you can wait or buy products who are on the market way longer than this one, sure i did bought it knowing that
de-5000 is a basic 2 chip lcr, many others on the same design, and you have many others on the market ... choice is your's, some are proven okay and don't have known bugs, but pricey
i did try 10mF caps yesterday too, the last lcr digit do wobble a tiny bit, but i get expected values, tested with 0.035% precision resistors and others, and other type of caps (non precision) so far, it fit the bill, i did not test in circuit serial or parallel mode, i'm more the type who remove parts to do better tests
the fw has or may contains errors or else, over time it may get better if Zoyi do updates and hear all users comments, they seems to some extent
i dont have better lcr, bench types etc ... i can not do better compare, others may do ...
you'll have to wait or be a guinea pig testing it and see ? keep in mind that's a new product.
