Author Topic: Rohde & Schwarz Oscilloscopes - Questions/Comments? Let me know!  (Read 112850 times)
Offline KaneTW
Re: Rohde & Schwarz Oscilloscopes - Questions/Comments? Let me know!
« Reply #350 on: January 29, 2019, 03:28:38 pm »
50 Ohm termination with active probe support, 500uV/div setting, I2S/etc decoding, a bunch of other obscure decoding formats, power analysis.
Adjustable bandwidth limits (the RTB can only do 20MHz, the RTM up to 20/100/200/350/500).
More acquisition modes (envelope/average + high res).
More trigger options (runt, rise/fall time, multi-channel trigger)
Storing failed mask testing segments.
Low/high pass in math.
Spectrogram option.
E:
significantly less blind time in segmented more, 200ns on the RTM vs 2.5us on the RTB
« Last Edit: January 29, 2019, 03:33:21 pm by KaneTW »
Online mikeselectricstuff
    • Mike's Electric Stuff
« Reply #351 on: January 29, 2019, 03:30:09 pm »
Spectrogram option.
6M vs. 3Mbaud serial decode
Day Job: Mostly LEDs
Offline RobBarter
    • Bedrock Systems Ltd
« Reply #352 on: January 29, 2019, 03:37:04 pm »
The 50ohm termination was in my mind given I'm a radio amateur.
Wasn't aware of the 'multi-channel trigger'
minimal sig so a single msg doesn't take up the entire page!
Offline luzotug
« Reply #353 on: January 29, 2019, 11:28:22 pm »
Either RTM3k or RTB2k my advice : don't bother the individual software options, go for the PK1 bundle instead.
The only 3 options that matters and you can choose from are : MSO (B1), a bandwith upgrade, PK1 bundle.
The following users thanked this post: nctnico
Offline kaz911
« Reply #354 on: January 31, 2019, 11:38:43 pm »
I just wanted to thank Rich for being a great R&S ambassador - I think his presence in the Forum helps elevate R&S almost to Keysight Level (and sometimes even above)
So Rich - thanks for being there for me (and everybody else I hope) - got my K36 license without issue.
Please feel free to bring this appreciation letter to your bonus/annual performance talks. *G*
/Kaz
Offline RobBarter
« Reply #355 on: February 01, 2019, 12:18:45 am »
Thanks luzotug.  The PK1 and MSO were also the only options I was considering (bandwidth upgrade when needed).
My son is studying Electronics at Uni, so I thought I'd give him a say (v.small) in the choice.  RTB2k, RTM3k or Rigol 5000.   The answer was very predictable....he has expensive taste!  ::)
Offline Kean
    • Kean Electronics
« Reply #356 on: February 01, 2019, 12:48:44 am »
/Kaz
Seconded!  :-+
The following users thanked this post: Rich@RohdeScopesUSA
Offline Rich@RohdeScopesUSATopic starter
« Reply #357 on: February 01, 2019, 03:18:43 pm »
/Kaz
Thanks for the kind words.  Happy to help.
-Rich
Offline gsocker
« Reply #358 on: February 16, 2019, 10:39:13 pm »
Rich,
With the newer RTO firmware, is there a reason ASCII has disappeared from the protocol decode display formats? ISTR it was there on 3.70, but 4.15 and 4.20 don't have it. However, it is shown in the SCPI reference as an available option.
« Reply #359 on: February 16, 2019, 10:41:49 pm »
Rich,
Hi gsocker - I'm actually without my RTO right now, but I'll see what I can find out from Munich.
-Rich
« Reply #360 on: February 18, 2019, 04:13:17 pm »
Rich,
Hi gsocker - talked with Munich this morning and this will be fixed in a future release.
-Rich
Online jjoonathan
« Reply #361 on: March 30, 2019, 01:51:46 pm »
Hi!
I'm shopping for used RTO-1000s and one factor I need to price in is RTO-B10 (GPIB) -> RTO-B1 (MSO) conversion. It appears that these are swappable modules that occupy a slot on the back. My understanding is that these options can still be purchased for the RTO-1k series until 2021, but I filled out [this form](https://www.rohde-schwarz.com/us/product/sw_rtx-b1-productstartpage_63493-502030.html) early last week and didn't receive a reply. Is there another place I should look?
