So i was trying to do some device sleep current measurement with a SDM4065A and i was a bit disappointed with the zero offset that came with this multimeter. So im running at the 2A DCI range and i first tried to measure the zero current level by just shorting the input. Im reading a zero level of about 380uA. Hmm, yeah when you are trying to measure microamps sleep current of say a microcontroller or something, having an offset of 380uA seems like a lot. But ok, it seems to be within spec of the meter.
Maybe i was just expecting a little bit better calibration out of the box?
The next histogram shows the results over a couple of minutes of measuring. It has a nice span of just 35.7uA, a std dev of 5.2uA and a distribution as you would expect. It even shows the distinct converter steps.
Anyway, we can obviously use REL mode to zero out the measurements. And as expected that puts the zero level in the right spot with just minor fluctuations.
The span, std deviation and distribution curve all look similar to the non-REL measurement so no problems here.
But then the SDM4065A has an AutoZero option. But what the hell is that supposed to provide us?
- It does not zero out the measurement at all, i get an average remainder of 85uA still
- The measurement noise increases a lot! A span of 122uA, std dev 24.8uA, and the curve is all over the place
- It obviously adds lag because of the additional zero measurement in between each normal measurement
So my question is, is there something wrong with AutoZero, or what is the purpose of it?
