Author Topic: New Rigol DS1054Z oscilloscope  (Read 1542867 times)
Offline alsetalokin4017
Re: New Rigol DS1054Z oscilloscope
« Reply #1775 on: October 22, 2015, 02:50:23 pm »
The response to USB sticks can be very variable. Sometimes you'll get the "Disabled some operations" message and the scope will seem to freeze (progress bar stalls) for a couple or three minutes even before it finishes. For saving screenshots to USB, especially with several channels operating, I've found it generally goes a lot faster if you STOP the scope with the Run/Stop button before pressing the "print" button.
I'm generally using an 8GB FAT32 stick with lots of folders and files already on it.
Online bitseeker
« Reply #1776 on: October 22, 2015, 03:57:05 pm »
It is recommended that the capacity of the USB storage device being used with this oscilloscope is no larger than 8 GBytes.
There's no reason at all the disk size would make a difference, it's just numbers.
Cluster sizes? Sure - buffer overruns and all that.
Not total disk size though.
Size does make a difference, but indirectly. It affects the default cluster size that's used on the storage medium. The documentation, however, was written for non-technical people (i.e., obscure the details), which makes life more difficult for technical folks, unfortunately.
Of course, putting the actual storage specifications in the specs section of the docs would have been nice.
I TEA.
Offline fvera
« Reply #1777 on: October 23, 2015, 10:49:13 pm »
Looking to place an order, could someone kindly PM the coupon code.
Regards,
Fernando
Offline Fennec
« Reply #1778 on: October 24, 2015, 12:37:08 am »
@alsetalokin4017
Thx for the files. Now I could reproduce all your issues. Exactly the same. Based on your topic https://www.eevblog.com/forum/testgear/new-rigol-ds1054z-oscilloscope/msg781316/#msg781316
The trigger issus I have with timebase set to 50µs only. Math and zoom is the 120k (120k only) / HighRes bug. See the pix.
« Last Edit: October 24, 2015, 12:46:30 am by Fennec »
Offline rosbuitre
  • Country: ar
« Reply #1779 on: October 27, 2015, 09:12:41 am »
New firmware received by mail from RIGOL
Regards
My instruments: DMM Keysight 34461A / Tektronix DMM916 / Fluke 12, Rigol DS1074Z, Deer DE-5000, Siglent SDG805 / SDP3303D, Dayton Dats2
Offline hayatepilot
« Reply #1780 on: October 27, 2015, 10:54:37 am »
@rosbuitre
Nice!
Did you notice any changes/improvements?
Were any of the bugs fixed?
Greetings
Offline crispy_tofu
« Reply #1781 on: October 27, 2015, 10:59:14 am »
@rosbuitre
Nice!
Greetings
+1, I would also like to know.  :-+
Offline rosbuitre
  • Country: ar
« Reply #1782 on: October 27, 2015, 12:13:28 pm »
@rosbuitre
Nice!
Greetings
Hi
I had no time to try it, only just install
Regards
Offline f1rmb
« Reply #1783 on: October 27, 2015, 02:04:15 pm »
Regards
Do you mind to share ?. I just checked the rigol's website, and only previous version is listed.
Cheers.
Daniel
Offline rosbuitre
  • Country: ar
« Reply #1784 on: October 27, 2015, 02:53:50 pm »
Regards
Cheers.
Daniel
Shared, please confirm if they can download.
Following the instructions I could not install, recognizes new version when you insert the pen drive.
https://drive.google.com/file/d/0B6F_CSCAsnsoS0dtQ3BLNV9yUTg/view?usp=sharing
https://drive.google.com/file/d/0B6F_CSCAsnsoZjFyRmdkVUQzZ3M/view?usp=sharing
Regards
Offline f1rmb
« Reply #1785 on: October 27, 2015, 03:21:33 pm »
Regards
Cheers.
Daniel
Regards
Many thanks, I'll upgrade in a few minutes. BTW, the update procedure in the document from the second sharing URL is wrong. AFAIK there is no bootloader in DS1000Z, so the help button have no action on startup.
