Author Topic: New Rigol DS1054Z oscilloscope  (Read 1570888 times)
Offline egonotto
Re: New Rigol DS1054Z oscilloscope
« Reply #1650 on: August 21, 2015, 08:12:54 pm »
" analog scope with 400 MHz bw that will do FFT"
how schould an analog scope do FFT?
Offline MT
  • Country: cn
« Reply #1651 on: August 21, 2015, 08:22:47 pm »
alsetalokin4017
Well.... if you can find a 4-channel secondhand analog scope with 400 MHz bw that will do FFT, Frequency counting, pulse width and screendumps for 400 dollars, and comes with 4 probes... buy it, by all means!
I actually was about to do (old 1Ghz Lecroy for 300usd) but got distracted by Daves used-care-salesman approach in the end of the 1054z video! :)
Otherwise, get a Rigol 1054z, unlock it to 100 MHz and just don't use the features you don't want. Do you really need 400 MHz bandwidth, on your budget?
The hack is great dont get me wrong on this but that is not part of my scope request, 500Mhz is also fine as well as 1Ghz etc.
For instance i could tomorrow order a Rigol DS6102 for 7620 usd from my local supplier, but why on earth would i spend such a fortune just to look at high speed signals?
Is there a scope like box where i can attach a old PC screen to display the measured 477Mhz wave? Basically i dont need an oscope in traditional sense if you get my hint!
I need a Ghetto style high speed wave display! :)
« Last Edit: August 21, 2015, 08:31:41 pm by MT »
Offline quantalume
« Reply #1652 on: August 21, 2015, 09:14:47 pm »
Is there some kind of scope that acts differently? Don't we all do just exactly this when we are looking at a waveform for the first time?
All analog scopes and the early digital scopes I remember used the left side of the screen as the trigger origin, unless you've explicitly set a delay.  To be honest, I don't have a lot of experience with modern DSOs.  I suppose my way of thinking is still rooted in the old analog storage paradigm, where you wouldn't want to throw away half of the screen.
Offline Stupid Beard
« Reply #1653 on: August 21, 2015, 09:27:19 pm »
I was about to buy a 1054z but sadly to say i had a second thought because i come across the 1054 bug and wish list and the fact the input bandwith is dived among the channels
Either you are using the wrong terminology or you're getting mixed up with the difference between sample rate and bandwidth. All 4 channels always have 100mhz of bandwidth (or 70, or 50 depending on model). It is the sample rate that gets divided and that happens only if you have the extra channels enabled.
Offline vk6zgo
« Reply #1654 on: August 22, 2015, 03:55:14 am »
A Tek 7000 series mainframe with a 7L12 Spectrum Analyser plugin could do better than an FFT.
Of course,you couldn't send it to a PC,or save it,other than with a digital camera.
You could probably get a 7000 series mainframe which could do the 400MHz as a normal 'scope,too!
Offline alsetalokin4017
« Reply #1655 on: August 22, 2015, 04:15:47 am »
My point exactly, since the OP said,
What i need is scope that do example 400Mhz, FFT, freq counting,PW and and who can do screen dumps in a suitable bitmap format for similarly amount of money and that's about it. I dont have the time or patience to read all the million posts about different scopes but with my requirements i'm i stuck with old secondhand analogs market or is there something new like this around?
Yes, that's what I thought he meant. Thanks for correcting.
« Reply #1656 on: August 22, 2015, 04:21:09 am »
alsetalokin4017
Well, if that is really your requirement I have to wonder why you posted in the "Re: New Rigol DS1045z oscilloscope" thread ! Are you doing the "wind-up" by chance?
 >:D
Get that old LeCroy for 300 dollars, then! And of course you will need at least one probe with 500 MHz bandwidth, if you care about precision in the displayed waveform! Good luck with that!
« Last Edit: August 22, 2015, 04:22:48 am by alsetalokin4017 »
Offline ankerwolf
  • Country: at
New Rigol DS1054Z oscilloscope - frequency response
« Reply #1657 on: August 29, 2015, 08:02:13 pm »
Hello,
I have measured the frequency response. You can clearly see the differences.
