Author Topic: NEW 100MHz Keysight Scope Release on 1st March 2017  (Read 239403 times)
Offline bitwelder
Re: NEW 100MHz Keysight Scope Release on 1st March 2017
« Reply #650 on: March 19, 2017, 06:59:49 am »
:-DD  :-DD
The last dozen or more posts have been with Siglent as the topic of discussion in a KS thread.  ;D
Rename the thread March Scopemonth?  :P
« Reply #651 on: March 19, 2017, 08:11:48 am »
:-DD  :-DD
Certainly seems that way, interesting times.  :)
Butting out now, we've got some new stuff coming soon too.  :-DMM
Avid Rabid Hobbyist
Offline mrpackethead
  • D Size Cell
« Reply #652 on: March 19, 2017, 08:14:01 am »
:-DD  :-DD
Makes me dislike siglent even more.
Offline ws2812b
  • Country: at
« Reply #653 on: March 19, 2017, 12:07:23 pm »
Pretty loud too. My application is in a quiet, audio-based environment where I need to hear subtle changes in musical pitch.
The old DSO that I use the most has a custom fan which is both large and looks like something to drive a wind tunnel but is practically silent.  A couple of my most used analog oscilloscopes are completely silent which can be a problem as well; I have left both on at one time or another without noticing for a week.
I do not know why so many test instruments now have such loud fans.  Maybe thermal engineering is considered too simple to be given enough consideration.
I'm also searching a pretty quiet scope. Can you give an idea how loud "pretty loud" is? Is there a spec? The only scope where I found a spec in the data sheet (and is in my price and feature range ;-)), seems to be the RTB2000? https://www.eevblog.com/forum/testgear/new-killer-scope-a-true-game-changer-from-rs-rtb2002-rtb2004/ There it says: "Audible noise | maximum sound pressure level at a distance of 1.0 m | 28.3 dB(A)"
Offline TheAmmoniacal
  • Country: no
« Reply #654 on: March 19, 2017, 12:21:50 pm »
I'm starting to lose track of what the different models can and can't do, how are the EDUX and DSOX different? Apart from the obvious - bandwidth and sample rate.
If we compare the EDUX1002G and DSOX1102G ...
Can the Ext Trig output also work as a digital input on the EDUX? So +/-1.6 or +/-8v? (mike says: "EDUX only has a single range for the EXT input, hence no relay")
The EDUX also has an option to enable Serial Triggering and Analysis (I²C, SPI, UART/RS-232), just not CAN and LIN?
Any other differences?
And is it correct that all models (A and G) has the training signals included? And these are generated by a hardware signal generator, it just doesn't have the frontend to the Gen Out?
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #655 on: March 19, 2017, 12:46:12 pm »
There is a feature comparison table in the datasheet listing all the differences.
Day Job: Mostly LEDs
  • Country: no
« Reply #656 on: March 19, 2017, 01:01:07 pm »
Alright, got that cleared up.
As it doesn't have SPI decoding, what about the Ext Trig as input?
« Reply #657 on: March 19, 2017, 02:10:41 pm »
Pretty sure it has this,just only one voltage range
Offline snoopy
    • Analog Precision
« Reply #658 on: March 20, 2017, 05:32:21 am »
I was wondering how long before SC came out with a review of this scope. Didn't take long because there's a review of the DSOX1102G in April Edition of Silicon Chip Magazine ;) Interesting enough it talks about a 2Gs/s sampling rate for 4 channel models. Freudian slip ?
  • Country: no
« Reply #659 on: March 25, 2017, 04:51:42 pm »
How many probe attenuation options does the scope give you? (Same for EDUX and DSOX I assume?) Does it have 0.2X and 0.5X for example?
If only Keysight would include the EDUX1EMBD I would throw my money at the 1002G.
« Reply #660 on: March 25, 2017, 05:18:02 pm »
0.1 to 10000 in 1-2-5 steps. also -20 to +80dB in 0.1dB steps. Also volts & amps
Offline synthRodriguez
« Reply #661 on: March 28, 2017, 05:17:17 pm »
Using my beat-up Radio Shack sound level meter I found in a parking lot along with my calibrated Stanley tape measure, I'm getting 56 dB at one meter, A-weighted when pointing it at the back of the unit.
The following users thanked this post: ws2812b
  • Country: no
« Reply #662 on: March 28, 2017, 05:20:09 pm »
Contacted my local Keysight distributor, 7 week delivery time on the EDUX1002G .. And no promos or package price for the decode option. Guess I'll wait a few weeks, keep an eye on the competition.
« Reply #663 on: March 28, 2017, 05:27:09 pm »
Farnell are showing 34 in stock.
Also don't forget the Scope Month giveaweays!
  • Country: no
« Reply #664 on: March 28, 2017, 05:45:26 pm »
I wish it was that easy. Farnell is also the cheapest option, but Farnell Norway do not sell to individuals  |O. The only other option I know of locally is Elfa Distrelec (https://www.elfadistrelec.no/en/oscilloscope-2x50-mhz-gs-keysight-edux1002g/p/30081608) but they refuse to ship to me, as I only have a PO Box (living on a university campus)  :-//.
My country is not eligible for the scopemonth, and no luck with Dave's giveaway (or ElectroBOOM's!). I guess I'll have to order it from abroad.. The fees associated with that stings though.
Offline nctnico
« Reply #665 on: March 28, 2017, 05:50:07 pm »
Why do you even want the EDUX1002G? It is positioned to outfit a classroom at low cost. For personal use you can get so much better bang for your buck that it is borderline insane to buy it.
  • Country: no
« Reply #666 on: March 28, 2017, 05:54:49 pm »
My room is a classroom  ;D
Offline Keysight DanielBogdanoff
  • ALL THE SCOPES!
    • Keysight Scopes YouTube channel
« Reply #667 on: March 29, 2017, 06:32:49 pm »
You can go to http://www.keysight.com/find/distributor and get a full list of distributors for your country. I see 7 options for Finland.
« Reply #668 on: March 29, 2017, 06:37:10 pm »
Speaking of Finland,  I'm surprised Daniel hasn't sent one to the Hydraulic Press channel....
Offline GlowingGhoul
« Reply #669 on: March 29, 2017, 08:58:48 pm »
Something tells me Keysight will have plenty of DMMs available for the hydraulic press very soon.....
Offline bitwelder
« Reply #670 on: March 30, 2017, 05:00:31 pm »
Errr.... for Norway (which should be TheAmmoniacal country) the FULL list is... 3 distributors, and one of the them is the above-mentioned Farnell.
  • Country: no
« Reply #671 on: March 30, 2017, 05:10:22 pm »
You're right. Lots of countries to keep track of!
Acal BFi and Farnell don't sell to individuals, and 4Test didn't get scopes during the first shipments - so a 7 week delivery time (for the next batches to arrive). I found it on RS Components though, but $120 more than other places :(
« Reply #672 on: March 30, 2017, 05:12:22 pm »
May be worth contacting them to see if they will price-match
Offline znroot
  • EE
« Reply #673 on: March 31, 2017, 07:34:58 pm »
I've got my DSOX1102G today...
The first impression is it's a huge and quality upgrade over SDS1000X and DS2072A.
Now let's see how it work in a production lab  :box:
I love negative feedback
The following users thanked this post: Keysight DanielBogdanoff
  • Country: no
« Reply #674 on: April 08, 2017, 06:14:40 pm »
Are there any soft carrying cases and front panel covers compatible with the new InfiniiVision 1000 X-Series?
