Darkover wrote:
However it is nice that it is possible to use the firmware. I did not expect it. I thought there will never comes a new firmware even if they had a not so short buglist for the RTB. So it is a good surprise.
I'm curious about which bugs you have note to be present in the RTB today.
As for myself, I do have quite some wishes, but most are not really bugs, rather than improvements I'd love to see. See also
https://github.com/RudisElectronicsLab/RTB_SDS_DSOX_review/blob/main/v80_RTB_SDS_DSOX_Functional_Comparison_Aug_2024.pdfUrgent improvements wish list (‘bugs, or features that should not have been missing’)
• Switch DVM to AC mode when a channel is set to AC (instead of showing incorrect DC values)
• Solve the problem that “identity and data” in CAN trigger only works when frame length is set (other decoders in the RTB do require that)
• When a channel is set to current (A), adapt the FFT scales to dBA, dBμA, and Aeff (RMS)[/li][/list]
Desired improvements• Increase the update rate of the bus table in serial decode
• When editing labels, show the last value of that label (not the last value of another edited label)
• Increase label length from 8 to 12 or 16 characters; slightly increase label display size
• Allow math as input for serial decode
• Allow reference as input for serial decode
• Allow digital channels as input for math
• Solve some smaller UI quirks (In modes where the lower half of the screen is used for showing tables or measurement data, the right bottom (text) elements are sometimes masked by the R&S logo or vertical menu. In serial decode, the rightmost column (for most decoders it is ‘status’) is often not completely seen (especially a problem when two or three errors are observed in a single frame). Also, when closing a menu, the table sometimes does not restore to full size, while sometimes it does.)
• Turn measurements on/off globally (without deleting their settings), e.g., by pushing the MEAS button
• In parallel clocked mode, allow analogue channels to be used for CS and CLK so that a full 16-bit bus width can be maintained.
• Allow (CAN) serial trigger to find a message with known data content without having to know the length of that message in advance.
• Show more than 8 characters of filename in load and save screens
• Do not show (or grey out) a “?’ icon when the user is then presented with a “No help available for this function” message.
Desired changes that would (assumingly) require more drastic effort
• Show small histograms for measurements (and a large histogram for selected measurements)
• Include a formula editor in the math functions
• Allow the entire (segmented) memory to be used entirely by any channel
• Show relevant data for (each) measurement mode as X and Y cursors
• Allow serial decode of two bidirectional buses
• Display uploaded ARB file properties (points, amplitude, etc.)
Further wishes… • Add more complex and varied serial decode training signals (timing, ID, payload, (n)ack), including some with deliberately inserted errors
• Offer analogue training signals (glitches, runt, etc.)
