Author Topic: New Rigol DS1054Z oscilloscope  (Read 2232086 times)
Online ebastler
Re: New Rigol DS1054Z oscilloscope
« Reply #4775 on: October 25, 2023, 07:08:03 pm »
Rigol 1054z and 1074z timing problems at 500ms timescale and 24M memory depth
https://www.eevblog.com/forum/testgear/rigol-1054z-and-1074z-timing-problems-at-500ms-timescale-and-24m-memory-depth/
Ah, thanks. Indeed, my scope does that too, running firmware 04.05. (The most recent one released internationally, I believe.)
Seems like a small barn to me, on a road rarely travelled... But on the other hand it should not be that difficult to fix, so I understand Sredni's annoyance.
Offline rob040
« Reply #4776 on: October 25, 2023, 07:16:22 pm »
rob040, Can you share the download link from the latest firmware update?
www.rigol.com/products/detail/DS1000Z
« Last Edit: October 25, 2023, 07:30:15 pm by rob040 »
The following users thanked this post: Adrian_Arg., alexalr, infino
Offline Adrian_Arg.
  • Country: ar
« Reply #4777 on: October 25, 2023, 08:22:18 pm »
At some point I sent an email to Rigol with that problem, they replied that the problem was solved, then I sent them an image of the installed firmware version and a video with the error, they never responded to me.
in spanish
yo en algun momento les envie un mail a rigol con ese problema , me contestaron que ese problema estaba solucionado, luego les envie imagen de la version firmware instalado y un video con el error, nunca me contestaron.
Offline Adrian_Arg.
  • Country: ar
« Reply #4778 on: October 25, 2023, 08:43:53 pm »
We are going to have to install it and add some new functionality, in the menus or something else.
Offline Sredni
  • Country: aq
« Reply #4779 on: October 25, 2023, 10:22:04 pm »
Well, yes one does not always operate at that set of specific settings, but since the bug is there it is necessary to remember to avoid that combination.
We also don't know for sure that it happens only in those conditions. One thing is an inaccurate instrument, a completely different matter is a tool that gives absurdly wrong values out of the blue.
Offline Adrian_Arg.
  • Country: ar
« Reply #4780 on: October 26, 2023, 04:36:51 pm »
Hello friends, I wanted to see if there were improvements, so I downloaded the new version of the Rigol DS1000z firmware v00.04.05.02.08, I formatted a 4GB pen in fat 32, I inserted it into the oscilloscope's USB, it detected the new version and did all the installation process, it asks me to restart and when it restarts it continues with the same version, I tried three different pen and everything is the same, it does not install.
in spanish
hola amigos, queria ver si habia mejoras, asi que descargue la nueva version del firmware de rigol ds1000z  v00.04.05.02.08, formatee un pen 4gb en fat 32, lo introduzco en el usb del osciloscopio, este detecta la nueva version hace todo el proceso de instalacion, me pide que reinicie y cuando reinicia sigue con la misma version, probe con  tres pen distintos y todo igual, no instala.
Offline Karel
« Reply #4781 on: October 26, 2023, 05:27:46 pm »
No surprise. They only fix bugs that doesn't require too much effort.
I guess some bugs cannot be fixed because of hardware limitations.
Then there's also the eternal USB bug (they use a mix of High Speed and Full Speed USB 2.0 protocol
that causes a timeout on Linux).
« Last Edit: October 26, 2023, 06:37:15 pm by Karel »
Offline Adrian_Arg.
  • Country: ar
« Reply #4782 on: October 26, 2023, 10:44:37 pm »
Could it be that this version of firmware is not compatible with DS1000z that are more than four years old? |O
Offline RoGeorge
« Reply #4783 on: October 27, 2023, 06:03:51 am »
Have you read the entire version string, or just the major few numbers that are shown by default?
To read the detailed version, under the trigger level knob, press fast
'MENU' -> 'MENU' -> 'FORCE' -> 'MENU', then press normally
'Utility' ->  'System' -> 'System Info'
What version is displayed now on your oscilloscope's screen?
Does it show the build date?  What is the software build date?
Offline Adrian_Arg.
  • Country: ar
« Reply #4784 on: October 27, 2023, 06:29:03 pm »
Yes, I already did that and it still shows me the version I had, it doesn't install the new one, I also thought it was just that the number had not been changed, but I checked the menus and other things to see if there were any changes.
spanish
si ya hice eso y me sigue mostrando la version que tenia, no instala la nueva, ademas pense que era solo que no se habia modificado el numero, pero revise menues y troas cosas para ver si habia algun cambio.
Offline mqsaharan
  • Country: pk
« Reply #4785 on: October 28, 2023, 04:31:59 am »
The latest firmware was installed on my DS1054Z without any problem. I purchased mine back in 2016.
