Author Topic: new killer scope in town - a true game changer from R&S - RTB2002 & RTB2004  (Read 942672 times)
Offline Robaroni
  • Retired EE
    • Design Specialties
There's no oil of any kind in scope probes, that's external.
Offline Darkover
I have RTB2002 for about 3 years and his 2 RT-ZP03 never show any sign of any leakage. They are perfectly dry. Maybe external causes? Proximity with some flowers, herbal decorations?
I never faced the problem you described! Is there any special gas in your enviroment?
However the probes from R&S not good anyhow. Buy some from PMK!
https://www.pmk.de/en/products/pml_high_z_tastkoepfe      PML712
They are smaler and the middle pin has a spring. They are so good that other famos company are buy them
and print there name on it and sold them for the double price  ;)
Unfortunatly R&S is to stingy to put good probes to >4000Euro scope.
Especially if you use the probes with the ground-spring you will never look back to the old ones!
Olaf
Offline alonsojar
Not a fan of the RT-ZP03, but PMK PML712 are selling 315 Euro plus VAT each... Is it a good price? Wow.
Btw, no problems with leakage in any of the four RT-ZP03 I own. I mainly complain  about the sliding hook mechanism that I feel tough and unpleasant.
J.Alonso
Offline Darkover
Aehm..yes. I am using older PML211 on my scope I bought  a few years back. I remember something like 150Euro VAT included.
https://www.batronix.com/versand/messtechnik/tastkoepfe/PMK/PML211.html
It is always possible to exchange bandwith by euro.  :-DD
Olaf
Offline pdenisowski
  • Product Management Engineer, Rohde & Schwarz
    • Test and Measurement Fundamentals Playlist on the R&S YouTube channel
My warranty is past, that's my fault, but decided to call Rhode and Schwarz support to inquire about this.  No one there had ever heard of this(came with RT-ZP03).
I have never heard of this before either (and believe me, I would have if it were a known issue), and I personally have a lot of ZP03 probes as well.  I think the other posters might be correct in that this was caused by some external substance getting on the probes at some point.
Test and Measurement Fundamentals video series on the Rohde & Schwarz YouTube channel:  https://www.youtube.com/playlist?list=PLKxVoO5jUTlvsVtDcqrVn0ybqBVlLj2z8
Offline Darkover
I have seen something like this with computer parts, rubber, cable that are installed in an
industrial sewage treatment plant. You did not notice it with youre nose, but some
gas/fumes can have strange effect on some plastic.
Sometimes I wonder how people can work there!
Please show a high quality picture to us.
Olaf
Offline electronix27
Thanks for all the replies.
This really has me stumped.  I know there's no oil inside the cable.  The outside jacket just appears to be degrading.  Has occurred to some degree on all probe cables but a couple have been a bit more.  No harsh environment, mostly just my home bench.  The scope itself still looks like new.  Shortly after original purchase, I bought the protection and transport case, model RTB-Z3, made just for this scope and 3000 series.  kind of expensive, but I don't regret the purchase, works really well.  All the probes and a few extra cables and a differential probe fit in there.  I thought that might be made in Germany.  It has a unique smell to it.  I used to roll all the probe cables and slide them inside front pouch, but after I noticed this wetness on the cables I put them in baggies first.  I don't think it's a reaction to case materials, none of the other cables inside have this issue.  When I first noticed the issue, I wiped them down with 91% Isopropyl, then water.  R&S Rep recommended same thing.  Few photos from storage baggie.
« Last Edit: April 16, 2024, 06:43:42 pm by electronix27 »
Offline Rydda
@electronix27
I believe my probe cables (RT-ZP03) suffer from the same problem, although not to the degree to cause a 'puddle'. But they feel very sticky, and when you handle them they leave a greasy feeling, and make you want to wash your hands. I bought my scope about three years ago, and I probably first noticed the problem last fall. The probes, when not in use, hang on a wall with no contact with anything else.
Beside them hang the probes (HZ200) from my previous scope (Hameg), and they do not suffer from this problem. I have had that scope for 20 years+.
I have encountered this problem before, especially in audio equipment where the manufacturer has tried to create a very flexible cable. On my high-end headphones, the symptoms appeared after more than fifteen years, but did not get worse. On my not-so-high-end headphones the symptoms also took a long time to appear, but they got worse over time, so I had to replace the  cable.
The worst cable I have had was a headphone extension cable of unknown origin that lay looped in a drawer for a long time. That cable had become a sticky mess, almost 'melted'. It was impossible to separate the windings.
My net searches gave no solution, other than to periodically wipe the cables with isopropyl. The cause of the problem was claimed  to be the softener agent in the material leaking out over time.
/Rydda
Offline Darkover
Hm..3years? I think my scope is now at the same age. I will check my probes very carefully later.
My probes stay unused in the delivery bag, most of the time, because I use the PMK probes
and only unpack them when I need 5-6 channels at the same time.
I think when it happens to more people it is a problem of the manufacturer of the plastic/rubber.
Olaf
Offline goaty
Same here 4 probes in bag, because use others.
They are not sticky but it smells a bit like plasticky.
