I hope no one minds me summing up the steps one more time for clarity. It's other peoples hard work we have this, not mine.
I finally got DG811 and read through this thread again.
Just so people don't have to read through all the posts and worry if they missed something.
My DG811 came with version 02.05.
Make a note of your serial number.
(On my device it can be still found on the back on a sticker)
Using:
- Windows 10 laptop, latest version
- 4GB USB drive formatted FAT32 with 4096 sector size with windows formatting tool. No magic on the USB drive at all.
All rar, zip archives files contain SardineUpdate.GEL file and that needs to be extracted from the archive and placed into root of formatted USB drive.
You don't need anything else.
OPTIONAL STEP - Backup calibration and internal memory
Extract SardineUpdate.GEL from
https://mega.nz/file/i91yEJRa#rRocE7s31SXCFvfQgmwkFF45v3vF9R8A0yb8PmfM4Hc on the root of USB drive.
Turn on Rigol device.
Plug in USB drive into rigol device.
Rigol detects update file and prompts for update.
Click yes.
Rigol displays Waiting and spinning wheel.
Rigol detects update file and prompts for update a second time.
Click cancel.
Unplug USB drive from rigol.
Plug USB Drive into computer to save dumped files.
adds two folders to USB drive:
- cal
- Internal Memory
OPTIONAL STEP - Backup NAND
https://mega.nz/file/P0lSVTJI#lccrNrvA2JOcZUqgvpV5dOT0-CweNUH5GWuzty4WkFw on the root of USB drive.
Click yes.
Click cancel.
NAND Backup script adds 14 files mtd#_NANDxxxxxxx about 500MB in size
takes a short while longer than backup calibration
STEP - Downgrade to 01.08.01
https://mega.nz/file/bxtkUJyA#hg0H1bxcOMeBNW6zbOwJvxEYqWtyL_UXmftwTMTBuWg on the root of USB drive.
Turn off Rigol device
Plug in USB drive
Turn on Rigol device and repeatedly press help button until you notice it detected firmware
Rigol displays: Upgrade from usb disk, reading...
Rigol displays: Upgrading (x/x) flash images...
Rigol resets into DG992 model 1.08 firmware.
(don't worry about unplugging usb drive)
STEP - Upgrade to latest firmware version 02.06.01
https://mega.nz/file/L51wBJrA#ZTDJ6_mi-U4N03YW7YrRVj-pgHYRTdB4z1yaSQmmD3I on the root of USB drive.
Plug in USB drive
Rigol prompts to upgrade
Click yes
Rigol restarts
Rigol resets into DG811 model 2.06 firmware.
STEP - Reconfuse Rigol into thinking DG992 way
https://mega.nz/file/f01EkZRK#HCifK9T-fDxB5RNpAtYNkKdPE7Rrh_6XZcvMV_quLng on the root of USB drive.
Plug in USB drive
Click yes
Rigol restarts
Rigol resets into DG992 model 2.06 firmware.
OPTIONAL STEP - WRITE SERIAL NUMBER TO DEVICE
Download "Ultra Sigma (PC)Installer" 00.01.06.01 Rigol software from
https://www.rigol.eu/En/Index/listView/catid/28/tp/5/wd/ultra%20sigma and install it.
(The software asks to disable fast boot in windows. I chose not to disable fast boot)
If the link does not work try
https://www.rigol.eu/products/waveform-generators/dg900.html -> Download -> software-firmware download -> software download -> search for "ultra sigma"
Software is about 500MB download and takes relatively long time to install and requires a computer restart.
I backed up the software here:
https://mega.nz/file/HpU1hQKB#BMuIwve2RK0FiX3OOBGYyb4VcWkl4HSxBDJP0kXaHBwPower on RIGOL device.
Open Ultra Sigma software
Connect Rigol device to PC via USB-A to USB-B (printer) cable.
Rigol is recognized by Ultra Sigma as DG992
Right-click "DG992 (USB0: :0x1ABa: :0x0643: :DG80000000001: :INSTR)" or something similar and select "SCPI panel control" (new window opens)
Write commands without quotes!
Check communication by issuing "*IDN?" command: Write "*IDN?" into the textbox, press "Send Command" than press "Read Command".
Rigol returns something like:
<- (Return Count:55)
Rigol Technologies,DG992,DG80000000001,00.02.06.00.01
Issue command with Send Command button ":PROJ:SN DG80000000001" with your correct serial number instead of DG80000000001, Click Send
Verify if it worked by sending another "*IDN?" command - it should report back with correct serial number
Disconnect the instrument from PC.
All files are just reuploaded files found on this thread, archives untouched.
