Author Topic: New Scope Demoboard from Batronix  (Read 35191 times)
Offline KungFuJosh
  • TEAS is real.
Re: New Scope Demoboard from Batronix
« Reply #150 on: July 06, 2023, 02:52:49 am »
Almost all of the screenshot examples are from the R&S MXO4, and it's a very, very nice scope :)
The screenshots I make with my MXO4 are more or less identical to the Batronix manual.  And I've been using junk probes for my experiments.
One difference may be that the Batronix examples have sample rate at 5 Gsa/s and your scope seems to show 2 Gsa/s.
Yeah, that's a little out of my budget. 🤣
I thought the humps might be related to signal interference, and maybe they were using active probes or something.
I have nice Probe Master probes, but my scope does max out at 2 Gsa/s.
"I installed a skylight in my apartment yesterday... The people who live above me are furious." - Steven Wright
Offline Performa01
  • Country: at
« Reply #151 on: July 06, 2023, 07:21:39 am »
I'm referring to how clean their lines are compared to mine in the attached example.
The true reason for this is the vast difference in bandwidth. Close to 600 MHz bandwidth (SDS2504X Plus) show a lot more detail - hence "uglier" traces - than a 200 MHz scope. Whether the imperfections of the signal are interferences from the environment, bad probing or in the signal source itself is unknown at this point, but the fact that higher bandwidth reveals more (even unwanted) details remains.
Apart from that, a scope with 12 bit ADC (MXO4) will generally show nicer traces, as every user of the SDS2000X HD can attest ;)
Offline KungFuJosh
  • TEAS is real.
« Reply #152 on: July 06, 2023, 05:11:06 pm »
Bit depth and bandwidth for the win!
I set the experiment back up, changed the bit depth to 10bit, which dropped the bandwidth to 100M. I also modified my acquisition to slow:
Edit: I fiddled with the display settings more, and put the menu back on to make Rob happy. 😉
For comparison...
Here's full bandwidth at 8bits:
200M limit at 8bits:
100M limit at 10bits:
« Last Edit: July 06, 2023, 05:23:54 pm by KungFuJosh »
The following users thanked this post: Performa01, tautech, pdenisowski, mathstudi
Online Martin72Topic starter
  • Testfield Technician
« Reply #153 on: July 06, 2023, 05:24:17 pm »
Yepp... 8)
The following users thanked this post: pdenisowski
« Reply #154 on: July 06, 2023, 06:34:50 pm »
The HF termination test (next step):
The following users thanked this post: Performa01, pdenisowski
Offline KungFuJosh
  • TEAS is real.
« Reply #155 on: July 06, 2023, 06:49:30 pm »
Did your probe move between tests? I'm assuming mine lined up cleaner because I had the probe jammed in there. 😉
« Reply #156 on: July 06, 2023, 06:52:43 pm »
I held the probe during testing/saving.
Offline KungFuJosh
  • TEAS is real.
« Reply #157 on: July 06, 2023, 07:02:19 pm »
I left the probe in a fixed position on its own where I didn't have to touch it. The ground spring gave it enough tension to stay still.
« Last Edit: July 06, 2023, 08:46:06 pm by KungFuJosh »
« Reply #158 on: July 06, 2023, 09:30:20 pm »
I don´t think it has something to do with it.
But will repeat the test with fixed probe and with another probe from lecroy.
Your amplitude seems higher when comparing the pics.
« Last Edit: July 06, 2023, 09:32:22 pm by Martin72 »
Offline KungFuJosh
  • TEAS is real.
« Reply #159 on: July 06, 2023, 10:23:03 pm »
From page 50 of the manual:
"Now remove the jumper connected to the lower “50”. This will remove the
termination and you should see a voltage rise to approx. 4.8 V about 8 ns after the
signal edge (from 0 V to approx. 2.4 V) (screenshot: red signal curve)."
I think my pic is pretty spot on, no?
Edit: when you do your test again, please move the ref table so we can see the axis numbers.
« Last Edit: July 06, 2023, 11:04:49 pm by KungFuJosh »
Offline markus_jlrb
« Reply #160 on: July 07, 2023, 05:48:46 am »
Dears,
get my demo board yesterday and made some first test.
I' wondering that all the testing stuff signals could be
provided by only one ic named ATSAMD20 from Microchip.
I was expecting a FPGA device on the board.
Btw have someone managed to run the I2C examp.
and see the country and capital names when selector#1
is set to 0? I'm using a SDS1104X-E and were able to
run the UART and SPI examp. but not the one mentioned
above.