Thanks,
Jon
EDIT: Would you happen to know what the port is next to the GPIB (see attached)? It doesn't look like a MSO pod port -- is it some kind of mini GPIB? I didn't know GPIB came in a mini size. Adorable  ;D
« Last Edit: March 30, 2019, 01:55:08 pm by jjoonathan »
Offline aminor
  • Country: my
« Reply #362 on: April 01, 2019, 03:45:46 am »
/Kaz
Agreed. I endorse.
Online jjoonathan
« Reply #363 on: April 15, 2019, 02:30:19 pm »
Hi! Is there a way to configure a RTO1024 that occasionally warns about overheated ADCs for a slightly more aggressive fan policy? The fans are barely spinning even though I keep getting ADC temperature warnings (110 degrees C).
Thanks,
Jon
Offline Jackob
« Reply #364 on: September 09, 2019, 11:20:15 am »
Hi Rich and other R&S Oscilloscope gurus
Is there a way I could write short measurement applications for my RT01000-series oscilloscope and run them from the scope "User Apps" window? Using the remote commands would be perfect, but I would prefer not using a separate computer (via GPIB or LAN) but run the apps directly from the RTO itself.
BR, Jackob
Offline Gary350z
« Reply #365 on: October 29, 2021, 05:49:07 pm »
Rich,
I am looking for the 100 MHz to 200 MHz bandwidth upgrade for my Rohde & Schwarz HMO1212 Oscilloscope.
It is called "Voucher-Code R&SHV312".
I can't find it listed anywhere, not even on the Rohde & Schwarz website.
Can you help me find it, and the cost?
Thanks,
Gary
« Reply #366 on: October 29, 2021, 05:54:04 pm »
Rich,
Thanks,
Gary
PM'd.
-Rich
Offline Neurosurg
« Reply #367 on: July 02, 2022, 09:26:42 pm »
Finally, place for me.
Rich, please tell me who is Your R&S dealer in Poland who can borrow me for test's RTE1000 oscilloscope.
Tespol has Your equipment exept scopes. In electronics shops are models up to RTM3000.
Offline Neurosurg
« Reply #368 on: July 02, 2022, 09:57:52 pm »
Probably you do not borrow scopes, like RTE1000, because I just found that RTE1024 full opt. cost more then 60.-000$ (something about 200.000PLN in Poland. But i have plan for buissnes, if it will be able to cope with my epectations, I can get it for leasing for e.g. but only after having a chance to test it brochures and videos is too small for that cost which user can afford.
« Reply #369 on: July 06, 2022, 07:07:19 pm »
Sorry - been on PTO.  I'll PM you.
-Rich
Offline Gary350z
« Reply #370 on: July 07, 2022, 06:58:15 pm »
I am repeating my question because you have not responded after your initial reply on 10-29-2021.
Rich,
Thanks,
Gary
« Last Edit: July 07, 2022, 07:03:40 pm by Gary350z »
« Reply #371 on: July 08, 2022, 08:00:54 pm »
Gary - I apologize.  Asking again.
-Rich
Offline berke
  • F4WCO
« Reply #372 on: December 26, 2022, 10:24:47 am »
Is there a way of having bus decode on math on an RTA4004?  Example use case is decoding RS-422 with varying common mode, using CH1 - CH2 for example.  The math channels don't appear in the UART bus config menu.
Offline EEVblog
« Reply #373 on: December 27, 2022, 12:35:45 am »
FYI, using the MXO4 scope FRA function and also the remote desktop view in a new video:
The following users thanked this post: pdenisowski, mawyatt
Online mawyatt
« Reply #374 on: December 27, 2022, 02:19:06 pm »
Nice informative Video as usual :-+
Like the use of the FRA/Bode Plot feature to show the CMRR vs. Frequency, and some think these DSO FRA/Bode functions are useless ;)
Best,
~Wyatt Labs by Mike~
