Author Topic: New Rigol DS1054Z oscilloscope  (Read 2067763 times)
0 Members and 11 Guests are viewing this topic.
Offline David Hess
  • DavidH
Re: New Rigol DS1054Z oscilloscope
« Reply #3075 on: October 22, 2016, 09:49:14 pm »
Indeed, that circuit not only that it has horrible ringing and ugly asymmetric transient response, but it also has 500 ps only for the falling edge. The rising edge is about 2 ns, nothing spectacular.  |O
Only one clean and fast edge, rising or falling, is needed to test transient response (unless the oscilloscope has asymmetrical response which can happen but indicates a major problem) and most reference level pulse generators are only designed to create one clean and fast edge polarity at a time.  The PG506 has separate outputs for positive and negative edges.
The CMOS output can be cleaned up by using either an open drain output (tri-state output for fast logic like LVC) with an external pull-up or pull-down resistor acting as a shunt termination or a fast low capacitance diode or cascode transistor can be used to disconnect a totem-pole CMOS output from the shunt termination.  The later is how the old NBS (National Bureau of Standards) design works which is duplicated by the PG506.
Online Fungus
« Reply #3076 on: October 23, 2016, 07:41:19 am »
Curiosity: What's the rise time produced a simple mechanical switch with very short wires?  :popcorn:
Offline David Hess
  • DavidH
« Reply #3077 on: October 23, 2016, 09:05:26 am »
The coaxial mercury relay in the Tektronix Type 109 has a rise time of 250 picoseconds.  It would be fun to test a mercury reed switch mounted coaxially inside of a brass tube or as part of a coplanar waveguide to see what kind of performance could be achieved.
The transition time is not easy to measure because of the low repetition rate and because while a sequential sampling oscilloscope would have the bandwidth, it would also need a delay line to produce a pretrigger.  That leaves using a rare random sampling oscilloscope or a modern expensive high bandwidth DSO.  On the other hand if well constructed, it should work great for testing 500 MHz and slower DSOs.
I know of someone who was working on something like this for high voltage pulse generation and with my random sampling oscilloscope, it took like 30 minutes to accumulate enough points to display the waveform.
Update: The forum software is dumb.  How do you *not* embed a hyperlink?  It is doing it automatically and I just want the link.
« Last Edit: October 23, 2016, 09:31:24 pm by David Hess »
Offline BravoV
  • +++ ATH1
« Reply #3078 on: October 23, 2016, 11:55:24 am »
Guys ... as contribution back to this community, look what I got there, the free DS1104Z-S vs my friend's DS1054Z that I helped him to procure it while ago. All this time I borrowed that DS1054Z a lot as I helped him in the "upgrade" it too, now he really hates me once he knew I have DS1104Z-S.  :-DD
Tell me what you need, and please, don't ask me to do teardown comparison, as the DS1054Z is brand new and still within warranty.
I can't promise though on the timeline, what I have in mind is to do head to head comparison at the 50Mhz to 100Mhz hack. Or any idea please just ask, I will consider it.
PS : Is it better to make this comparison at separate thread ? or just put them in this giant overcrowded thread ?
« Last Edit: October 24, 2016, 01:56:46 am by BravoV »
Offline yngndrw
« Reply #3079 on: October 23, 2016, 12:08:56 pm »
Guys ... as contribution back to this community, look what I got there, the free DS1104Z vs my friend's DS1054Z that I helped him to procure it while ago. All this time I borrowed that DS1054Z a lot as I helped him in the "upgrade" it too, now he really hates me once he knew I have DS1104Z.  :-DD
The DS1104Z looks to have another "source" button on the front, I thought they were meant to be exactly the same apart from the bandwidth ?
Edit: On the UK Rigol site, the DS1054Z also has the extra "source" button so maybe it's a new addition: https://www.rigol-uk.co.uk/Rigol-DS1054Z-Digital-Oscilloscope-p/ds1054z.htm
The DS1***Z Plus on the site also has the source button in addition to a "LA" button just above it.
« Last Edit: October 23, 2016, 12:11:25 pm by yngndrw »
Online 2N3055
  • Country: hr
« Reply #3080 on: October 23, 2016, 12:35:05 pm »
That is a signal source button...
That probably means that DS1xxxZ-Plus is full MSO with digital not enabled, and that new DS1xxx(non plus) is actually DS1xxxZ-S that  has AWG hardware built in but it is not enabled....
That would be my guess.
« Last Edit: October 23, 2016, 12:37:12 pm by 2N3055 »
Online Fungus
« Reply #3081 on: October 23, 2016, 07:43:02 pm »
Technically it's exactly the same device.
(Although you appear to have option for signal generator on yours...)
The hack can be applied/removed at will.
The easiest way is to connect to the scope via telnet port 5555. All you need is an Ethernet cable.
You switch between 50/100Mhz with a single command.
// Remove all options
:SYSTem:OPTion:UNINSTall
// Install an option
:SYSTem:OPTion:INSTall RDxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Where xxxxxxxxxxxxx is a code generated by Riglol
A separate thread might be good.
Offline bitseeker
« Reply #3082 on: October 23, 2016, 08:54:55 pm »
The page says DS1054Z, but the photo is of a DS1104Z.
