The color can be misleading as it's rendered by the camera and image post processing, then on your monitor. If your monitor is not one of the expensive "Calibrated" types (or Calibrated with a proper device), then it's difficult to determine the actual precise color.
Edit: Just took a look at our SDS800X HD, it's the "Dark" color and if the SDP is the same, then it does have a brownish tint to our eyes, whereas the Keysight "Dark" has a charcoal with a slight blueish tint.
Personally think this new PS looks fine, also like that Siglent has "listened" to users and placed the Terminals at standard spacing (keeping with color coding the ends like previous models), and included a numeric keypad, all per user/complainer inputs
One will soon find out that without color coded terminal ends it's very easy to mis-plug the connections when the PS is straight on (~level with the eye). Results can be disaster in the waiting, don't ask how we know!! Our GPP-4323 has this problem and we used Acrylic Paint to color the terminal ends, after an "Experience"!!
Also Siglent has included Remote Sensing to the main channels, this is a welcome addition as one can create a custom cable that senses at the cable ends. This allows one to "Cheat" and use a smaller core cable and still deliver the proper voltage to the DUT without worry for cable drop.
Best,
