Thx
I saw the same excerpt. It’s not very understandable what the manual is trying to convey. “Pushed twice” means pushed twice in fairly rapid succession? Or something else? And “485-2 is non-illuminated momentary switch for RESET only”?? If anyone can explain, thanks.
Does 485-1 and 485-2 refer to two versions of the 485? Or maybe the wording indicates there is also a 485-3 version? If so, any easy way to ID the particular version?
On the good channel the 50/1M buttons work and the 1, 10, 100X probe LEDs work; on the 2nd channel only the 1M Ohm setting works, and the 1X LED works, but with a 10X probe the 100X LED goes on rather than the 10X LED - so maybe the IC David described is the problem, or maybe it’s a discreet (resistor) component? How hard is it to access this area inside?
Thanks again
