If its the serial right side banner, then its just the arrow down below to get the native ch info banner.
For a modern dedicated bench oscilloscope with 12-bit vertical resolution, I find screen size & resolution very important, as that is my info-canvas and I don't wanna be undermined by something as fundamental as the screen.
- can you work on a small screen with low resolution' - of course, works okay, as we have seen for decades.
I understand on a mobile handheld scope that there are limits on how big you can make the screen without making it cumbersome to move around and hold one-handed, but on a bench oscilloscope where size is relative..
nope, make the screen big, and put a big gorgeous high-resolution screen of good quality in it.! (that is so fundamental in a modern 2024 oscilloscope, not least when you get up in a certain pricelevel)
1920x1200p = above 2.3mio pixels at 14" (MHO3/MDO/ETO series)
1024x600 = a tad over 600k pixels at 10".. On a high-resolution benchscope, then at least suit it up with a matching big "high-resolution" screen.
On MHO3 I believe that screen is actually a 16:10 ratio, so you get even more vertical screen, vs a 16:9 for those precious vertical bits., which is definitely a plus.
The MHO3 Micsig GUI looks (for a good part) to be the same as previous Micsig models, just with some added bells & whistles (that IMO was long overdue) and obviously way higher resolution, as my battery-unit are 600p 8" screen and a fraction of the 1200p, as on MHO3
It's a UI that is based around a touch interface, - and then later they added knobs, the majority of Micsig oscilloscopes are without knobs, its only STOxxxxC/E and MHO3 & MDO line, that got knobs as far as I remember.
And one of the big hurdles (IMO, at least in previous Micsig models) I reckon Its a shame that Micsig didn't optimize more of their features for knobs & button interface..- on my unit there are 7x clickable potentiometer knobs - and 23 buttons incl. a shift-button that will open up for secondary features for each of these, so you have a lot of tools to work with if Micsig actually optimized for it.
I would have loved if one of the knobs was dedicated to intensity or heatmap or the variable filters, fx through the lightable shift-button.
An example of the UI on the older 8" STOxxxC/E (I really like the variable bw-filtering, which goes from full bw down to 30KHz on my unit, with 1k Hz intervals,and where it seems to go down to as low as 30Hz on MHO3)
BW filt 3.18