I guess when Rigol hire new interns, they give them the bug list of these old scopes to work on. Perhaps that is why we are still seeing new updates with small fixes.
Offline Adrian_Arg.
  • Country: ar
« Reply #4786 on: October 28, 2023, 05:36:12 pm »
After a lot of struggle it was updated, they added an option or rather changed the vertical menu now it is AC vrms, but it has a button left with option 3, which when you press it is period, but well it can't always be perfect
in spanish
después de mucho batallar se actualizo, agragaron una opcion o mas bien cambiaron en el menu vertical ahora es AC vrms, pero le quedo un boton con la opcion 3, que cuando uno lo preciona es periodo, pero bueno no siempre puede ser perfecto
Offline rob040
« Reply #4787 on: October 28, 2023, 06:05:04 pm »
@Adrian_Arg.: The AC Vrms was already implemented one update earlier, see the posts from mid-September.
But what caused the struggle to update your ‘scope?
« Last Edit: October 29, 2023, 01:41:41 pm by rob040 »
Offline Adrian_Arg.
  • Country: ar
« Reply #4788 on: October 28, 2023, 11:02:29 pm »
But was caused the struggle to update your ‘scope?
I used a 1 GB pen and it worked, the strange thing is that it doesn't record images now
PD  The solution is with some pendrives, so I already marked the crafty ones
« Last Edit: October 28, 2023, 11:14:43 pm by Adrian_Arg. »
The following users thanked this post: rob040
Offline madires
  • A qualified hobbyist ;)
« Reply #4789 on: October 29, 2023, 12:57:53 pm »
2GB limit?
Offline Adrian_Arg.
  • Country: ar
« Reply #4790 on: October 29, 2023, 02:35:01 pm »
2GB limit?
I am now using a Kingston pendrive of 16GB (14.8) capacity formatted to fat 32, and it works perfectly, it must be about 10 years old, it is one of the first of that capacity that I bought
in spanish
yo ahora estoy usando un pendrive kingston de 16gb(14.8) de capacidad formateado a fat 32, y funciona perfecto,  debe tener como 10 años es de los primeros de esa capacidad que compre
https://imagefullhost.com/images/2023/10/29/pendrive.jpeg
Offline perieanuo
« Reply #4791 on: October 30, 2023, 06:15:38 am »
This also works, I struggle with my coworkers to tell them they don't need to deal with usb sticks or anything and use ethernet, galvanic isolation does miracles;
« Last Edit: October 30, 2023, 06:20:20 am by perieanuo »
Offline jwc
« Reply #4792 on: April 08, 2024, 02:39:55 pm »
Just chiming in to say that hacked options persist as of firmware version 00.04.05.02.04 (aka 00.04.05.SP2) [build date 2023-02-27].
Presumably this means riglol still works too.
Offline s8548a
  • Country: in
« Reply #4793 on: July 27, 2024, 06:15:59 pm »
My scope was in packed condition when returned from work for couple of years, and this week took it out to place it in my new desk at home.
Power up was ok, test waveform measured on channels found ok.
then headed to rigol website https://int.rigol.com/products/detail/DS1000Z to check for any updated firmware, and updated to DS1000Z Firmware v00.04.05.02.07
not sure what got improved, but I couldn't  resist   :-//
Offline rob040
« Reply #4794 on: July 27, 2024, 06:36:39 pm »
Well, one version later was already announced in Reply #4770 (October 24, 2023, 10:21:50 pm):
v00.04.05.02.08
To be honest, I haven't tried it yet...
The following users thanked this post: s8548a
Offline ToThePub
« Reply #4795 on: July 27, 2024, 11:31:46 pm »
Even though the website says it's 00.04.05.02.07, if you download it, it's actually 00.04.05.02.08
[Supported Model]    All the MSO/DS1000Z Series Digital Oscilloscopes
[Latest Revision Date]  2023/07/6
[Updated Contents]
v00.04.05.02.08  2023/08/21
    -made some optimizations.
[History]
v00.04.05.02.07  2023/07/06
     -Optimized the startup problem of the previous version
v00.04.05.02.06  2023/06/30
     -Solve the problem that some machines cannot be started after being left for a long time
Offline Adrian_Arg.
  • Country: ar
« Reply #4796 on: July 28, 2024, 05:31:03 pm »
It would be nice to know what the optimizations were?
[Updated Contents]
Offline ToThePub
« Reply #4797 on: July 30, 2024, 05:09:21 am »
We'll never know I'm guessing.
Offline Adrian_Arg.
  • Country: ar
« Reply #4798 on: July 30, 2024, 10:17:53 pm »
Has anyone already installed this firmware version?
Offline szpila
« Reply #4799 on: July 31, 2024, 11:08:55 am »
Yes, everything works. Calibration passed.
The following users thanked this post: fpliuzzi