Markus
« Reply #161 on: July 07, 2023, 03:19:50 pm »
Besides the 2504HD, I still have a 1104 lying around... 8)
Check it today, no problems with the I²C signal...
Note:
Clock and data thresholds must both be set, approximately at 1.6V.
Can be found in the sub-item "Signals" in the decoder menu after selecting the decoder type.
I can post more pictures later.
Offline markus_jlrb
« Reply #162 on: July 07, 2023, 07:39:44 pm »
Thanks Martin,
you point me to the right direction.
Now I was able to decode the I2C data.
Today the SPL1016 Probes arrive too, so I could now
do some logic signal examples with the new Batronix
training board.
Markus
« Reply #163 on: July 07, 2023, 07:58:19 pm »
Thanks Martin,
training board.
Markus
Some tips if I may:
Idle High signal should have a falling edge trigger.
Saving screenshots to USB can be done with the blue Print button shortcut and leave the active scope menu visible and not have the Save/Recall menu instead.
Avid Rabid Hobbyist
Offline markus_jlrb
« Reply #164 on: July 07, 2023, 08:08:37 pm »
One problem appear as I have powered the demo board from the internal DSO USB connector,
so that at the same time I was not able to plug in the USB stick to save the screen shot.
I was not keen to power the demo board from a external psu as in this case the ground
layer is connected to the DSO ground.
Perhaps a USB hub will be the proper solution for this problem.
Markus
« Reply #165 on: July 07, 2023, 08:11:58 pm »
Markus
You do have another USB A socket on the rear......maybe not if you have SDS1202X-E.
Yes I have used a USB hub for these needs.
« Last Edit: July 07, 2023, 08:18:14 pm by tautech »
Avid Rabid Hobbyist
« Reply #166 on: July 07, 2023, 08:19:54 pm »
Yepp, a few hours ago I had the same "problem"... ;D
Then "wait a minute, is there another one on the back...ahh..."  8)
(You can see it on the picture, ok...not so clear)
This little puppy, I like it !
« Last Edit: July 07, 2023, 08:21:52 pm by Martin72 »
Offline markus_jlrb
« Reply #167 on: July 07, 2023, 08:20:33 pm »
Good hint tautech, indeed I have missed this.
Have only recognized the USB-B plug on the rear side and overseen the USB-A.
Demo board is now connected to the read side.
Thanks again.
Markus
« Reply #168 on: July 11, 2023, 03:35:30 pm »
The "HF" tests, now with siglent sds1104X-E..
Offline kerouanton
  • Just curious about science, radio etc.
    • Sometimes I play with radio
« Reply #169 on: July 12, 2023, 04:09:37 pm »
In my experience, most people aren't aware of all the different ways of using XY mode.
Indeed, I didn't think about using X-Y mode to see IQ patterns. And happy to see that my basic SDS1204X-E does the job well on 256QAM. This makes nice screenshots, quite artistic. Thank you for your video and taking the time to explain.
Online pdenisowski
  • Product Management Engineer, Rohde & Schwarz
    • Test and Measurement Fundamentals Playlist on the R&S YouTube channel
« Reply #170 on: July 12, 2023, 10:53:16 pm »
My pleasure :)
I like to joke that XY mode on oscilloscopes is like zero span on spectrum analyzers: a standard feature with lots of useful applications, but something that even experienced users are often unfamiliar with.
(and I also did a video on zero span, by the way :))
Test and Measurement Fundamentals video series on the Rohde & Schwarz YouTube channel:  https://www.youtube.com/playlist?list=PLKxVoO5jUTlvsVtDcqrVn0ybqBVlLj2z8
Free online test and measurement fundamentals courses from Rohde & Schwarz:  https://tinyurl.com/mv7a4vb6
The following users thanked this post: egonotto, 2N3055, Martin72, duckduck
« Reply #171 on: July 13, 2023, 07:53:01 pm »
Done this a few minutes ago, with a lecroy pp023 probe.
Offline KungFuJosh
  • TEAS is real.
« Reply #172 on: July 13, 2023, 11:16:06 pm »
It looks cleaner now, and lined up better.
« Reply #173 on: August 06, 2023, 08:14:48 pm »
Testing my new SPL2016 probes with the demoboard, it works..
(Function CAN decoding, 20kbit/s)
The following users thanked this post: egonotto, pdenisowski, KungFuJosh, mwb1100
Offline explozz
« Reply #174 on: October 25, 2023, 04:07:04 pm »
Hello everyone,
The 20% off MSO demo card special ends in a few days, so I ordered one to take advantage of the special.
And like everyone else, I too am going to have fun with this new toy.
Thanks to Martin72 for this expensive discovery (Laughs).  ;)
