Author Topic: new killer scope in town - a true game changer from R&S - RTB2002 & RTB2004  (Read 942664 times)
Offline Gribo
Thanks, I used the HCOP:DATA? command.
I am available for freelance work.
Offline Ecogeek
I suspect the Fan model has been changed from early RTB to more recent. My unit arrived after 6 months on order in Jan 2023 and it is very quiet. Peaking inside the fan is also rubber mounted, but sorry no idea of the brand.
Offline alonsojar
Re: new killer scope in town - a true game changer from R&S - RTB2002 & RTB2004
« Reply #3302 on: September 10, 2024, 03:34:44 pm »
After more than 6 years in service I'd like to check if the button battery on the rtb2004 front board would need a replacement. No messages nor any problem arised by now.
The cell is easy to access once retired the back cover, but I'm not sure if removing it may delete any important record (like calibration or so) or it's just a RTC battery that in the worst case will reset the system date and time.
Of course the user manual doesn't even mention it.
Has anyone gone into this? Thanks!!
Alonso
Offline Fenstergucker
  • Country: at
    • Private Website
« Reply #3303 on: September 10, 2024, 05:08:25 pm »
Changing the battery is not a problem. When the oscilloscope is switched on, a message appears if the date is invalid, indicating that some options have been deactivated. But everything still worked for me, and after setting the current date and restarting, everything works as usual.
Peter
The following users thanked this post: Fgrir, alonsojar
Offline alonsojar
« Reply #3304 on: September 11, 2024, 07:32:46 pm »
Thank you Peter, I swapped the battery and all went smooth exactly as you said. Just for reference the battery was a Renata lithium 3V CR2032. It was still holding 2.95V, but replaced anyway to avoid leakage risks.
Alonso
The following users thanked this post: egonotto, Fgrir
Offline salomonander
« Reply #3305 on: October 08, 2024, 01:54:14 pm »
Is the RTB2002 still a good buy today? I can get a used one from 2018 like new (less than 10hrs of use) for around 900€
Offline KaneTW
« Reply #3306 on: October 08, 2024, 01:56:19 pm »
With all options 900EUR is a steal.
The following users thanked this post: nctnico
« Reply #3307 on: October 08, 2024, 02:16:16 pm »
Its the base model im afraid. No options at all. Dont really need them, to be honest.
Offline egonotto
« Reply #3308 on: October 08, 2024, 04:16:20 pm »
Hello
I would not buy the used RTB2002 without options for 900 €. A new Siglent SDS804X HD is cheaper and better in many areas.
Best regards
egonotto
Offline pdenisowski
  • Product Management Engineer, Rohde & Schwarz
    • Test and Measurement Fundamentals Playlist on the R&S YouTube channel
« Reply #3309 on: October 08, 2024, 05:20:40 pm »
I had the opportunity to play with an SDS804X and one of the things the RTB has going for it is a much larger screen (10.1" vs. 7") - it might not sound like much, but there's a huge difference in usability, at least for me.
And it's not just because I'm more familiar with R&S scopes :)  I have a much easier time driving a random KS, Tek, etc. scope that has a "normal" sized screen compared to the SDS804.  Still kind of surprised Siglent went with such a tiny screen, especially when there is no video out (like the Rigol DHO900 has).
Test and Measurement Fundamentals video series on the Rohde & Schwarz YouTube channel:  https://www.youtube.com/playlist?list=PLKxVoO5jUTlvsVtDcqrVn0ybqBVlLj2z8
The following users thanked this post: nctnico, skander36
Offline egonotto
« Reply #3310 on: October 08, 2024, 08:00:13 pm »
Hello,
if the screen is too small, you can use the web server. Or am I wrong?
If the noise of the RTB2002 is not significantly better than its bigger brother RTA4000, the SDS804X HD is better. It has more memory, 2 Mpts FFT instead of 128 kpts, 4 channels instead of 2, new instead of used and much cheaper.
Best regards
egonotto
Online nctnico
« Reply #3311 on: October 08, 2024, 08:18:42 pm »
Using a webserver isn't ideal due to lag and needing to operate a touchscreen device through a mouse. I'd get the RTB2002 if it covers my needs. Noise can be mitigated using high-res mode. The RTB2002 has many nice UI features which make life easy. Maybe the price can be haggled down a little bit further.
