MTX2088 ADC
This is Dual Channel 8-bit, 100Msps ADC... (analog AD9288)
datasheet
but can't see the processor. Is it hidden under the shield?
MCU is on bottom side, and it is Synwit SWM34SRET6
datasheet
How did you find the MCU make and model? On csuhi17 his pictures the marks on the chip are removed.
The ADC is most likely the same as used in the 1013D, 1014D and some of the other scopes FNIRSI makes. They can be overclocked but have not tried it myself, because it would require reprogramming the FPGA in the scopes I have. There we assumed it to be the AD9288 or a clone of it, but the markings have been removed, until now in this one where it is still there.
I wonder why they choose the bigger FPGA for this scope, instead of the most likely cheaper ones used in the other scopes.
