I just received my Kaiweets KM601. I paid $43.50 with free shipping on eBay. Or at least that is where I thought I was buying it from. It came via Amazon delivery two days later. My thoughts....
The specifications, of course, are pretty mediocre. Best case is DCV at +/-0.5% (+ 3 counts). My unit consistently reads about 0.3% low on DCV and ACV. The Ohms, DCI, ACI, Frequency, and C values are much closer to nominal, comfortably exceeding the specifications.
The specifications are given over an 18 to 28 degree Celsius range. Since my lab is usually about 17 degrees, I put the unit in the oven for a few minutes and raised its displayed internal temperature to 23 degrees. Against my 10 VDC standard, the voltage reading went from 9.970 V to 9.978 V.
The buttons and user interface are OK, but it can be annoying to keep pressing the button to march through the functions. Also, the ambient temperature is displayed in Celsius and doesn't appear that it can be changed to Fahrenheit (it will show F if you are in the temperature function). The test leads are pretty much junk as one would expect at this price point.
Although I have metrology-grade equipment, I didn't have a portable DMM. What I like most of all about the KM601 is its size - it will fit in your pocket. It's a nice piece to have if you need to check things around the home and aren't concerned about ppm accuracy!
