Hi all, I got a 1054z and DG1022z in early last week.
I'm new to any test equipment beyond a good multi-meter, but learning them has been going fairly well.
Lot's of EEVblog tutorials, and searching around the good info in this thread. THX!
After being able to put a wave file into the signal generator using Ultra Station / Sigma, I figured all systems are an eventual go,
so I decided it's time to go ahead and do the 1054z hack.
But I get 'invalid license' no matter how I go about it.
Whether I input the key from the o'scope Editor, using SCPI commands via telnet (PuTTY) or Sigma....always the same...'invalid license'.
Can't be an issue of confusing B for 8, S for 5, etc...
I've generated DSER several times from
http://gotroot.ca/rigol/riglol/, always get the same key.
Tried with a key generated for just Record...it was invalid too.
Serial # on screen matches the one on the unit which matches cal certificate.
Checked firmware via upgrade routine..says same as already installed ...00.04.03.SP2
Sorry to ask for help here, given how often this topic has come up...I've really tried to figure this out...
But I'm stuck...
