Author Topic: New Siglent SDM4000A series Multimeter  (Read 72924 times)
jjoonathan, MikePie, S13, Mortymore and 11 Guests are viewing this topic.
Online Martin72
Re: New Siglent SDM4000A series Multimeter
« Reply #200 on: June 21, 2025, 01:36:00 pm »
Same here, reported to siglent.
Offline Furna
  • I still don't know
« Reply #201 on: June 21, 2025, 03:36:43 pm »
May I ask you how did you report?
Standard Siglent EU "contact us" form or did you contacted the seller?
Thank you
The sky above the port was the color of television, tuned to a dead channel.
Online Martin72
« Reply #202 on: June 21, 2025, 07:09:45 pm »
I know someone at siglent support, that would be more direct.
« Reply #203 on: June 21, 2025, 08:08:45 pm »
Thanks Rob anyway you always respond very fast!  @tautech
indeed thats not it.
tried also with the date 2025.06.21 for today and chatgpt thought it was 112112
so i send now a support ticket to siglenteu, i wanted the original calibration report also.
when i know, you know :)
Tried the SN# or the word SIGLENT ?
Anyone looked in the Help files in the chance the PW is there ?
After visiting Siglent last August and seeing their instrument Cal lab and the rows and rows of automated Cal equipment, adjustment of any reasonably new instrument in my view is questionable however any precision instrument with a reference will over time drift.
Again in my view isn't it better to concentrate efforts into measuring/logging any initial drift until it stabilises before attempting adjustment ?
Still, User Cal in any instrument should be an 'available to all' feature and not behind a PW wall.
Instead when entering User Cal a massive OSD warning is all that is needed and the ability to recall the factory Cal.
Offline Kleinstein
« Reply #204 on: June 21, 2025, 08:18:54 pm »
Memory is relatively cheap and usually large enough to keep quite some of the calibration history. So the option for a reset to a previous setting should be possible.
A PW protection makes some sense, but the users should have the default password. So the owner can decide to enable an effective protection. This is how it is usually done.
Online Martin72
« Reply #205 on: June 21, 2025, 09:56:03 pm »
I see it a bit more pragmatically.
Siglent's initial calibration ensures that the devices are within their specifications.
Subsequent (external) calibrations confirm this or not.
The parameters drift at the beginning, of course, but as long as they do so within the specified tolerance, it is only of academic interest, at least to me.
The fact that I burned in my SDM4000A for three weeks is purely for sporting reasons. ;)
In real-life testing, you should choose a measuring device with a tolerance that is well below that required for the measurement tasks, so that you never find yourself in a situation where you have to question the measurement results.
Online TheDefpom
  • YouTuber Nerd - I Fix Stuff
    • The Defpom's Channel
« Reply #206 on: June 21, 2025, 11:37:01 pm »
Anyone tried the obvious passwords...?
SDM4000
SDM4000A
SDM4065
SDM4065A
4065A
4065
6504
A6504
4000
4000A
1234
4321
1111
abcd
dcba
« Last Edit: June 21, 2025, 11:40:47 pm by TheDefpom »
Cheers Scott
Offline Furna
« Reply #207 on: June 22, 2025, 03:23:40 am »
I tried 1234 and I would also try all the other obvius ones ... if the device does not freeze and need a power cycle to return functional  :-//
Offline tonyalbus
    • My Channel
« Reply #208 on: June 22, 2025, 07:22:30 am »
It is just to play with to try to get it the same as my DMM6500 GDM9061 and the WRYtech who all agree on most tempratures on 1 or 2 digits.
Thats what a user call is for i would think. and you can just set it back to factory cal at any time.
The Factory call is near good ~13ppm so yes within specs. compared to my other stuff of which i am sort of sure off :)
The strange thing is, the User-Call is very off, i would assume/expect it to be same as factory when arriving new.
which is not the case with my meter, and i received it new, it was not the old Demo one from the video.
The following users thanked this post: Furna
Offline Furna
« Reply #209 on: June 22, 2025, 07:37:00 am »
I confirm; Facotry-call is well within specs.
The User-call is way off.
Online Martin72
« Reply #210 on: June 22, 2025, 02:47:30 pm »
For whatever reason, no password is now requested...
Yes, the values differ drastically, but that's not so bad because you want to correct them anyway.
That's the whole point of personal calibration, otherwise you wouldn't need it.
However, I would steer clear of it for two reasons:
-As long as there is no documentation available on how to do it.
-You don't have the appropriate references that are sufficient for calibrating a 6.5 digit meter.
