Author Topic: RTB2004-COM4 RTB-B6 Pattern Generator Trouble on SAVE/LOAD  (Read 1343 times)
Offline AntoninoTopic starter
« on: August 26, 2020, 04:39:50 pm »
i'm Antonino from Rome.
I want to apologize immediately for my poor English.
My problem arises when I intend to load a previously saved arbitrary pattern.
No problem if I try to load the ARB.SCP file already contained in the internal memory. (/INT/SETTINGS/ARB.SCP)
The problem only occurs when I try to load a file saved by me.
The oscilloscope freezes.
I found that the files I saved have more or less this formatting (MyFile.SCP):
:PGEN:FUNC ARB
:PGEN:PATT:ARB:DATA 1,2,4,8,0
:PGEN:PATT:ARB:DATA:LENGTH 5.000000e+00
:PGEN:PATT:BURS:STAT 1.000000e+00
:PGEN:PATT:ITIM 4.000000e-02
:PGEN:PATT:BURS:NCYC 5.000000e+00
:PGEN:PATT:STIM 1.000000e-04
:PGEN:PATT:STAT 1.000000e+00
Instead, the ARB.SCP file already in memory starts with:
*RST;*CLS
CHAN1:STAT 1
CHAN1:POS -2.5
PROB1:SET:ATT:MAN 10.0
CHAN1:SCAL 0.5
PGEN:PATT:STAT 1
PGEN:FUNC ARB
PGEN:PATT:ARB:DATA 0,1,2,4,8,0
TRIG:A:TYPE EDGE
TRIG:A:SOUR CH1
TRIG:A:EDGE:COUP DC
TRIG:A:EDGE:SLOP POS
TRIG:A:LEV1 1.5
TIM:SCAL 5e-6
If I manually add (through RSCommander on the pc) the line
* RST; * CLS
to MyFile.SCP then the oscilloscope loads correctly.
*RST;*CLS
:PGEN:FUNC ARB
Any suggestions?
Best regards and many thanks.
Antonino
P.S.
Device Firmware version 02.202
Re: RTB2004-COM4 RTB-B6 Pattern Generator Trouble on SAVE/LOAD
« Reply #1 on: August 26, 2020, 06:05:36 pm »
Hello
thank you very much.
Also, each line of the file begins with ":".
Strange behavior...
Antonino
« Last Edit: August 26, 2020, 06:08:49 pm by Antonino »
Offline Rich@RohdeScopesUSA
« Reply #2 on: August 26, 2020, 06:33:55 pm »
Let me run this by the development team.
Thanks,
Rich
« Reply #3 on: August 26, 2020, 07:09:16 pm »
@PeDre
Ok, but keep in mind the ARB.SCP prebuilt in internal storage(R&S) Is written whitout ":".
Thanks a lot
Antonino
« Last Edit: August 26, 2020, 07:14:28 pm by Antonino »
« Reply #4 on: August 26, 2020, 07:12:12 pm »
Thanks,
Rich
Thanks to you!
Antonino
« Reply #5 on: August 26, 2020, 07:17:43 pm »
If I save the settings on a USB stick on the oscilloscope afterwards, there are no "*RST;*CLS" commands. Loading from USB stick will freeze the oscilloscope.
This Is true also for int storage.
No differnces.
Thanks,
Antonino
« Reply #6 on: August 27, 2020, 01:53:59 pm »
Heard back from the team - this is apparently a known issue and a fix is planned for the next release.  The next release is currently planned for October.
-Rich
The following users thanked this post: egonotto, maginnovision
