Author Topic: New miniature programmable DC power supply - FNIRSI DPS-150  (Read 13315 times)
Offline ptluis
  • Country: pt
Re: New miniature programmable DC power supply - FNIRSI DPS-150
« Reply #50 on: September 27, 2024, 12:16:21 am »
Did you tried RISE instead of peak detect?
Hi
I don't know what RISE is.
My cheap scope has the acq. modes: Normal - Hi-Res - Peak - Average.
Thank you.
My mistake sorry,
Aquisition mode I use normal instead of peak
Trigger type I use Edge and slope Rise
After you check for ripple at no load, apply some load at output and watch the real ripple of the ps when stressed
« Last Edit: September 27, 2024, 12:23:52 am by ptluis »
Online Aldo22
« Reply #51 on: September 27, 2024, 08:36:17 am »
@ptluis
It depends on whether you don't want to miss a spike (Peak detect).
For ripple measurement, Hi-Res is probably the best for my scope.
I'll check with load later.
Thank you.
Offline ptluis
  • Country: pt
« Reply #52 on: September 27, 2024, 10:24:00 am »
@ptluis
Thank you.
Well you should try and see what option gives you the best results, but in ripple measurements were not looking for spikes. that's my 2 cets
Online Aldo22
« Reply #53 on: September 27, 2024, 10:50:32 am »
I understand that this is a good way to measure ripple.
But actually the higher frequency noise of my (other) SMPS bothers me even more...
It's not that easy: https://www.4niev.com/switching-power-supply-noise/  ;)
But in any case, my self-built PSU hasn't shown any worrying interference in any range so far.  :-+
And to get back on topic, I think it would be a good source for the DPS-150 (for low power applications).
Offline ptluis
  • Country: pt
« Reply #54 on: September 27, 2024, 12:15:46 pm »
Your self made psu operates differently from  smps  (switch mode power supply) so the smps always show spikes, some show higher spikes other less, depending on the quality of the filtering, with aquire mode set to peak, your calculated pk to pk value is higher meaning ripple measured will not be real.
The dps-150 is a dc-dc buck converter that also produce spikes although at lower values and in this case it's possible to even decrease them to lower values by using a ceramic capacitor with low esr at the output, the low esr is the key.
If you don't want any ps noise on your dut you should power it using batteries as source of power, and use analog voltage regulators like the 7812 for eg. Also in audio electronics a clean PS is preferable.
Offline Fungus
« Reply #55 on: September 27, 2024, 01:11:04 pm »
Yeah, something like this is probably useless for Audio.
Online Aldo22
« Reply #56 on: September 27, 2024, 02:43:31 pm »
Here are the ripple measurements of my own PSU (12V), in case anyone is interested.
Above without load, below with 1.5W.
I will hardly need more power with this ps.
That's good enough for me.
Offline ptluis
  • Country: pt
« Reply #57 on: September 27, 2024, 03:16:26 pm »
Now with the load, change the aquire mode to average 8 and you'll get a more stable representation of the ripple of your ps, meaning a better visualization of the ups and downs of the stabilization.
Online Aldo22
« Reply #58 on: September 27, 2024, 03:34:51 pm »
These screenshots are taken in "Hi-res" mode.
This is also a type of averaging, but does not iron out as much as the “Average” mode.
I think that's fine. 250uVrms ripple at 12V is OK. I don't think I can (or want) improve on that.
Thanks.
« Last Edit: September 27, 2024, 03:40:09 pm by Aldo22 »
Offline ptluis
  • Country: pt
« Reply #59 on: September 27, 2024, 04:05:40 pm »
Thanks.
High res won't "clean" the signal as much as average does and that's why average is nice to "make the signal thinner" by removing the less constant acquired points and keep the most stable ones. It's a way of loosing fat  :-DD
Online Aldo22
« Reply #60 on: September 27, 2024, 04:34:45 pm »
Yes, that's where we reach the limits of my $150 scope.
You need a stable trigger for average mode.
But it doesn't manage to do that in the uV noise salad.
But I remembered that it has a line trigger mode (50Hz)
This works a little, but you can clearly see the limits.
In the attached screenshot: 1.02mV/div ("zoomed")
If you squint your eyes a little, you can see the capacitors discharging. :-DD
But for $150 it's not that bad...   ;)
« Last Edit: September 27, 2024, 04:45:15 pm by Aldo22 »
Offline ptluis
  • Country: pt
« Reply #61 on: September 27, 2024, 06:21:28 pm »
That's where 500uv/v scopes come in.
And you know, it's better to have a 150€ scope that allow us to "see" electricity that have nothing and just guess. I use 70 bucks toy scopes like the dso2512g and the dpox180h for quick checking signals and only use the better ones when I need more accurate info on what's going on.
Online Aldo22
« Reply #62 on: September 27, 2024, 06:34:55 pm »
Sure, but I can actually see enough.  :)
Delving deeper into microvolts doesn't give me any additional information that could be of practical use at the moment.
obrigado
Offline ptluis
  • Country: pt
« Reply #63 on: September 28, 2024, 12:58:22 am »
Quote from: Aldo22
obrigado
"De nada"  :)
We're here to help each other  :-+
Online Aldo22
« Reply #64 on: September 28, 2024, 09:37:46 am »
If you increase the number of acquisitions in average mode, you see a pretty clean signal.