Online Martin72
  • Testfield Technician
« Reply #3312 on: October 08, 2024, 08:23:46 pm »
That one even compares a €500 scope with the former game changer... ;)
Offline hansibull
  • Country: no
« Reply #3313 on: October 08, 2024, 08:39:27 pm »
You should instead compare it with a Siglent SDS1000X HD or 2000X HD.
I have a fully equipped R&S RTB2004 at the lab at work and a Siglent SDS2000X HD at the office.
I've been using the RTB2004 since 2018, and got the SDS2000X HD last year.
The RTB2004 has a few things I wish the SDS2000X HD has:
However, I do like the UI on the Siglent better. I find it more intuitive, and easier to "find things" in the menus. I guess it's something one can get used to eventually, but I've always found the RTB2004 a bit more cumbersome, even when it was my only scope at work, and all I had back home was a Rigol DS1054Z.
The following users thanked this post: egonotto, pdenisowski
Offline alonsojar
« Reply #3314 on: October 08, 2024, 08:42:39 pm »
A question salomonander,
How do you know it only has 10 hours of use? Is there any record or scpi command showing the total hours?
I noticed in the service record option a file named Deviceinfo.txt with a 'Total operating time' field but observed it was reset from time to time (I think when a self-calibraton is recorded, but not sure).
I imagine it should be a record with this information, but maybe this is only for service people?
Perhaps pdenisowski may help in this. I'm just curious about the total hours mine was up.
Alonso
Offline analogRF
« Reply #3315 on: October 08, 2024, 08:50:55 pm »
I also dont recall seeing operating hours anywhere on RTB.
I think on the system info page it shows how many hours it has been ON since it was powered (just the "current" operating time  not the total)
Offline pdenisowski
« Reply #3316 on: October 09, 2024, 10:16:08 am »
That's a great question.  Let me ask R&D
The following users thanked this post: alonsojar
Offline pdenisowski
« Reply #3317 on: October 09, 2024, 10:21:21 am »
As someone who did a lot of protocol work early in my career, this is one of my favorite features :)  I made a video on this for the RTM3000 (works the same on RTB2000)
https://youtu.be/f13LbYHCOss?list=PLKxVoO5jUTlvsVtDcqrVn0ybqBVlLj2z8&t=193
Offline pdenisowski
« Reply #3318 on: October 10, 2024, 10:22:27 am »
According to R&D, there is no "total hours of operation (since manufacture)" counter on the RTB2000
Offline hotze
« Reply #3319 on: November 04, 2024, 09:43:05 am »
Hi, anyone here who knows how to check for and get latest firmware as a private user?
Online Kean
    • Kean Electronics
« Reply #3320 on: November 04, 2024, 11:08:46 am »
I cannot suggest anything other than trying to register using an email address on a custom domain (i.e. not gmail/yahoo/hotmail).
I registered for GLORIS access when I purchased my scope in 2018, and I was able to login just now without issue.  I do have my own domain name and business, and the account is linked to the local R&S sales rep I worked with.
The latest RTB2000 firmware is 02.400 released 06-Dec-2021 - so unless you have bought it more than a few years ago and never updated it, then you are probably on this version.
The following users thanked this post: hotze
Offline skander36
« Reply #3321 on: November 04, 2024, 11:15:18 am »
But are you able to download the fw?
I can also login but trying to download FW get me to to register page.
Online Kean
    • Kean Electronics
« Reply #3322 on: November 04, 2024, 11:19:15 am »
Yes, from this page - but you have to log in to view the download links
https://www.rohde-schwarz.com/firmware/rtb2000/
Offline skander36
« Reply #3323 on: November 04, 2024, 11:22:12 am »
As I said I am logged in , the link to downloads is there but clicking to it get me to the register page, endlessly.
My question was: Are you able to download the file (not to see the link)?
Online Kean
    • Kean Electronics
« Reply #3324 on: November 04, 2024, 11:34:38 am »
Yes, sorry I didn't make that clear.  I confirmed that the download links worked for me just before I replied.
Any ad or javascript blocker running?  Try another browser?
