Author Topic: New Rigol DS7000  (Read 107146 times)
Offline wat
Re: New Rigol DS7000
« Reply #350 on: January 24, 2024, 08:57:05 am »
Link to download the 1.04 FW: https://www.rigol.com/products/detail/MSO7000  (Using chrome to translate into English helps a lot...  8) )
Offline drhex
« Reply #351 on: February 17, 2024, 01:29:54 am »
Will have a look next week.
Offline Wong
  • Country: cn
« Reply #352 on: February 17, 2024, 02:44:50 am »
DS7000(ARM)Updatev00.01.04
https://kdocs.cn/l/csXWKvRt3y9D
Offline drhex
« Reply #353 on: February 18, 2024, 11:32:24 am »
Did open 00.01.04 up fall last year. Same patch still applies. Just look for the byte sequences with a hex editor and replace.
The following users thanked this post: wat
Offline wat
« Reply #354 on: April 20, 2024, 09:07:00 pm »
Hello,
I've prepared a 1 click patch for the latest fw 1.02.01.03 using the details from GurljoM and the automatic patch script from mabl
The procedure is pretty straightforward:
-Upgrade fw as normal
-Copy the content of the rar file into the usb stick, and "upgrade" the fw again: the screen will turn white, press "Menu off" button (I tried other buttons but they didn't work). You should see the details of the patch being applied.
Done!
P.S. It is similar to what omgoleus did here
Done the same for FW 1.4, easier than I thought to compare the patch.. thanks drhex
The following users thanked this post: Wong
Offline carlos33193
« Reply #355 on: April 22, 2024, 03:58:37 pm »
Hello,
Done!
Worked perfectly! Thank you!