The following users thanked this post: OlliFell
Offline Darkover
I checked my probes, they are okay.
Olaf
@ Rydda
Thanks for the very detailed and informative post.  At least I now know someone else has experienced this.
Russell
This last thing may be of use to someone.  Decided to purchase four new probes.  According to the Rhode and Schwarz website, I could purchase new probes directly from the company.  Support told me as an individual, not a company or part of a company, they could not help me.  Something about being in the process of changing the way they deal with non company purchasers.  Maybe US market only.
Considered some other options, but decided on OEM probes.  The only place to purchase these in the US currently is TEquipment.  So I ordered four RT-ZP03S probes.  The image, description and specs listed were exactly the same as RT-ZP03 probes, 1X/10X switchable attenuation.  Upon arrival I found the RT-ZP03S are actually 10X only, and all three waveform adjustments are now inside the small enclosure at the BNC connector.  They work, but I really do prefer the switchable attenuation.  Possibly the original RT-ZP03 are no longer made.
Part of the reason I purchased this scope for the higher cost was the claimed superior support.  Other companies may have the same protocol.  Nonetheless my last Rhode and Schwarz purchase.
Russell
« Last Edit: April 28, 2024, 05:09:57 pm by electronix27 »
Offline Darkover
I did not know that there was a kind of RT-ZP03 with 1x/10x switch, but is using this kind of probe not a
pain in the ass with a scope that can not autodetect the switch position?
There are very few reason why you should need a 1x probe with the limited bandwith on a 300Mhz scope with 12Bit.
I think that means your probes are the older type. The newer type has only two adjustment. The
third one is hidden behind the sticker.
I can understand. This company was always good in asking high price, but they became now bader in delivering a value for the money.
If I pay for a mercedes I like to drive one and not a beetle. (no 50R termination, no probe detection, fat probes)
Olaf
Online 2N3055
  • Country: hr
Olaf
RTB2000 is not 12 bit.
Dr. Richard W. Hamming
Offline Darkover
Ups, I invented two more bits.  ;)
However, it is noisefree enought that I enjoy it and I think it is very seldom that
I need the gain of 1x probe, especialy if I had to pay with lower bandwith.
Olaf
Offline pdenisowski
Did support say they could not answer technical questions or that they could not help you purchase accessories as an individual?  This is an important distinction.
Told me I had to purchase new probes from supplier, Tequipment was listed in my email as the supplier.  The only place I found these in stock in US.  Also spoke to R&S via phone.  For me, same as could not help me, I mentioned what was posted on their own website.  Again I was told R&S was changing policy for how they deal with non company individuals.
Offline pdenisowski
Thanks.  I'm not surprised if we are referring individuals (vs. companies) to distributors for purchasing accessories:  we don't really operate a "web store" in the United States, and most of our partners are very well stocked and can ship quickly (and are the same price as buying from us).
But I don't think our support model has changed with regards to individuals versus companies.
As mentioned I wanted RT-ZP03 probes, could only find The 10X only attenuation S probe.  Didn’t know that before arrival, RT-ZP03S is listed incorrectly on Tequipment website as 1X/10X.  The supplier didn’t know the difference, and I had no other option.  They didn’t contact me back.  So when I say R&S couldn’t help me, the supplier is my only contact for representation from the Rhode and Schwarz company.  R&S Support didn’t even want to talk to me about this at first until I contacted Tequipment beforehand, where I had purchased the scope.  That was a process.
I was told personally via phone R&S was changing policy how they deal with individuals.  As far as fully stocked, didn’t find this to be the case.
Offline Darkover
You are wrong. When I had a problem with my RTB last year I contacted R&S and they told
me that they did not talk with me because I am not a company.
I had to talk with the company that sold the scope to me!
Olaf
Offline Gribo
Hello all,
 I have an RTB2004, and I'm trying to grab a screenshot via SCPI commands. I'm trying to set the storage location to /USB_FRONT, but the unit can only save the screenshots to the internal storage.
Obviously, setting it to USB_FRONT works through the touchscreen and setting the location manually.
I'm on FW version 02.400.
Here are the commands I use:
EXP:SCRS:DEST /USB_FRONT
HCOP:DEST MMEM
MMEM:NAME 'FILENAME' (No extension here, otherwise I get FILENAME.PNG.PNG which cannot be deleted).
HCOP:IMM
If the destination is anything but /INT, I get a 200, "Execution error"
I am available for freelance work.
Offline Fenstergucker
  • Country: at
    • Private Website
Hello Gribo,
these commands work for me:
EXPort:SCRSave:DESTination "/USB_FRONT"
MMEMory:CDIRectory "/USB_FRONT"
MMEMory:NAME "Screen"
HCOPy:IMMediate
MMEM:CAT? "/USB_FRONT/*.*"
40960,2088968192,"SCREEN.PNG,,35478"
Peter
Offline Darkover
So you wrote a program that talk via network with the RTB? Why did you not ask
it to send you the picture direct?
sprintf(buf,"HCOP:DATA?\n");
write(s,buf,strlen(buf));
Olaf
