Author Topic: New toy(?) scope Fnirsi DPOX180H, claimed 180MHz/500MSps (May 2023)  (Read 91225 times)
Offline rhb
Re: New toy(?) scope Fnirsi DPOX180H, claimed 180MHz/500MSps (May 2023)
« Reply #25 on: May 28, 2023, 12:09:55 am »
The Owon HDS272S delivers the promised 70 MHz -3 dB point, but is usable much higher.  And the FW is much better than the analogous Hantek.  UI is everything when you make it small.
The following users thanked this post: RAPo
Online RAPo
« Reply #26 on: May 28, 2023, 03:00:09 pm »
I cannot replicate the measurement, even with probe attenuation=100x  ;D
Offline Aldo22
« Reply #27 on: May 28, 2023, 03:18:02 pm »
« Last Edit: June 07, 2023, 02:20:53 pm by Aldo22 »
The following users thanked this post: Markus2801A
Online RAPo
« Reply #28 on: May 28, 2023, 03:23:05 pm »
Hi RAPo
And what is the bandwidth according to your measurement?
Just the point where Pk-Pk falls below -3 dB (0.707) compared to, say, 100kHz?
I'm a bit busy. I will need to get my TinySA Ultra for reliable testing. See PSG908/FY6900 testing.xlsx for preliminary results.
Online RAPo
« Reply #29 on: May 28, 2023, 03:33:05 pm »
Mailed Fnirsi and asked for a firmware update regarding the cursors.
Fnirsi responded within one day: results are sen d to their engineers. They will respond back within a few days.
While on the topic, I asked for some "enhancements":
Could a long press CH1/CH2 button enable/disable the signal?
Could a double click on CH1/CH2 button enable/disable the bandwidth filter?
Could a long press on the trigger button cycle through the trigger modes?
Could a long press on the orig-button cycle through the coupling mode of the active channel?
Offline IconicPCB
« Reply #30 on: June 01, 2023, 02:12:31 am »
Is the signal generator ground independent of scope ground? ( galvanically isolated)?
Offline Aldo22
« Reply #31 on: June 03, 2023, 12:00:58 pm »
Some people complain that you don't see vertical lines with square waves.
What do you think?
Bug or feature?
« Last Edit: June 03, 2023, 12:07:47 pm by Aldo22 »
Online RAPo
« Reply #32 on: June 03, 2023, 12:24:32 pm »
I've just finished some discussion with Fnirsi. On the good side: they respond quickly, and are really looking into things.
But the cursor problem took a strange turn.
On my question the V1 and V2 measure, I got as the answer:
V1 and V2 are the voltage cursors of channel 1 and channel 2, respectively to distinguish
Presenting evidence that this cannot be right (see images), the response was:
The measurement principle of the cursor is to measure according to the vertical sensitivity of the channel.
Therefore, when measuring, it is necessary to measure the voltage cursor of the channel separately to obtain an accurate value.
V1V2 is the vertical sensitivity set according to channel one and channel two; to measure the voltage value of the range selected by the cursor
I'm giving up on this scope and bought a Zeeweii DSO2512G.
Online RAPo
« Reply #33 on: June 03, 2023, 12:25:54 pm »
What do you think?
Bug or feature?
I consider it a bug implemented as a feature :P
Offline Aldo22
« Reply #34 on: June 03, 2023, 01:46:08 pm »
:-DD
The DSO2512G is probably not better overall, but definitely cheaper.
Good luck!
Offline Aldo22
« Reply #35 on: June 03, 2023, 05:03:57 pm »
What do you think?
Bug or feature?
On the other hand, with "Digital Phosphor" they seem to be trying to imitate a CRO and they apparently showed square waves like that.
Offline vk6zgo
« Reply #36 on: June 04, 2023, 01:23:18 am »
What do you think?
Bug or feature?
& it becomes more visible.I consider it a bug implemented as a feature :P
Not really, analog 'scopes all displayed the rise & fall of square wave signals.
Because the beam was more briefly in any discrete point during such transitions, the display was less bright than the top & bottom "flat" bits of the waveform but wind up the intensity, & it becomes more visible.
The following users thanked this post: RAPo, Aldo22
Offline Aldo22
« Reply #37 on: June 04, 2023, 10:13:56 am »
I'm not quite sure if I understand you.
