Author Topic: New Rigol DS7000  (Read 55598 times)
Offline mindy
Re: New Rigol DS7000
« Reply #200 on: February 10, 2019, 12:34:34 pm »
Hello,
So far I'm happy with MSO7k performance & functionality, but I'm a bit concerned of my device calibration and wondering is this something what can be fixed by a Firmware upgrade or I should be filling a warranty card for my brand new scope :(
I'm unable to get a perfectly flat 1k square with included passive probes RP3500A, I'm getting a small dip at the beginning of each wave.
Can this be a source of a small overshoot observed on a signal generator?
When I tried a DIY 1k probe on a 50 \$\Omega\$ input with 1:20 attenuation I got a perfectly flat square wave.
Does anyone have a similar experience or can suggest if it's still in a acceptable error margin or should I be concerned and send it for a repair?
BTW tried to re-calibrate multiple times but this does not helped
« Last Edit: February 10, 2019, 07:29:15 pm by mindy »
Online Fungus
« Reply #201 on: February 10, 2019, 11:15:40 pm »
I'd say that was due to the probing technique, nothing to do with the 'scope.
What does a piece of 50 Ohm terminated coax cable give you?
No.
Offline mindy
« Reply #202 on: February 11, 2019, 10:55:33 am »
I've tried to use a spring for my probe ground to minimise signal ringing on measuring signal from my integrated AWG what made little to none effect.
I saw very similar result (overshoot) on a different (external) signal source as well.
But the most important is a compensation 1k square wave which clearly shows a dip and can not be fully compensated.
This should eliminate an inductive loading from the equation as compensation signal ground is connected internally.
Obviously I'm not going to solder my probe tip to compensation clip for a better contact, but I did my best to make sure that it has a good contact.
Any further tips to try before concluding that either Probe OR Scope is defective?
As I mentioned I tried a quick test (1k 0.25W resistor directly connected to compensation signal & Channel 1) and I got a perfectly flat square wave. Then I'll have more time I'll make a bit more robust probe with compensation and parasitics taking into account. Differential probe would do even better. But my concern right now is about 1M ohm range / included Probes quality.
Offline nctnico
« Reply #203 on: February 11, 2019, 12:09:13 pm »
You can try a coax cable and a 50 Ohm feed-through terminator. A 1M input usually has various frequency cross-over points which need to be adjusted. Perhaps you are seeing the crossover between the LF and HF path of the 1M input. The 50 Ohm input path may be entirely different.
Offline KlausF
« Reply #204 on: February 11, 2019, 01:08:11 pm »
Nice device, but imho way too expensive, regrettably.
Online Fungus
« Reply #205 on: February 18, 2019, 12:41:49 pm »
This is most likely a product of a Chinese company.
Yes, it's labelled on the front, "Rigol"
https://en.wikipedia.org/wiki/RIGOL_Technologies
Offline Karel
« Reply #206 on: February 18, 2019, 01:58:40 pm »
Offline swansonbroth
« Reply #207 on: May 16, 2019, 06:21:25 am »
Hi there,
is there a way to get all the options and a bandwith upgrade up to 500 MHz for my DS7014 over a GEL File?
Offline tv84
  • Country: pt
« Reply #208 on: May 16, 2019, 08:55:13 am »
Use the same method as in the MSO5000 thread. Just need to craft the correct 7000 patch.
The following users thanked this post: swperk
« Reply #209 on: May 16, 2019, 09:06:09 am »
@tv84
did you have a workaround or how is the procedure?
Offline tv84
  • Country: pt
« Reply #210 on: May 16, 2019, 12:48:49 pm »
I didn't do any patch for the 7000. If anyone wants to create the patch, I can provide the bytes to be changed.
Offline wat
« Reply #211 on: May 18, 2019, 04:47:25 pm »
Hello all,
something similar to the previous post, but not necessarily locking it to a GEL file: what's the best way to enhance ;) a MSO7014? (FW 00.01.01.07.01)
I read the "Hacking the MSO5000" forum, all of it.
Now, having the ssh enabled (root/root), I would think the -fullopt should be easiest way, and I can see in the "start.sh", line 82, the flamingo app being launched:
/rigol/flamingo_console $PowerOn  -wpu_compress &
shall I just add the -fullopt there? Will it work?
Otherwise I don't think I have enough experience to create a GEL file myself to patch the app,
but I'll be happy to move on another forum ("Hacking the 7000"?) and provide assistance to someone more capable and create a tutorial for it.