« Last Edit: June 22, 2025, 03:37:23 pm by Martin72 »
Offline tonyalbus
    • My Channel
« Reply #211 on: June 22, 2025, 02:50:13 pm »
The password is requested when you select Recili, not before
Offline Furna
« Reply #212 on: June 22, 2025, 02:50:52 pm »
Correct ... when you select Recali
Online Martin72
« Reply #213 on: June 22, 2025, 03:37:11 pm »
Yepp, my fault. ;)
Offline Furna
« Reply #214 on: July 05, 2025, 02:11:17 pm »
Things starts to look better  ;)
Unfortunately I cannot tell what has changed since the 10V reference just arrived a couple of hours ago.
Online Martin72
« Reply #215 on: July 05, 2025, 02:33:45 pm »
This perfect match... ;)
Online KungFuJosh
  • TEAS is real.
« Reply #216 on: July 05, 2025, 03:10:11 pm »
Room temperature?
Best Continuity Tester Ever
Offline Furna
« Reply #217 on: July 05, 2025, 03:57:03 pm »
Room temperature?
When I took the photo it was 26.5°C; now 26.8°C
DMMCheckPlus cal. certificate report 5V room temp 21.3°C
TEN389 unfortunately does not report root temp.
DMMCheckPlus meanwhile drifted to previously measured 5.00004V
TEN389 looks more stable and drifted to 10.01649
Online S13
« Reply #218 on: September 05, 2025, 03:51:30 pm »
Just got my 4065A a couple of days a go, and been playing around with it. Nice to have such a comprehensive multimeter! 8)
But there are quite a few bugs that i have encountered so far. So the firmware could use some improvement still.
Here is a weird bug:
2W resistance: Turn on Auto Ranging and Auto Zero. Short the input leads to create zero ohms. The instrument shows about ~0.007 ohm. All ok so far. Then remove the short. You would expect the meter to measure open "overload" in the 100Mohm range. But nope. Mine shows about 0.014 ohm (slight fluctuating) and sometimes tries to switch to the 200k range, before going back to the 200ohm range. When i disable Autozero, the measurement functions correctly again. This only happens on auto range, when using fixed ranges everything works correct.
And another bug/issue? On 2 wire resistance, when i just plug in the upper test lead, the meter already measures ~20Mohm. When i unplug the upper test lead the meter measures >100Mohm. This might be an earthing related issue here in the lab to be honest, but yeah this makes measuring anything above 20Mohm impossible.
The whole datalogging and digitize functions are a bit unreliable. I had instances where the digitize function would continuously alternate between the true value of the signal and zero volt, when i was just measuring 5V from my lab supply. Exports to csv from both the datalog and digitize would sometimes result in the same incorrect values. I dont have a way to reliably reproduce this problem.
It isnt really clear when you are in Continuous acquire mode that you are also recording, at what speed, and where in the recording memory you are exactly. You can save the recording from the Acquire menu, but in order to delete/reset the recording you have to go in to the Trend view. But in trend view you cant save them, you have to go back to Number view -> Acquire. A bit messy if you ask me.
The Start value in the CSV export had a bit of a weird notation. For example:
"Start date:,2025-09-05,Start time:,14:15:08.3.375781"
Is it showing milliseconds or what?
And maybe it would be nice to have better options to navigate (zoom, scroll, etc) through Histogram and Trend view?
And as a final issue, windows keeps nagging about the usb stick needing to be repaired after it has been used in the sdm4065a. There seems to be no data corruption however.
That is what i have so far :box:
The following users thanked this post: Mickle T., tautech
Offline Furna
« Reply #219 on: September 06, 2025, 06:13:29 am »
Agree
« Reply #220 on: September 23, 2025, 09:58:05 am »
SDM4055A arrived and now with a chance to spend a little time with it since last August when we played briefly with SDM4065A at Siglent HQ before release.
First thing was to set time to NZ where I noticed there is also a setting for NTP time if connected to your LAN.  :-+
Screenshot grabbed remotely using the webserver.
Online danno_cj
« Reply #221 on: September 23, 2025, 01:03:18 pm »
New one is already released SDM4075A  7 1/2 digits with 50000 rdgs/s.
The following users thanked this post: ddrl46, tautech
« Reply #222 on: September 23, 2025, 03:50:07 pm »
Online KungFuJosh
  • TEAS is real.
« Reply #223 on: September 23, 2025, 04:17:11 pm »
I'll take one. ;)
« Reply #224 on: September 23, 2025, 04:33:05 pm »
