Old guy here that trained as a tech years ago, just getting back into electronics. I need to build a bench up on a budget. been reading this site for a while and decided to sign up.
I picked up an old Tek 465b the other day, along with an old Sony/Tektronix 308 data analyzer/w probes and a little old heath sg1271 signal generator as a package for $200 bucks. Got it locally so I was able to briefly test the scope with the generator. Not a steal but not a bad price I think
Since then the generator that was working great has quit working after about an hour of use, power but zero signal out, should be easy to fix though as I have the manual.
The 465b works ok, it's pretty clean, no dents, all knobs and buttons intact, everything is functional, but spent some time in a garage, rotary switches and pots seem a bit oxidized but much better after a few rotations. Came with two sets of probes in the ziploc bags, and couple of other connectors.
Two issues I need to fix though that I would appreciate an opinion on from vastly more experienced folks here before I even open it up. First all the small push buttons stick pretty badly. They seem to switch electrically fine, it seems the springs just can't physically push the buttons back out. What should be cleaned and/or lubed and with what?
I know the service manual states to use IPA for the rotary switches contacts etc, easy enough, I don't know if I actually even need to clean them but the channel 1 vertical control seems loose, it can move up and down vertically when wiggled, with a corresponding reaction on the scope of intermittent connection. Anything specific to look for for that?
Then there's the probes not making contact good enough for good readings, and lighting up the proper 1x or 10x lights on the vertical, it uses the probes with that little pin to know what probes are in it and I have to wiggle em and hold my tongue just right to get a good connection it seems. What the best way to clean the BNC jacks and probe plugs for a good solid connection?
