Author Topic: new killer scope in town - a true game changer from R&S - RTB2002 & RTB2004  (Read 505526 times)
Robaroni, KaneTW, maginnovision, Psi, bayjelly, chicken, tru, skench and 8 Guests are viewing this topic.
Offline Rich@RohdeScopesUSA
Re: new killer scope in town - a true game changer from R&S - RTB2002 & RTB2004
« Reply #2325 on: January 19, 2019, 03:26:23 pm »
Hi Folks - all PMs have been replied to.
And this is very much a manual process - the request actually ends up going to a group in Munich to handle, so please be patient.  I know they are pretty overwhelmed and sometimes the first requests take a little figuring out before they can get it all going smoothly.
-Rich
Online maginnovision
« Reply #2326 on: January 19, 2019, 03:54:09 pm »
-Rich
I think we're just excited to try out the feature we just found out about. Reasonable waits feel like decades!  :scared:
Offline mk_
  • Country: at
« Reply #2327 on: January 19, 2019, 04:10:21 pm »
-Rich
Thats a so called eevblog-DDOS...
Well, R&S should know that this would happen when there is a thread called "new killerscope in town...." and you do some good support to the crowd... :-+
Offline Hydron
« Reply #2328 on: January 19, 2019, 06:05:07 pm »
I too had the back and forth about the lack of a PK1 bundle, but have been told that eligibility will be confirmed on Monday (and that lookup of my device ID has indicated all options included in PK1), so I hope to have a positive answer and some new features shortly :)
I actually have another device for FRA measurements (with more functionality than the K36 option), but it would be nice to be able to check things quickly from my main scope.
« Reply #2329 on: January 20, 2019, 05:21:23 pm »
Hi Folks,
All PMs replied.
-Rich
The following users thanked this post: mtdoc
Offline stuartk
« Reply #2330 on: January 21, 2019, 02:03:27 am »
Wireless mice now work since the firmware update.
Both the Logitech M325 and Logitech M705 work.
Neither worked before.
Thanks very much R&S
Offline maxspb69
  • Country: ru
« Reply #2331 on: January 21, 2019, 03:14:08 pm »
I just received a email  with the activation code for RTB-K36 option from Rodhe&Schwarz!
Thank you so much Rich, for you assistance!
« Reply #2332 on: January 21, 2019, 08:57:55 pm »
Hi Folks - All PMs replied.
-Rich
« Reply #2333 on: January 21, 2019, 09:02:55 pm »
Also received mine with no back and forth. I did add numbers from the box though so maybe that made it easier or they've got it all figured out now.
The following users thanked this post: Rich@RohdeScopesUSA
Offline Hydron
« Reply #2334 on: January 21, 2019, 09:33:08 pm »
When did you request the key? (I assume it is a COM4 bundle unit?) Still no word about mine (Monday being almost over), but as Rich said they are busy and I'm not in a rush so I'll give it a few days before chasing.
« Reply #2335 on: January 21, 2019, 09:36:51 pm »
I sent the request 2pm on thursday(california time). Yes, a COM4 unit. From the box I included R&S order number, purchase number and consignee po number just to be safe.
« Last Edit: January 21, 2019, 09:40:17 pm by maginnovision »
« Reply #2336 on: January 21, 2019, 10:29:12 pm »
Took me a minute to realize I had to go into gen settings to set offset(testing single rail amp and filter and was clipping under 0 giving bad gain readings) but it seems fine. Not sure if it's an issue but you only seem to get three amplitude points for the gen output but you can set frequency and amplitude for them. Runs well, you can see the input/outputs and the plot, it also has a record for all recorded measurement points.
Offline JoHr
« Reply #2337 on: January 22, 2019, 09:15:22 am »
Got my key today  :-+
Found this on Youtube
The law of conservation of bugs states that the total amount of  bugs of an isolated system remains constant. Bugs can neither be created nor destroyed; rather, they can be transformed from one form to another.
Offline JoHr
« Reply #2338 on: January 22, 2019, 10:44:16 am »
Twisted some L-C Stuff together  ...  it works.   Thanks R&S.
Offline JoHr
« Reply #2339 on: January 22, 2019, 01:50:04 pm »
.... Not sure if it's an issue but you only seem to get three amplitude points for the gen output but you can set frequency and amplitude for them. ...
I can set the profil with up to 16 points with frequency and amplitude level each.
« Reply #2340 on: January 22, 2019, 04:43:25 pm »
I must have missed where you can add points then.
Offline simone.pignatti
« Reply #2341 on: January 22, 2019, 06:04:33 pm »
It is next to start and stop frequency
Technical Support
Offline nctnico
« Reply #2342 on: January 22, 2019, 06:09:13 pm »
I'm wondering.. is there any math possible on the bode plot traces? It would be nice to calculate the real and imaginary impedances (and from there the RLC values of the device under test). The latter would turn the feature into an LF network analyser.
« Reply #2343 on: January 22, 2019, 06:53:46 pm »
Ah, I'll have to look there too. I did find it in the main bode plot menu, I just overlooked it my first time through.
Offline casinada
« Reply #2344 on: January 22, 2019, 08:02:34 pm »
Bode Plot is explained starting on page 144 of the user's manual (revision 7). Of course manuals are overrated  :) :)
Offline emanresu
« Reply #2345 on: January 22, 2019, 11:18:03 pm »
-Rich
Argh, I had the "except messages only from admins" switched on :palm:
Can you please respond again?
« Last Edit: January 22, 2019, 11:20:49 pm by emanresu »
« Reply #2346 on: January 22, 2019, 11:51:09 pm »
-Rich
Offline Hydron
« Reply #2347 on: January 23, 2019, 09:05:37 am »
Got my code yesterday, a quick play suggests the feature does what it should for the standard gain/phase stuff and is not too slow at it either. Even used it in anger checking the frequency response of a CT I wound recently.
It's still limited compared to a real low-freq FRA/network-analyser (i.e. no calibration, L/C/Z plots etc), but that's a limitation shared by all the other big-name scope based "bode-plot" tools, and I have other tools for when I need to do that. Definitely happy with the additional feature  :-+
Online Robaroni
  • Retired EE
    • Design Specialties
« Reply #2348 on: January 23, 2019, 11:32:53 pm »
Thanks Rich, we're good to go.
Offline RGK
« Reply #2349 on: January 24, 2019, 03:58:14 am »
I'm all set for K36.  Thanks, Rich and R&S!
BK
