Firmware 2.13 is now available on Rigol's website !
https://alc-sh-wwwdownload.oss-cn-shanghai.aliyuncs.com/cn/Firmware/Digital%20Oscilloscope/DHO1000%26DHO4000/DHO1000-DHO4000(software)Update00.02.13.00.07.zipAnd they fixed my main grudge, the decoder levels jumping around !
Here is the complete changelog :
0.02.13 2024/03/27
- Fixed the problem of deleting files when copying the same files.
- Requirements for optimizing the total time for oscilloscope delivery, configuration, and reading.
- Fixed the problem of crash when LAN is not connected and click Apply.
- Fixed the problem that after passing the test screenshot, it cannot be stopped.
- After fixing the default, *IDN? cannot read the project version number.
- The problem of not closing the project version number lxi/identification.
- Fixed the issue of statistics not being reset when moving the measurement cursor.
- Fixed the problem that the measurement value of the moving cursor area is not updated after STOP.
- Fixed the problem of occasional no waveform when booting.
- Fixed the issue of the waveform disappearing in small gears after a pause.
- Implementation of USB external keyboard requirements.
- Fixed the problem of obtaining Math waveform error.
- Fixed vertical scaling mask error by testing.
- Fixed SPI timeout triggering problem, also for four-channel mode.
- Modify the problem that ultraLab cannot connect to the server after shutting down and restarting.
- When the Zoom function is turned on, the cursor adjustment area is not limited to the Zoom window.
- Modify the offset range below 50 ohm and 500uV/div to solve the flip problem.
- Fixed the problem of failure to modify the settings of measurement source B.
- Fixed the problem of window transparency and failure to load the last value.
- Fixed the problem of error in saving screen waveform to csv and SCPI command to obtain waveform in Math filter operation.
- Fixed the problem of crosstalk caused by adjusting vertical offset.
- One-click to open the measurement items required by the user and realize the functional requirements of the trigger source tracking channel.
- Error displayed when modifying the measurement cursor for multi-source measurement.
- Fix the problem of IIC SCL threshold and SDA threshold random reset&trigger level line random jumping caused by probe ratio at 10X gear.
