Author Topic: New toy(?) scope Fnirsi DPOX180H, claimed 180MHz/500MSps (May 2023)  (Read 141447 times)
Offline RAPo
Re: New toy(?) scope Fnirsi DPOX180H, claimed 180MHz/500MSps (May 2023)
« Reply #525 on: February 12, 2024, 05:45:33 pm »
Old in the sense of the initial offering or v1.
The following users thanked this post: Randy222
Offline iceek
  • Country: cz
« Reply #526 on: February 23, 2024, 12:05:22 pm »
Is there posibility to change menu language in menu or by flashing new FW?
Offline RAPo
« Reply #527 on: February 23, 2024, 12:47:54 pm »
press move+power-on buttons together, choose language and press mod/ok
Online csuhi17
  • Country: hu
« Reply #528 on: March 04, 2024, 09:16:38 am »
After a couple of hours of use, I wanted to turn it off and the screen crashed.
after pressing the power button again, it turned off normally.
I hope they release a bug fix soon.
Have they already replaced the incorrectly chosen capacities in the newer sold versions?
Fnirsi oscilloscope = waste&regret
Offline ptluis
  • Country: pt
« Reply #529 on: March 04, 2024, 12:18:42 pm »
Offline battlecoder
  • Country: cl
    • A BIT of Mystery
« Reply #530 on: March 08, 2024, 05:23:49 am »
I sold my "old" version and bought the new one a couple of months ago. I have not disassembled it, but considering what I saw in my tests after receiving the unit I don't think they did.
I didn't bother modding this new unit because even with "better" caps the problem wasn't fully gone. It was better, but still there.
I can check by opening the unit tomorrow, assuming people here are truly interested in knowing whether they made any change to the caps they picked for the new version  :-//
The following users thanked this post: csuhi17
Offline infino
« Reply #531 on: March 08, 2024, 10:15:28 am »
What's the sense of replacing it then?
Offline battlecoder
  • Country: cl
    • A BIT of Mystery
« Reply #532 on: March 14, 2024, 01:22:10 pm »
Just to be clear, the problem occurs when measuring low-frequency waveforms (up to a couple of KHz) in AC coupling mode, with the probe at 10x. If you don't replace the caps, you get a severely attenuated signal under those conditions. Replacing the caps improves the situation and lowers the attenuation by a lot, making it a lot more useful in those scenarios BUT it doesn't eliminate it entirely.
After I sold my old unit and got a new one I couldn't be bothered to do the mod, mostly because I've not used the device a lot, and but also because I'm already aware of the problem so I can avoid it by not using the probe at 10x with low frequency signals if I want AC coupling.
I might still do the mod, but it's not in my priority list.
Offline Randy222
« Reply #533 on: March 14, 2024, 05:39:57 pm »
So in this case where 10x is an issue, is it better to use 1x with a divider network? Example pic.
Offline battlecoder
  • Country: cl
    • A BIT of Mystery
« Reply #534 on: March 14, 2024, 06:53:48 pm »
Well if you want to start adding external circuitry it would be simpler to try external ac-blocking first, since it's their selection of ac-blocking cap what is questionable (although I think at one point it was determined that the ac-blocking is happening after the input resistor that forms the voltage divider with the probe, and thus it's not as simple).
Now, I don't really do a lot of AC probing. At most I use AC coupling when measuring noise in switching supplies, but the frequency in those scenarios is usually is high enough for this to not be an issue, and if they were really low-frequency (in the <10 KHz range), I still could get around this problem by not using the probe at 10x.
If I had a need to measure high voltage low frequency AC signals regularly, I would definitely prefer to mod the unit over adding external circuitry or ignoring the issue.
Offline lfldp
« Reply #535 on: July 26, 2024, 12:57:08 pm »
Hello I wanted to ask how long does this oscilloscope need to fully charge? The red diode has never changed color during charging or gone out, only the indicator at the top showed a higher battery charge - is this normal or did I buy a damaged model? Best regards.
Online csuhi17
  • Country: hu
« Reply #536 on: July 26, 2024, 05:33:31 pm »
in 3-4 hours.
If you turn it on, you can see it in the upper right corner of the indicator.
Offline lfldp
« Reply #537 on: July 27, 2024, 10:32:44 am »
in 3-4 hours.