Offline yngndrw
« Reply #3083 on: October 24, 2016, 12:19:48 am »
Good spot ! That explains that - They must have just used a stock photo.
« Last Edit: October 24, 2016, 02:01:51 am by yngndrw »
Offline BravoV
  • +++ ATH1
« Reply #3084 on: October 24, 2016, 01:58:17 am »
My mistake, its DS1104Z-S , its the one that has AWG.
Watch the two white symbols (sin & square wave buttons) at the lower right of the screen.
« Last Edit: October 24, 2016, 02:07:09 am by BravoV »
Offline metrologist
« Reply #3085 on: October 24, 2016, 05:39:25 am »
I shortened up my leads and went to a much larger cap, 50 ohm input terminated. A little cleaner setup and some exercising the switch seems to have improved repeatability.
Online Fungus
« Reply #3086 on: October 24, 2016, 05:50:24 am »
I'd go for lots of small caps in parallel. The idea is to reduce ESR/ESI.
(lots of larger caps in parallel works too)
Online Fungus
« Reply #3087 on: October 24, 2016, 05:53:35 am »
Here's a question: Does anybody know if a genuine DS1104Z can be downgraded to a DS1054Z by doing a ":SYSTem:OPTion:UNINSTall"?
I imagine it can, I was just wondering.  :popcorn:
The following users thanked this post: quetzalcoatl
Offline BravoV
  • +++ ATH1
« Reply #3088 on: October 24, 2016, 05:59:43 am »
Noted ... will be in my test list.  >:D
Offline metrologist
« Reply #3089 on: October 24, 2016, 03:35:29 pm »
Thanks!
I also found the trigger output routed to CH2 through a short 50? terminated BNC interesting. A trigger event on CH1 produced a relatively fast edge (1.9 ns rt)  on the trigger output, after some delay (which seemed like a lot).
Online JPortici
« Reply #3090 on: October 24, 2016, 07:14:06 pm »
"Trail" :palm:
i tried too with the trigger output going into terminated coax, a bit slower than yours
Online Fungus
« Reply #3091 on: October 24, 2016, 07:39:57 pm »
Thanks!
Ceramic caps of course... for fastest response.
And cut the legs as short as possible.
Offline IAmBack
« Reply #3092 on: October 24, 2016, 09:18:32 pm »
Our hero' firmware download link vanished from the following page:
http://int.rigol.com/Support/SoftDownload/3
Weird...
Offline RoGeorge
« Reply #3093 on: October 24, 2016, 10:32:57 pm »
The following link seems to always point to the latest version of DS1000Z firmware:
http://beyondmeasure.rigoltech.com/acton/fs/blocks/showLandingPage/a/1579/p/p-0019/t/page/fm/0
Offline metrologist
« Reply #3094 on: October 25, 2016, 05:19:48 am »
What is the expected external trigger signal delay? I'm getting 350 ns. I have not seen specs on the ext trigger output, nor signal levels...
I bumped up the memory depth and forced a trigger - external trigger routed to CH1 input through 50 ohm termination (and I forgot to change to 1X).  :-// Maybe someone can verify the trigger output on a nicer scope?
« Last Edit: October 25, 2016, 05:22:05 am by metrologist »
Offline David Hess
  • DavidH
« Reply #3095 on: October 25, 2016, 07:27:15 am »
The delay for the trigger output is high compared to an oscilloscope with an analog trigger simply because triggering happens after the pipelined digitizer and time has to be spent doing digital signal processing to qualify the trigger even if it is a simple edge trigger.  The trigger output also has considerable trigger jitter caused by the granularity of the DSP clock cycle.
Offline yngndrw
« Reply #3096 on: October 25, 2016, 07:14:16 pm »
The HMCAD1511 ADC used in these scopes has a pipeline delay of 128ns on its own, so 350ns doesn't sound unreasonable:
http://www.analog.com/media/en/technical-documentation/data-sheets/hmcad1511.pdf
(See page 5, the pipeline delay in single channel mode is 128 clock cycles at 1GHz. In quad channel mode it's 32 cycles, but presumably that is at 250MHz and therefore the same time period.)
Offline mmprestine
« Reply #3097 on: October 27, 2016, 08:44:05 pm »
Anyone running the current v00.04.04.01.01  2016/09/14 firmware?  I updated today from an older 4.03...something and now I get random reboots and lockups.
Offline RoGeorge
« Reply #3098 on: October 27, 2016, 09:07:55 pm »
None of these so far, board version 0.1.1. The FW was updated this months with the version 00.04.04.01.01 from 2016/09/14, but didn't used it more then 10-20 hours yet.
How often does the reboot/lockup happen?
« Last Edit: October 27, 2016, 09:09:47 pm by RoGeorge »
Offline yngndrw
« Reply #3099 on: October 27, 2016, 09:24:05 pm »
I'm running v00.04.04.SP1 which should be the latest (Brand new scope, was updated and dispatched by Telonic on Tuesday) on board version 0.1.4 and haven't seen any lock-ups or reboots - Not that I've been using it for very long.
This version is listed as the latest as of the 24th of Oct, so might want to try this:
http://www.rigol-uk.co.uk/Get-the-latest-RIGOL-firmware-p/firmtest.htm
« Last Edit: October 27, 2016, 09:26:05 pm by yngndrw »