Cheers.
Daniel
Online bitseeker
« Reply #1786 on: October 27, 2015, 04:45:35 pm »
Correct. Just plug in the USB drive with the file in the root directory and the scope will prompt to install it.
I TEA.
Offline f1rmb
« Reply #1787 on: October 27, 2015, 05:03:27 pm »
Okay, just flashed, reset to default, autocal, and the freezing bug looks still there :-(
Cheers
Daniel
Offline Fennec
« Reply #1788 on: October 27, 2015, 07:32:14 pm »
Did a quick check.
Freeze bug does'nt fixed
Math issue does'nt fixed
50µs timebase / trigger issue seems to be fixed... Iam not sure, maybe someone else can check it too.
BUT
I feel the whole scope is much slower.
The probe devider setting is a procedure like hell now. Pain in the ass. Useless < My knob is broken
If I turn on all 4 channels and the brightness changes with the memory settings. The channels are flickering now.
I play a little with this firmware and change back to SP1 that's for sure.
/Edited
« Last Edit: October 27, 2015, 08:10:04 pm by Fennec »
Offline strimarc
« Reply #1789 on: October 27, 2015, 08:12:56 pm »
I'm looking to buy a new DS1054z..  Can someone give me the discount code eevblog members?  Thanks in advance.
Online bitseeker
« Reply #1790 on: October 27, 2015, 09:48:48 pm »
No code needed. Just use the online chat.
I TEA.
Offline ankerwolf
  • Country: at
« Reply #1791 on: October 27, 2015, 11:16:30 pm »
Yes, many German incorrect translations which I had reported.
Offline MarkF
« Reply #1792 on: October 28, 2015, 12:40:59 am »
PM sent.
« Reply #1793 on: October 28, 2015, 03:47:16 pm »
Well, that's interesting. I reported the FreezeBug to Rigol when I found it, and was assigned a number and was told there would be a new firmware in October. I get notifications of sales and equipment from Rigol but I have heard _nothing_ from them about this new firmware.
And it seems like it is causing problems and doesn't actually fix the important stuff like the freeze bug and the math horizontal error.
So I downloaded it from rosbuitre's link but I'm not going to install it just yet, due to the reports of slowing, flickering, not fixing the bugs, etc.
What is the matter with Rigol? It seems like they are really dropping the ball on this one. The "firmware" needs a complete rewrite, I think.
Offline JohnPen
« Reply #1794 on: October 28, 2015, 05:00:46 pm »
I have noted that Rigol UK is saying the latest s/w--f/w is now 00.04.03.SP2 so I have downloaded from the link provided by rosbuitre but not proceeded any further yet.  Maybe try it tomorrow.
John
Offline ankerwolf
  • Country: at
« Reply #1795 on: October 28, 2015, 07:31:21 pm »
My first quick check with the new Update 00.04.03.SP2:
No Trigger Bug more - all ok ;D
« Last Edit: October 28, 2015, 11:34:11 pm by ankerwolf »
Offline JohnPen
« Reply #1796 on: October 28, 2015, 08:08:45 pm »
Freeze bug is just the same with this new firmware. UGH!
John
Offline nanofrog
« Reply #1797 on: October 28, 2015, 09:10:58 pm »
My first quick check with the new Update:
Has the UI become sluggish with this newest release?
Offline ankerwolf
  • Country: at
« Reply #1798 on: October 28, 2015, 11:06:11 pm »
Hello,
no Zoom Bug more (00.04.03.SP2) - look
« Last Edit: October 28, 2015, 11:34:32 pm by ankerwolf »
Offline ankerwolf
  • Country: at
« Reply #1799 on: October 28, 2015, 11:32:33 pm »
Hello,
with 00.04.03.SP2
1) now I can't see the Math bug - can anyone check it too (what procedure?)
2) Math & Zoom lookes good, BUT LAN FREEZING !!! (more check needed)
3) now: NO !!  Freeze bug as shown here
« Last Edit: October 28, 2015, 11:39:10 pm by ankerwolf »
