Author Topic: New Siglent SPD4000X series power supply  (Read 34592 times)
tautech and 1 Guest are viewing this topic.
Online mawyatt
Re: New Siglent SPD4000X series power supply
« Reply #150 on: October 07, 2024, 01:25:37 pm »
As to good practice, you would set voltage to some low value and set 20mA.
Connect DUT, enable output and slowly ramp up the voltage...
Good advice with any unknown DUT situation :-+
With known DUT and developmental work (what we mostly do/did) we almost always set the Overcurrent (CC) Limit to slightly above normal (expected) current draw and the Voltage (CV) to the desired operating voltage. We've been "saved" by this procedure more times than we care to admit :o
Best
~Wyatt Labs by Mike~
The following users thanked this post: Performa01, 2N3055
Offline ArdWar
  • Country: sc
« Reply #151 on: October 07, 2024, 01:28:39 pm »
Why isn't that a normal mode of operation?
I should've word it better, what I meant is that direct into CC is not exactly commonly used feature. And the problem mentioned above is not "normally" appliable to the use case presented in the posted question.
Yes I agree that proper CV AND CC is expected (and should be guaranteed) mode of operation, but CV is by far the more common usage and is the one that applies to the posted question, and so far no decent PSU fails so bad that it violate CV setpoint.
To put it simply, the particular problem discussed here is not where you set your PSU at 3.3V and it somehow overshoot to 8.0V. It is where you set 10mA and it somehow go all the way to 160mA.
« Last Edit: October 07, 2024, 01:34:40 pm by ArdWar »
Offline Furna
  • I still don't know
« Reply #152 on: October 07, 2024, 04:41:38 pm »
Overshoot Voltage can and will damage/destroy certain components ...
Execess of current due to the Overshoot Volatge can and will damage/destory certain components ...
« Last Edit: October 07, 2024, 04:43:40 pm by Furna »
The sky above the port was the color of television, tuned to a dead channel.
Online mawyatt
« Reply #153 on: October 07, 2024, 04:49:37 pm »
Execess of current due to the overvolatge can and will damage/destory certain components ...
Actually the overvoltage can without much current at all. CMOS Gate Oxides fail due to voltage, they are so thin today, a few atoms thick, that it doesn't take much voltage (or current) to puncture the oxide and cause a failure, and in it takes very very little current for this puncture to happen :P
BTW BJTs are also susceptible, altho they tend to take more current as the usual failure mode is localized heating. A couple decades ago we were dealing with 400~500GHz SiGe BJTs in a BiCMOS process that had junction breakdowns below 2V, you could fry these by just looking at them it seemed....exteremely sensitive to any over voltage.
Of course as always YMMV!!
Best
Best
« Last Edit: October 07, 2024, 04:59:56 pm by mawyatt »
Offline seajayshore
« Reply #154 on: October 07, 2024, 04:58:10 pm »
Looking forward to a video review on these! They look great on paper!  :popcorn:
Offline Furna
« Reply #155 on: October 07, 2024, 05:41:36 pm »
Best
Best
Let me insist :)
Voltage does not flow, Voltage is potential difference or as Fluke states "Voltage is the pressure from an electrical circuit's power source that pushes charged electrons (current) through a conducting loop" https://www.fluke.com/en/learn/blog/electrical/what-is-voltage
Wikipedia "Voltage, also known as (electrical) potential difference, electric pressure, or electric tension is the difference in electric potential between two points." https://www.google.com/url?sa=t&source=web&rct=j&opi=89978449&url=https://en.wikipedia.org/wiki/Voltage&ved=2ahUKEwiNiNjl5_yIAxW9cfEDHUD3Id4QFnoECDwQAQ&usg=AOvVaw313bQM2LG1bdUNXXllrJqE
Even a smal potential difference might make an electron moves.
Electrons move and can damage things
« Last Edit: October 07, 2024, 05:43:53 pm by Furna »
Online mawyatt
« Reply #156 on: October 07, 2024, 09:16:38 pm »
Let me insist :)
Yes electrons move and can damage things, and how much current is a few electrons moving thru a thin oxide  ;)
Best
« Last Edit: October 07, 2024, 11:41:10 pm by mawyatt »
Offline MildInductor
« Reply #157 on: October 09, 2024, 04:34:17 am »
My SPD4323X has arrived. From playing with it for a few moments it seems to be a good product overall. The buttons and encoder don’t feel as high quality as my SDS800X-series scope, but they are definitely useable. I am keen to start using it!
Offline Furna
« Reply #158 on: October 09, 2024, 05:40:44 pm »
Enjoy it but move it on the bench; can't see it on the floor!  8)
Indeed I like the "clicky" encoder.
Share your opinion soon.
Offline Furna
« Reply #159 on: October 09, 2024, 05:50:27 pm »
[...] and how much current is a few electrons moving thru a thin oxide  ;)
1eV=1.602*10^-19 J
1[C]=6.25*10^18 electrons
Q= algebric sum of electrical charges
8) ... anyway I have to admit I am not aware of phisical characteristics of oxide.
« Last Edit: October 09, 2024, 05:52:37 pm by Furna »
Online mawyatt
« Reply #160 on: October 09, 2024, 06:38:56 pm »
1eV=1.602*10^-19 J
Modern CMOS gate oxide layers are ~1nm thick. One electron per microsecond is 150fA, or 0.15pA. Oxide breakdown occurs 1st with a soft nature, then hard breakdown occurs. Soft is when a localized gate oxide conductive path is formed (soft failure device degradation), hard is when this becomes permanent (hard failure device destruction). The effective current levels for these effects are very small!!