The Tektronix oscilloscopes have a steeper drop. The Rigol DS1054Z is much flatter, also in the 100MHz option.
LG Wolf
Offline SaabFAN
« Reply #1658 on: August 29, 2015, 08:32:01 pm »
alsetalokin4017
If your waveform is repetitive, you should consider scopes from the late 80s and early 90s. They had relatively low real time sampling, but with random sampling an equivalent sampling of several GS/s. Also the analog inputs were quite powerful back then and had smooth frequency response instead of the brickwall-like in more modern ones.
The Lecroy you mentioned is such a device. The HP-Units from that time-period should be able to do the job as well. These scopes also most likely have RS232 installed as standard, so you can extract the data via the serial-port and perform FFT-Calculations in excel or Matlab or whatever program you're using, like it is described here: https://www.eevblog.com/forum/repair/repairing-an-old-pm3320a/75/
If you have the equipment available to characterize the frequency-response of the analog inputs, I think you can also use lower spec units like the PM3394 or even the PM3384 and reconstruct the real nature of the signal afterwards in Software. PM3394 Scopes also have the advantage to switch into analog-mode.
Offline Lightages
  • Canadian po
« Reply #1659 on: August 29, 2015, 09:48:43 pm »
Thanks for any info and your time regarding this!
This is a thread about the DSS1054Z. You don't have time nor patience to read and understand all the information other have taken the time to provide? So now you want everyone to change the discussion, and talk about things that aren't a DS1054Z and jump to your commands to give you help on your terms?
Why not start another thread about what YOU want to talk about. Why be like most people on the internet and pollute threads with off topic posts?
Offline MT
  • Country: cn
« Reply #1660 on: August 30, 2015, 01:47:18 am »
NOTE: This message has been deleted by the forum moderator Simon for being against the forum rules and/or at the discretion of the moderator as being in the best interests of the forum community and the nature of the thread.
If you believe this to be in error, please contact the moderator involved.
An optional additional explanation is:
« Last Edit: August 30, 2015, 10:09:30 am by Simon »
Offline TorqueRanger
« Reply #1661 on: September 05, 2015, 02:47:14 am »
Does anyone know what is latest firmware update and can I get it without registering ???
My plan was to update to the latest software and upgrade to DS1104Z.. Have you guys had any problems with the updates and the upgrade hack  or any other kind of issues ???
My specs
Spec- DS1054Z
Software-00.04.03
Board-0.1.1
Thanks
Offline MarkF
« Reply #1662 on: September 05, 2015, 03:27:50 am »
Version 00.04.03.SP1 is the latest.  Disregard the zip filename and see the directory name inside.
And Firmware Release Notes.
« Last Edit: September 05, 2015, 03:33:43 am by MarkF »
« Reply #1663 on: September 11, 2015, 02:05:05 am »
Thanks for the info ..
I am sorry I had to ask but the manual said to use Rigol.com but the website doesn't have the DS1054Z listed but if I used the http://www.rigolna.com webiste then it has all the information but I was sure how valid the website was since the manual said to use the Rigol.com site ..Also I am starting to learn Electronics and I was if it was in best interest to do the upgrade or am I better off sticking with stock setting ???? How much do you lose after the trial upgrade is done ??
Offline MarkF
« Reply #1664 on: September 11, 2015, 05:21:38 am »
www.rigolna.com is the official Rigol North America site.  Not the main China site.
As far as upgrades...  The bandwidth and memory depth are the most important for me.  The extra triggers and decoders I've used to a lesser degree.  If you're going to upgrade, do them all and be done with it.  Use DSER.  Do NOT enable the 500uV/div option as it doesn't work properly.
« Last Edit: September 11, 2015, 05:29:13 am by MarkF »
« Reply #1665 on: September 11, 2015, 07:02:13 pm »
Is it DSER or DSFR cause there is not listing for the DSER and everyone keeps saying it but no listing using the link below.
http://gotroot.ca/rigol/riglol/
Offline Lightages
  • Canadian po
« Reply #1666 on: September 11, 2015, 07:46:48 pm »
Everyone keeps saying DESR because that is what you should use. USE DSER NOT DSFR!!!!!