Ok thanks for the instructions. Yes I see the arrow and the increasing battery capacity while charging but the power button still lights red so what is the full battery indicator in this oscilloscope? :) How do I know that the battery is fully charged?
Offline lfldp
« Reply #538 on: July 27, 2024, 10:34:31 am »
in 3-4 hours.
The problem is that the charge indicator increases to maximum after 30 minutes of charging - does this device have any battery charge detection?
Online csuhi17
  • Country: hu
« Reply #539 on: July 27, 2024, 11:09:24 am »
To be honest, I don't know, I rarely use it, I mostly work with my Owon HDS272s.
I'm used to putting it on the charger and taking it off after a few hours.
I don't pay much attention.
I noticed that I have some charger that does not want to charge it.
It is possible that this is also a bug.
What you can possibly try, I just don't know with mine right now, because it's fully charged,
If it is almost completely drained, put it on a charger and turn it on after half or  an hour.
If it shows full, you disconnect the charging cable.
In theory, the charge level indicator will then dropt back down.
But I repeat, I have not dealt with such things, I just use it and charge it.
If the battery is half full, then 2 hours. If empty then 3-4 hours.
If you're really interested, you can monitor it with an external device or with a charging cable that displays current or power.
Or make something that disconnects the scope from the charger and tells you with an LED that charging is complete.
The following users thanked this post: lfldp
Offline lfldp
« Reply #540 on: July 27, 2024, 01:01:05 pm »
I understand you. I have a USB cable with a voltage monitor from what I remember after about an hour of charging the power dropped from 8-9W to 5W. I will repeat the tests today and describe what and how. Yes, it may be a bug and what is worse, if the voltage system does not disconnect the batteries, they may be damaged after some time.
Offline Dave_g8
« Reply #541 on: July 27, 2024, 01:45:15 pm »
Generally the charger will terminate at 10% of the preset charge current. So when initially charging a discharged battery, it will charge at a constant current of say 500mA.
As the battery is charged, the charging reverts to constant voltage and when the current falls to around 10% of the full charge current, 50mA in the example, the charging should terminate.
Many of the low-cost products may not support simultaneous charge and power, and therefor may not terminate the charge cycle if the device is turned on, this is because the current drawn is greater than the termination current.
Offline lfldp
« Reply #542 on: July 27, 2024, 04:20:41 pm »
Thank you all for your help - I repeated the charging process and indeed the power dropped to 5W at first and after about 3 hours to 0W and the red power diode turned green, which means everything is working as it should. :)
Offline imyxh
    • our hackerspace
« Reply #543 on: July 31, 2024, 08:55:06 am »
I just ordered a DPOX180H, and noticed those weird plots radiolistener was showing:
But 5 GS/s looks crazy even if they used equivalent time sampling, so I'm not sure if I decoded it properly...  :)
Very interesting! I decided to download some of the .wav data shared here. I'm no professional but I have a crazy idea about what's going on.
If you plot the .wav files in e.g. Python (try plt.plot(np.fromfile("foo.wav", dtype=np.uint16))), you will see that the noise seems to be an exact offset of 256 counts, up or down. See my attachment for an example.
In fact, it seems that bits 8:15 tend to flip too early. For example, here's an ascending sequence:
julia> string.([5323, 5631, 5428], base=2, pad=16)
3-element Vector{String}:
 "0001010011001011"
 "0001010111111111"    # <-- bit 8 flipped before it was supposed to!
 "0001010100110100"
where we can see that if we didn't flip bit 8 preemptively, it would've been a reasonable value. Similarly, a descending sequence:
julia> string.([10249, 9986, 10230], base=2, pad=16)
 "0010100000001001"
 "0010011100000010"    # <-- bits 8, 9, 10, 11 flipped too early!
 "0010011111110110"
Hmm! My guess is that actually, somehow they are only measuring eight bits at a time of the uint16, starting at the least significant byte, and so there is a sort of race-condition where they check the lower byte, then the signal transitions to flip some bits in the upper byte, and then they check the upper byte. As a result you have a uint16 that is 256 too high or too low, depending on if the signal was increasing or decreasing at the time.
Is this a known trick? Maybe this is something that's happening in the FPGA? Or maybe they are using 8-bit ADCs and doing some clever switching?
