Impressive. Now you just need to create a phase noise test set. I am dying to test it myself against my 5370B. Your .tim files are almost identical to the 5370 which even today, is still a great performer.
Two more questions:
1) Is the performance of the 7G and 12G versions the same under 5Ghz? Most of my testing would be using ultra low noise oscillators in the 26Mhz range but I'm curious if the noise baselines are the same for the two versions of the unit, and if they differ, at what frequency does it begin?
2) Given R and L still doesn't have the 12G version, if I purchase the 7g version, can it be upgraded?
Thanks again.
Jerry