Offline GonzoTheGreat
  • Country: aq
« Reply #1667 on: September 11, 2015, 08:07:27 pm »
Does pt.7 in the Release Notes mean that Rigol has repaired the zoom freeze bug ?
pt.7:
In scanning  mode,turned  on  the Zoom  display  and setted the AC as the trigger  coupling,then  adjusted  the timebase  of  Zoom  zone  and  the waveform  display  error.
Offline bitseeker
« Reply #1668 on: September 11, 2015, 09:49:32 pm »
It's DSER. The list of codes hasn't been updated in quite some time. You do not want to enable all options because 500uV is not supported on 1054z. So type in DSER and you'll be all set.
Handy Mnemonics:
E: Everything that works
F: F***s the scope
« Last Edit: September 11, 2015, 09:54:04 pm by bitseeker »
I TEA.
« Reply #1669 on: September 11, 2015, 11:15:32 pm »
That's right. But what is confusing some people is probably that the DSER  code is _undocumented_ in the Riglol keygen. It's not listed as an option... but it works anyway.
« Reply #1670 on: September 11, 2015, 11:22:31 pm »
pt.7:
Unfortunately... no. The scopes that have the bug will still freeze when Mem Depth is 'Auto', Persistence set to 100ms or greater, and Horizontal Zoom (aka Delayed) mode is entered. Or at least mine still does, anyway, running 00.04.03.SP1.
A Rigol tech told me that there is supposed to be a new firmware version coming in October. Will it fix the issue? Let's hope so.
  • Country: aq
« Reply #1671 on: September 11, 2015, 11:43:45 pm »
What about the Math channel bug?
Offline MarkF
« Reply #1672 on: September 12, 2015, 02:42:01 am »
Maybe this will finally alleviate the code questions.  It's from the Re: Sniffing the Rigol's internal I2C bus thread.
Just because a code is not listed on the Riglol keygen, doesn't mean you can't use it!
Maybe some one knows how to get DSER added to the Riglol keygen list.
Here is the bit representation for the DS1000Z hack code:
The first column is always 'D' and the second column is always 'S'.
DS1000Z ECC private key: 0x6F1106DDA994DA
DSAB - 00011 10000 00000 00001 - Advanced Triggers
DSAC - 00011 10000 00000 00010 - Decoders
DSAE - 00011 10000 00000 00100 - 24M Memory
DSAJ - 00011 10000 00000 01000 - Recorder
DSBA - 00011 10000 00001 00000 - 500uV Vertical      DO NOT USE!
DSEA - 00011 10000 00100 00000 - 100MHz
DSFR - 00011 10000 00101 01111 - All options           DO NOT USE!
DSER - 00011 10000 00100 01111 - All options except 500uV/div      USE THIS CODE!!!
The binary value assigned to each letter:
A = 00000     J = 01000     S = 10000     2 = 11000
B = 00001     K = 01001     T = 10001     3 = 11001
C = 00010     L = 01010     U = 10010     4 = 11010
D = 00011     M = 01011     V = 10011     5 = 11011
E = 00100     N = 01100     W = 10100     6 = 11100
F = 00101     P = 01101     X = 10101     7 = 11101
G = 00110     Q = 01110     Y = 10110     8 = 11110
H = 00111     R = 01111     Z = 10111     9 = 11111
« Last Edit: September 12, 2015, 03:41:16 am by MarkF »
The following users thanked this post: BravoV, Marcos, freebil
Offline timofonic
  • Eternal Wannabe Geek
« Reply #1673 on: September 12, 2015, 04:09:48 am »
Is 500uV/div a hardware limitation? Can't it be hacked too?
Offline Lightages
  • Canadian po
« Reply #1674 on: September 12, 2015, 04:27:35 am »
Yes, and no.  :)
