Can you charge a battery with it? Don't see mention of it in the datasheet or app notes, no precautions etc. unlike the EDU36311A which requires a lame output diode.
Regen, backspin, large capacitive load, battery potential etc.- unexpected voltage at the output terminals does happen.
I expect a power supply to be robust and cope with any load. Not crowbar it and don't take the backfeed and auto-destruct.
I can't get excited about a product, no right to repair- access to a service manual or at least a power-section schematic, that can get damaged with a common use, and asking Keysight Support over their shortcomings I've been through that and don't waste time taking blame for their own engineering omissions.
Can these new power supplies withstand voltage at the output terminals (4-wire sense as well), when powered off, or the output disabled, or above the setpoint? Yes the OVP function is obviously not enabled when working with these type of loads.