It's amazing what can be achieved with a few (cheap) tricks.  :-+
Offline ptluis
  • Country: pt
« Reply #65 on: September 28, 2024, 10:28:06 am »
Yes and it's a way to see if there's a problem with the rectification
bridge. if you have a not so good diode in the rectification bridge you will see it!
 but average mode is not good for signals when you can't get a stable trigger in this case hires mode could help better.
Offline Eltax1693
FNIRSI DPS-150 firmware
« Reply #66 on: October 04, 2024, 03:22:23 pm »
I'm on firmware 1.0
Any newer version available?
Thank you
Offline Stray Electron
« Reply #67 on: October 04, 2024, 11:23:25 pm »
Uout >=5V
Shame!!!
I don't know what Uout is.  Do you mean Vout?
If so, the device goes from 0V to 30V.
    "U out" is very commonly shown on German made electronics instead of "V out".  It must be a language thing.
    This is the explanation that I found online.  One of our German members can probably tell us if it's correct.
But now, I found, an explanation plausible and maybe also a historic for that, which is as follows: Germans started denote voltage by the letter "U", probably because that letter was largely unused and so couldn't be confused with anything else. It also came up by its etymology, since "U" stands for Unterschied, which in German means "difference"; very fitting since voltage is obviously the same as potential difference.
Offline xKertx
« Reply #68 on: October 05, 2024, 12:14:42 am »
Uout >=5V
Shame!!!
"U" is not german. It is used  in europe overall.
Online Aldo22
« Reply #69 on: October 05, 2024, 11:46:57 am »
As far as I know, "U" means “electrical voltage” (German: Spannung) and "V" is the unit Volt.
The "U" comes from the Latin word “urgere”.
It's like "I" ("intensité du courant") and "A" (Ampere).
In English "V" is used for the phenomenon (in formulas) as well as for the unit.
« Last Edit: October 05, 2024, 02:41:56 pm by Aldo22 »
Offline Fungus
« Reply #70 on: October 05, 2024, 03:02:03 pm »
OK, I bit the bullet and ordered one on Aliexpress.  :)
I'm gonna get a USB C charger to power it, it seems like the best/easiest option.
FWIW: Ikea make awesome phone chargers and they're super cheap. Their 30W "SJÖSS" should be enough for me (supports 20V, 1.5A) and they're only 7 Euros.
I'm gonna get a bunch more of their little SMÅHAGELs as well. They're awesome for powering 5V gadgets, and only 3 Euros(!)
« Last Edit: October 05, 2024, 03:04:32 pm by Fungus »
Online Aldo22
« Reply #71 on: October 05, 2024, 06:57:27 pm »
Congratulations!
I'm still looking for a potential use for this thing.
It's like the Fnirsi SG-003A: somehow I'm tempted to buy it, if only I could find a tiny rational reason to do so...  ;)
Offline 4thDoctorWhoFan
« Reply #72 on: October 05, 2024, 08:10:09 pm »
You can NEVER have to many power supplies.  :-+
The same goes for multimeters.  :D
Offline Nominal Animal
« Reply #73 on: October 05, 2024, 09:35:35 pm »
Both U and V are common symbols for voltage; I've definitely seen both.  U is also used in physics for potential energy (as is V and Eₚ, too).
The situation is very similar to calling 74W "tungsten" or "wolfram".  ("Wolfram" is the original one, stemming from the ore wolframite; "tungsten" derives from the scheelite ore, then called tungsten, and is Swedish for "heavy rock".  Basically, Scandinavian mountain miners used the former, German (and slavic miners later on) the latter, way back in the day.  The German miners just had a habit of naming their ores more imaginatively, )
In physics, many prominent physicists in the 1700s to early 1900s developed somewhat distinct patterns of notation, including which letters they used for which physical properties and measurables (especially U, V, and what superscripts and subscripts were used for).  Some even developed completely new notations; see e.g. Dirac or bra–ket notation.  Einstein notation in particular can throw even mathematicians off, but is very common in some areas of physics.
There is no specific correct notation.  It is just a matter of convention; whatever one is used to.  Claiming otherwise is just succumbing to a perceived authority, and rejecting individual thought.  Certainly, all the great scientists have changed notations whenever it suited them, simply because it is just a tool, a way to convey the ideas and expressions.
Offline DaneLaw
« Reply #74 on: October 06, 2024, 12:51:13 am »
Congratulations!
They can be quite handy, these small SMPSUs and the ability to have a small adj. powersupply with a powerbank or LIPO cellpack.
and PD3.1 (28v/5A) powerbank with 140watt works well with either a 100W or 150W. 30/5A SMPSU.
« Last Edit: October 06, 2024, 01:10:47 am by DaneLaw »
The following users thanked this post: artik, Aldo22, rozwell
