Reply #144 on: March 01, 2019, 09:40:14 am »
hi,
I did the upgrade for my DS1054Z, everything ok, rebooted the thing, check if upgraded>ok, then calibrate after 50 minutes failed.
now I'm trying calibration second time.
and yes, he was hacked before :)
[edit]
second calibration passed ok, now is fine.reports Model DS1104Z version 00.04.04.SP4, board version 0.1.1,
installed options remained untouched (trigger/decoder/mem-depth/recorder/bw 100M) :)
« Last Edit: March 01, 2019, 09:58:42 am by perieanuo »
Online 2N3055
  • Country: hr
« Reply #145 on: March 01, 2019, 10:48:43 am »
You really need to have scope on for at least half an hour before self cal.
One thing I've noticed is that after self cal all 4 traces perfectly align around zero and that encoders (especially one for horizontal position) have different (more aggressive, faster) acceleration profile.
Pulse are fixed in menu and measurements.
Otherwise works normally.
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #146 on: March 01, 2019, 11:47:10 am »
just installed it out of curiosity, did a calibration. no its still the same laggy on both vert and horz offset. vert and horz gain also still the same (laggy or not it depends on how you feel it), so no magic happened on my scope. but on the horz (time) offset, on previous version, on very quick encoder rotation, the time marker went off the chart very easiy far away, took me few counter encoder rotation to get it back, or easiest press for zero offset. but this version, on counter very fast rotation, the marker goes back to zero, so its nicer and quicker imho. but they are all laggy as before, the only way i know to get better respond is put the acq in stop mode and change to your heart content. math still like 3fps slow. the other thing i noticed is the bottom pluses urban legend is now gone. havent made extensive test on https://www.eevblog.com/forum/testgear/mechatrommer_s-rigol-bug-report-space/?topicscreen since previous version though... ymmv...
« Last Edit: March 01, 2019, 11:50:21 am by Mechatrommer »
It's extremely difficult to start life.. one features of nature.. physical laws are mathematical theory of great beauty... You may wonder Why? our knowledge shows that nature is so constructed. We simply have to accept it. One could describe the situation by saying that... (Paul Dirac)
Online RoGeorge
« Reply #147 on: March 01, 2019, 02:09:41 pm »
Kind of sad to see pulses instead of pluses  :-\
Offline frozenfrogz
« Reply #148 on: March 01, 2019, 02:27:21 pm »
Same here. It was one of those imperfections that gave it a little character. :)
Offline ebastler
« Reply #149 on: March 01, 2019, 02:47:05 pm »
Seems like 80% of the discussion around the new firmware release is about the "pulses".
I'll take that as an indication that the DS1000Z series firmware is pretty solid now. ;)
