Author Topic: New Scope Demoboard from Batronix  (Read 86527 times)
Offline axantas
Re: New Scope Demoboard from Batronix
« Reply #225 on: January 30, 2024, 08:23:44 pm »
What I find a pity about the demo board is that they couldn't keep the price below €200 in the long term.
In the beginning, at least a lot of people "here" ordered the board, which I thought was great, because we all have the same source here, so it's easier to understand the problems/measurement situations of other users.
A board as a reference, so to speak.
So please make the board more affordable again. 8)
You're probably right. As this is a really great forum (and there are so many great people here) we have set up a coupon code.
With the coupon code "EEVblog" you can get the demo board in the Batronix online shop for the introductory price of 159 Euro + shipping + VAT again. The shipping costs + VAT are calculated by the online shop depending on the country of delivery.
We could also have called the coupon code "ThanksToMartin72", but that would certainly have confused some people.  ;)
I am already experimenting with this board, but Batronix just earned 10 additional stars in my next Google review for this presence at your customers - there is a one for a DHO914 pending...
« Last Edit: January 30, 2024, 08:26:56 pm by axantas »
Offline Grandchuck
« Reply #226 on: January 31, 2024, 05:33:36 pm »
I received one and have begun using it.  I make cheat sheet to help with the switches.  And, a note to young players, use J4 and not J5 for viewing the 50kHz and 100kHz Hz clock signals (that mistake cost me some time).
The following users thanked this post: coromonadalix
Offline Grandchuck
« Reply #227 on: February 13, 2024, 06:58:55 pm »
Working through the demo board manual ... thought I'd share these:
Interesting demo for using Channels 1 and 3, rather than 1 and 2, for better performance.
Offline Martin72Topic starter
  • Testfield Technician
« Reply #228 on: February 13, 2024, 10:49:10 pm »
Which point is that?
Offline axantas
« Reply #229 on: February 14, 2024, 08:43:24 am »
This appears to be a 2000X HD. I suppose, we know, why this is that way. Dave shows it in his teardown video. It is due to the routing of the PCB. CH1/2 and 3/4 share one ADC:
Offline gf
« Reply #230 on: February 14, 2024, 11:05:12 am »
Looks like "CH1&Ch2" suffers from aliasing (signal not sufficiently bandwidth limited for 1GSa/s).
« Reply #231 on: February 14, 2024, 12:57:08 pm »
Yep, he should try to measure it again with 200Mhz bandwith limit(if avaible).
Offline Grandchuck
« Reply #232 on: February 14, 2024, 01:43:01 pm »
The scope used is the SDS2204X HD which has a 200 MHz bandwidth.  As shown in Dave's video, Ch1 and Ch2 share one ADC and I am thinking this explains the result.
 Martin, I am on page 48 ... it has been educational.  Thanks for alerting the forum about this demo board.
Offline Grandchuck
« Reply #233 on: February 14, 2024, 04:20:01 pm »
Here is the delay from TP1 to TP6 on the demo board.
« Reply #234 on: February 14, 2024, 04:41:41 pm »
Nice,
I hadn't even tried it yet.
Offline Performa01
  • Country: at
« Reply #235 on: February 14, 2024, 05:37:32 pm »
Cursors are bit outdated nowadays, especially in an analytical DSO. What about using the automatic FRFR measurement instead?
The following users thanked this post: Grandchuck
Offline Grandchuck
« Reply #236 on: February 14, 2024, 05:59:41 pm »
Done!  Still learning.  This is going to take a while.  :P
The following users thanked this post: Performa01
« Reply #237 on: February 14, 2024, 06:19:31 pm »
For others, this is the "Hf Test Track" section.
Mainly responsible are two fast risetime logic gate ICs (tr<450ps), one IC is directly connected to the RF out BNC socket, so that you have a quite fast pulse at the start.
The signal also looks pretty clean.
« Last Edit: February 14, 2024, 07:08:56 pm by Martin72 »
The following users thanked this post: Kean, Grandchuck, rpro
Offline mwb1100
« Reply #238 on: February 14, 2024, 07:50:53 pm »
Is that SDS1104X-E stock (100Mhz) or hacked to 200MHz?
« Reply #239 on: February 14, 2024, 07:58:56 pm »
100Mhz "untouched", loaned from work until new scope arrives.
The following users thanked this post: mwb1100
Offline tautech
« Reply #240 on: February 14, 2024, 08:37:51 pm »
2k HD gone to someone else already ?
« Reply #241 on: February 14, 2024, 08:56:28 pm »
Yep, two weeks ago.
Offline Grandchuck
« Reply #242 on: February 15, 2024, 04:39:11 pm »
The end of the Batronix manual ... reflections in coax.  The coax length is 41 inches.  Three conditions are shown.
I will be going back and changing/trying more experiments.  Conclusion: the board is well engineered and executed.  The manual is as good as can be expected since different instruments will have to be set up in their own fashion.
Martin would like a lower price and who would argue?  However, given the sales volume it might be already priced as low as practical?
The following users thanked this post: Performa01, KungFuJosh, Martin72
« Reply #243 on: February 15, 2024, 06:25:47 pm »
I took the demo board to work today and connected our Lecroy WR9054 (500Mhz) to the Hf-Out (J7).
Indeed, this is a very fast signal, demo board owners have a "small Bodnar pulser" at the start, even if "only" in the upper ps range. ;)
Martin
The following users thanked this post: pdenisowski, Grandchuck, mwb1100
Offline 2N3055
  • Country: hr
« Reply #244 on: February 15, 2024, 09:16:10 pm »
It is faster than that...
Estimate cca. 270-280ps ...
Measuring 480ps on scope with 400ps risetime. 500ps on scope with with 420ps risetime and 521ps on one with 440ps risetime..
Used good quality 200mm cable.
Dr. Richard W. Hamming
The following users thanked this post: egonotto, Martin72
« Reply #245 on: February 15, 2024, 09:22:03 pm »
Nice...
First I was a little bit irritated - Another lecroy ?  ;D
Second look, thank god a siglent..
With 4GSa/s... 8)
Offline 2N3055
  • Country: hr
« Reply #246 on: February 15, 2024, 09:24:17 pm »
Nice...
With 4GSa/s... 8)
I thought you might like it... :-DD
Offline tautech
« Reply #247 on: February 15, 2024, 11:22:17 pm »
Nice...
With 4GSa/s... 8)
One will be in Martin's camp very soon.  ;)
Shame his SDS2000X HD had to make way for it.
« Reply #248 on: February 15, 2024, 11:28:51 pm »
To be honest, it wouldn't have been necessary.
At first glance, but you can imagine why I did it after all in view of the upcoming 3000 models and their prices.
Offline tautech
« Reply #249 on: February 16, 2024, 12:06:21 am »
Still that would be a bit of coin tied up in 2 good scopes.  :scared:
3034X HD is little more than 5034X but 12bit and the same size 10"nice 12" display.
Excellent upgrade IMO.  :-+
Correction made.
« Last Edit: February 17, 2024, 06:38:16 pm by tautech »