I believe the DPOX180H simply displays the difference between the dashed lines in relation to the respective vertical sensitivity (V1 Ch#1, V2 Ch#2).
It doesn't show absolute levels afaics (Like Y1, Y2 with the Zeeweii).
This is strange, but not directly a bug imo.
The DSO2512G displays the two absolute values Y1, Y2 and the difference dY in relation to the vertical sensitivity setting of the selected channel.
If you want to see the values in relation to the vertical sensitivity setting of the second channel, you can switch the channel priority. The values are then displayed in green.
« Last Edit: June 04, 2023, 10:30:31 am by Aldo22 »
Online RAPo
« Reply #38 on: June 04, 2023, 10:45:21 am »
The statement from Fnirsi was: V1 and V2 are the voltage cursors of channel 1 and channel 2, respectively to distinguish.
In the image below, both channels are turned on and have the same sensitivity.
Turning the cursor *measurement* on, you see two different green dashed lines.
Both V1 and V2 have the same value. Moving one of the green lines, both values V1 and V2 change. Why on earth would you need that?
« Last Edit: June 04, 2023, 10:55:24 am by RAPo »
Offline Aldo22
« Reply #39 on: June 04, 2023, 11:07:48 am »
Yes, it's the same 'Delta' as dY on the DSO2512G, but it is displayed for both channels at the same time.
If both channels have the same vertical sensitivity, the same value is displayed twice.
That's why you see 4.04V and 808mV on your other picture, because 1V is set on the 1st channel and 200mV on the 2nd channel.
I don't like that the absolute levels are missing, but it's not really a bug imho. It's a feature!  :-DD
« Last Edit: June 04, 2023, 11:09:47 am by Aldo22 »
Online RAPo
« Reply #40 on: June 04, 2023, 11:14:23 am »
but why is moving one cursor line to show a difference in both V1 and V2?
Offline Aldo22
« Reply #41 on: June 04, 2023, 11:34:43 am »
Because it shows basically the same thing twice. Once in the vertical sensitivity of Ch1 and once in the vertical sensitivity of Ch2.
You probably expect these values (V1 and V2) to say something about the position of the dotted lines, but they don't!
They only show the difference between the dotted lines in the respective unit of Ch1 and Ch2.
Compared to the ZEEWEII DSO2512G, they only show dY, not Y1/Y2
« Last Edit: June 04, 2023, 11:40:02 am by Aldo22 »
Online RAPo
« Reply #42 on: June 04, 2023, 11:37:15 am »
and why would you need that?
Online coromonadalix
« Reply #43 on: June 04, 2023, 11:44:09 am »
gonna laugh at all this
people ask thoses little thingys a lot, you want good scope performance at this size ???
i would say lots of falses claims / specs  etc ...  you have to get prices cuts somewhere ?
but if Fnirsi  respond  and they are taking comments  i'll say its good for them and users
Offline Aldo22
« Reply #44 on: June 04, 2023, 11:47:27 am »
I don't know exactly. I don't like it either, but I get what it does.
If this is a bug, it's at the user interface level ("bad decision"), not necessarily in the implementation.
Online RAPo
« Reply #45 on: June 04, 2023, 11:48:58 am »
Yes, they do reply, are looking into the things and that is a good thing.
Online RAPo
« Reply #46 on: June 04, 2023, 11:50:32 am »
Yes, it is in the UI and, therefore, straightforward to change.
Online RAPo
« Reply #47 on: June 04, 2023, 11:55:10 am »
I only ask what they advertise
Offline Aldo22
« Reply #48 on: June 04, 2023, 03:00:07 pm »
It's clear that in this price range, cheap hardware is used wherever possible, but that doesn't necessarily mean that something unusable has to come out if you put it together intelligently.
And that's where the ZEEWEII guys have done something right with the DSO2512G, in my opinion.
Of course, it has its drawbacks,maybe even some serious ones, but it doesn't suck and makes the most of itself.
Simply as much as is possible for this price and that alone is an achievement.
Offline ycui7
    • SpecialtyCircuits LLC
« Reply #49 on: June 07, 2023, 03:40:27 pm »
This is exactly what you will see with digital phosphor with any brand. Vertical line should NOT show up. That is what you would see in the good old analog days.
So they implemented their digital phosphor correctly.