Anyway, we should start another topic on this and not disrupt this thread about the new SPD4000X.
Best
« Last Edit: October 10, 2024, 12:18:19 am by mawyatt »
« Reply #161 on: October 19, 2024, 09:08:59 pm »
New firmware for SPD4000X models.
Version: V4.1.2.8R1
400kB
https://int.siglent.com/upload_file/zip/firmware/Power_Supply/SPD4000X_4.1.2.8R1_EN.zip
Release notes
1. The flag font in CC state is changed to red.
2.In case of channel output, Press the aLL key to disable All ON/OFF output, and then press the All ON/OFF key to enable four output channels.
The following users thanked this post: Furna
Offline Furna
« Reply #162 on: October 19, 2024, 10:50:14 pm »
Version: V4.1.2.8R1
400kB
Thank you for sharing; I should receive the info from the newsletter but it's nice to have a very timing information from you!
Indeed it is dated 14th of October on Siglent EU website
Release notes
I think this is good; it make more clear the switch from CV to CC ... if I got it correcltly.
Not sure I like this ... currently I can power on a channel and in a second moment power on all the remaining 3.
The following users thanked this post: Sorama
« Reply #163 on: October 19, 2024, 10:55:51 pm »
Please test and report.
Online KungFuJosh
  • TEAS is real.
« Reply #164 on: October 19, 2024, 11:23:23 pm »
I think it sounds safer that way. Less likely to damage stuff.
Online TheDefpom
  • YouTuber Nerd - I Fix Stuff
    • The Defpom's Channel
« Reply #165 on: October 19, 2024, 11:26:30 pm »
It will ONLY power on all channels at once if you intentionally push the ALL button... I don't see a problem.
Cheers Scott
Offline Furna
« Reply #166 on: October 20, 2024, 12:14:58 am »
What is written in the release notes corresponds to real facts ...
- CC mode is now in signaled in red font.
- "All On/Off" button behaviour while a channel (or more than one) is already On has changed.
   Pressing "All On/Off" button while a channel is already On, now power it Off. Counter intuitive IMHO.
I agree to TheDefpom ... if Siglent want to insert a new layer of "security", please ask me if I really want to power on all channels (press the button twice).
Indeed the behaviour has changed substantially.
Online KungFuJosh
  • TEAS is real.
« Reply #167 on: October 20, 2024, 12:57:58 am »
Since the behavior only happens while a channel is already powered on, it sounds like somebody broke something and requested the feature.
If that was an option you could change in the settings somewhere, that would be cooler.
« Reply #168 on: October 20, 2024, 01:26:25 am »
Thanks.
ALL ON/OFF behavior of SPD3303X/X-E has been criticized in that the ALL ON/OFF button would not turn any ON channel to OFF.
It seems this change of which I agree with is to provide 2 front panel methods of turning any active channel to OFF.
In this case it only adds additional functionality to the ALL ON/OFF button.
Offline Furna
« Reply #169 on: October 20, 2024, 11:55:42 am »
With one button only it is a binary situation; as I wrote IMHO a functionality was changed.
I flashed back firmware 4.1.2.8 and now I already miss the red font in CC mode :)
Regarding the "revise" history: it is written version 4.1.2.8 is the first release ... when the unit arrived on my bench it was running 4.1.2.6R2 (see photo below)
Offline seajayshore
« Reply #170 on: October 20, 2024, 01:17:28 pm »
I’ll be buying one of these supplies soon…  :-+
Can anyone who’s had both an SPD4000X and SPD3000X say if fan noise is improved/worse/similar?
I know that’s a very use-dependant situation… So just any rough comparison & opinion is all I’m looking for!
Offline sparky2024
« Reply #171 on: October 22, 2024, 11:02:31 pm »
Has anyone else noticed that, with all four channels switched off, when using the master power switch to turn the whole power supply off, channels 2 and 3 will “pulse” the set power level briefly?  I do note that relays toggle when master power switch is turned off also.
I am seeing this on HW rev 0 SPD4323X, and wonder if this really is an issue (I am afraid of zapping a work in progress breadboard circuit or device I may be diagnosing with “unexpected power”), and whether it could be a firmware fix?
Online mawyatt
« Reply #172 on: October 23, 2024, 02:55:02 am »
That shouldn't happen with any power supply, regardless of pedigree or cost, even a DIY version  :(
Our SPD3303Xs and GPP4323 don't behave this way, if they did we wouldn't have or use them. As you mentioned too much chance for sensitive circuit damage :--
Hopefully this misbehavior is only with your individual PS, and not typical behavior for these new SPD4000X models.
Best,
Offline Furna
« Reply #173 on: October 23, 2024, 04:46:21 am »
My unit SDP4121X HW rev 0
What firmware version are you running? The firmware version 4.1.2.6R2 that was running when my unit arrived is NOT available on the web site while 4.1.2.8 and 4.1.2.8R1 are available
https://www.siglenteu.com/service-and-support/firmware-software/dc-power-supplies/#spd4000x-series
While powering off using the master switch (with NO load connected) I could NOT hear the relays ... will try to better reproduce when back from work.
Online KungFuJosh
  • TEAS is real.
« Reply #174 on: October 23, 2024, 04:10:42 pm »
Why not use single trigger on your scopes to test this?
