Yeah Fungus, it will sadly not be cheap, it looks to be a revised flagship
Micsig seems to be somewhat tight about it, but at least it ain't just a render - and is a model under development headed to market.
Micsig refers to it as a "500MHz, 3GS/s scope".. if the 500MHz is entry-model bandwidth, I don't know.
It does seem to have resonated with Micsig, that people prefer knobs, no matter how intuitive & touchy' you make the interface on these dual-purpose scopes (mobility & bench-use)
Both Micsig's relatively new models TO (10") & ETO (14") are completely removed for UI-buttons and their newer revision of "STO" line (8") is based around a 4-way joystick interface - with a somewhat minimalized button-layout (19 buttons & 4 joysticks) quite a bit less, than the quite popular STO-C/E series. with 23 buttons & 7-clickable rotary knobs.
https://tinyurl.com/c22uaaay /
https://tinyurl.com/mw34x8u5Though' the 500MHz, 3GS/s spec on this new model' seems to match their single-line ETO-flagship model (ETO5004) so it's likely Micsig seeing the light, and making their flagship 14" model [ETO5004] into a model with some buttons & knobs, as the ETO5004 also has these isolated Mic-OPI probe-connectors, and the ETO5004-UI seems to be the same.
My guess is that it's this 14" ETO-flagship model (500MHz, 3GS/s) that is present on the Chinese market, that is now being retrofitted with knobs & button interface, and the specs from the [ETO5004], would likely go a long way in getting an idea of this new model fundamentals.
Link
https://www.micsig.com.cn/ETO/ Promosheet [CN-pdf]
https://tinyurl.com/56274jhh