Thanks
Online rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #212 on: May 19, 2019, 10:11:34 pm »
Sell it and buy a used DSOX3014? :-DD
(Sorry, I really couldn't resist the opportunity or, as we say in my home country: we lose the friend but don't lose the joke)
Offline KlausF
« Reply #213 on: June 08, 2019, 10:17:58 pm »
Too tired for reading so much. Waiting for a video review.
Offline tv84
  • Country: pt
« Reply #214 on: August 20, 2019, 08:27:52 pm »
Just tested:
A fresh fully licensed MSO7000 with the latest v00.01.01.09.02 FW doesn't show any sign of working with the JITTER/EYE options!!
What a mega bummer!!!  :palm:  :palm:
Even the MSO5000 shows some signs of JITTER based on the MSO8000 developments...
Maybe this 7000 thing is dead and it doesn't even know it!
The following users thanked this post: swperk, Sparky
Offline tv84
  • Country: pt
« Reply #215 on: August 25, 2019, 07:35:39 pm »
Bandwidth on a "opened up" MSO7000 using a Leo Bodnar fast rise time pulse generator 10Mhz (40picosec version):
First image of the pulse genny  taken with acquisition set to average, measure set to normal mode, BW @250Mhz as you can see the average is just a shade of 1ns for rise time which would indicate a BW around the the 350Mhz mark using 2 averages.
Second trace as above with BW limit removed all other setting identical, now the result is 455 picosec rise time which is pretty close to around 820Mhz.
The 3rd one is a 25HMz rolling linear sweep, 500mV p2p.
« Last Edit: August 30, 2019, 06:29:46 pm by tv84 »
The following users thanked this post: swperk, thm_w, Sighound36
Offline SpaleKG
  • Country: cs
« Reply #216 on: September 27, 2019, 10:37:16 am »
Can you share resources for unlocking MSO7000? Do you have GAL with enabled SSH? Or if you have any patched GAL for MSO7000.
I would like to try to create patch for 7000. Please provide what needs to be changed.
Thanks,
Spale
« Last Edit: September 27, 2019, 10:42:02 am by SpaleKG »
Offline tv84
  • Country: pt
« Reply #217 on: September 27, 2019, 10:53:12 am »
Use the method for the MSO5000 as described here:
https://www.eevblog.com/forum/testgear/hacking-the-rigol-mso5000-series-oscilloscopes/msg2682411/#msg2682411
You will need to patch the app accordingly.
Offline wat
« Reply #218 on: October 01, 2019, 08:49:07 pm »
Thanks to tv84, here is an happy owner of an "upgraded" MSO7014!!!
500MHz and all the options enabled!
I have the latest FW downloaded from the Rigol main website:
https://rigol.com/supports/software-firmware-download_3.html  (Google Chrome is great to translate pages in Chinese!)
The following users thanked this post: ebclr
Offline Sighound36
« Reply #219 on: October 01, 2019, 08:53:56 pm »
Welcome to the club actually you have pretty close yo 1Ghz BW as well Tv84 is rather good isn't he  8)
Offline wat
« Reply #220 on: October 01, 2019, 09:02:48 pm »
I would say awesome, yeah!
Offline tv84
  • Country: pt
« Reply #221 on: October 27, 2019, 09:50:27 pm »
Backup scripts for MSO/DS7000
Here.
Offline swperk
« Reply #222 on: December 16, 2019, 12:44:27 am »
Another big thumbs up to @tv84! I've got a fully enhanced DS7014 now, running the 01.01.07 firmware. Does anyone know if it's possible to "enhance" the 01.01.09.02 firmware?
Offline ebclr
« Reply #223 on: December 16, 2019, 10:41:11 am »
Just curiosity, How is the web interface of DS7000 is like DS5000 a jpg image who refreshes very slow?
Offline jemangedeslolos
« Reply #224 on: February 17, 2020, 09:59:10 am »
Hello !
There is not much information about this scope. Much much less than the MSO5000 for example. I hope to find some here  ;D
I can touch a MSO7014 for 2000€. I have never been interested in this model but I find the perf/price ratio very good.
I looked the R&S RTM3004 but I don't know if it is hackable and I don't have the money for the option bundle ( 2500€ + 3700€ for the scope ).
I also looked the Siglent SDS5034X.
I can't have all of these on my bench for comparison but on the paper, the Rigol seems to be the more powerfull.
Has anyone ever compared it to one of its other scopes?
Those who have one are happy with it?
Thank you :)
« Last Edit: February 17, 2020, 10:03:26 am by jemangedeslolos »