Once my scope arrives I'll test and see if the same happens. If so I'll email FNIRSI, but I'm sure they already know about this. Maybe this is why they don't release info on the file format, and why they laser etch the ADC model....
In any case, for the purposes of data analysis on a signal much slower than your sample rate, this is probably trivial to fix in post—just scan along the data, and any time the upper byte increments, check if the lower byte is bigger than the lower byte of the next sample. If it is, decrement the upper byte. And same for the reverse.
« Last Edit: July 31, 2024, 11:25:12 am by imyxh »
The following users thanked this post: lfldp, RAPo
Offline imyxh
    • our hackerspace
« Reply #544 on: July 31, 2024, 11:31:55 am »
Hahahaha. I'm stupid. I bolted awake to realize that this is not a race condition sort of thing, it's just that the data is big-endian, and starts at an odd offset.
Try np.fromfile("10MHz-1V.wav", dtype=">u2", offset=1) to read. Or increase offset if you want to skip all the metadata, etc.
I'll work more on the file decoding later but we have the basics down.
Offline imyxh
    • our hackerspace
« Reply #545 on: August 04, 2024, 04:55:16 am »
I have found a new video showing a new bug/crash of this device when using the usb function. Try on your units to see if it happens.
https://youtu.be/NLNTrn9KVrk
Aha! I have this too on my Linux machine, but I fixed it.
After using Wireshark to capture the USB traffic, I found that the device was timing out after the host sent it an SCSI Read command, for 240 blocks. I then also found this: https://bugzilla.kernel.org/show_bug.cgi?id=219027
It seems like the DPOX180H can only buffer something like 128 blocks at a time over SCSI. Linux doesn't find out about this for interesting reasons (see bugzilla link) and the mass storage chip on the DPO fails to throw an illegal request error like it's supposed to but instead just completely crashes. This also explains the text disappearing afterwards. Windows is probably either playing it safe with low default maximum block limits or looking at the Block Limits VPD page.
So on Linux, one solution is to edit the udev rules like this:
$ cat /etc/udev/rules.d/fnirsi.rules
# DPOX180H seems to have a transfer limit of something like 128 blocks
ACTION=="add|change", SUBSYSTEM=="scsi", ATTR{model}=="F1Cx00S Disk    ", ATTR{max_sectors}="128"
and then of course do udevadm trigger. After doing that I was successfully able to mount the scope as mass storage and flash a firmware update to it.
I don't have a mac so I can't help there, sorry. :P
The following users thanked this post: battlecoder, Rooster Cogburn, lfldp, mmldrm
Offline ptluis
  • Country: pt
« Reply #546 on: September 05, 2024, 02:28:11 pm »
Today I'm going to change my opinion about the dpox180h. I bought the first version and honestly I didn't like it, it froze a lot. I updated the firmware to 3.0 and the problems continued, mainly with the trigger, which in a certain sequence of operations was not possible to access the menu to change the trigger mode. I then decided to update the firmware to 4.0 and the oscilloscope got much better, there was no freezing since I installed it, the trigger menu bug was also solved, the waveform is finer and details are noticeable. I have used it to test sensors, single-phase and three-phase motors, controllers, signals from ECU and I must say that it is completely satisfactory. Therefore, the Fnirsi has risen in my consideration because it really fixed some of the problems and did not forget the first versions. In this last point, Zeeweii and its dso2512g took the wrong direction, where the first versions were set aside in terms of updates or improvements.  There are about 3 or 4 different versions and when they make improvements they forget about the previous units and sell a new one. That's the deal. So it's only fair that I correct what I wrote in previous posts for those who consider my previous comments before deciding to purchase. Thank you, have a nice day  :-+
Offline RAPo
« Reply #547 on: September 05, 2024, 02:51:45 pm »
Indeed and if you buy the new (yellow) version the pressing of the buttons will substantially be better. You don't need to buy a new scope only the casing.
Offline ptluis
  • Country: pt
« Reply #548 on: September 05, 2024, 04:04:17 pm »
and where can i find the case? can you post a link? thanks
Offline RAPo
« Reply #549 on: September 05, 2024, 04:34:40 pm »
I can't find a product link. Will ask finirsi if they still sell it.
The upgrade video is here:
https://youtu.be/VsiZiW_2zy8
