Author Topic: Help Rohde & Schwarz CMU200 Display Issue  (Read 3254 times)
Offline jessejgmTopic starter
  • Country: br
« on: April 09, 2024, 10:48:53 pm »
Goodnight. I'm wanting to buy this cmu200. But I'm in doubt because of the problem with the display turning orange. And there is no clarity.
Could there be a problem with the screen? In the Capes?
It is worth it?
I'm a beginner in the area.
Offline richnormand
Re: Help Rohde & Schwarz CMU200 Display Issue
« Reply #1 on: April 09, 2024, 11:02:01 pm »
I think many old cmu200 have this issue.
1)
Usually from the corners and it creeps in.
Fortunately here it looks like the display proper is OK.
If I remember correctly it is an issue with the RF shielding layer on top and it can be removed.
Should you need the ultimate RF specs you might consider some ITO coated glass , if not, then you are OK with a protective plastic.
2)
The display needs to be disassembled to see if the fluorescent lamps are the issue (brightness low) which would make the issue here worse from a colour point of view.
3)
some issue with the colour drivers to the display.
Never seen that before but who knows???
Again dismantling the front screen will be the way to know.
Hopefully people more familiar with the issue will chime in.
Cheers.
« Last Edit: April 09, 2024, 11:04:52 pm by richnormand »
Repair, Renew, Reuse, Recycle, Rebuild, Reduce, Recover, Repurpose, Restore, Refurbish, Recondition, Renovate
Online coromonadalix
« Reply #2 on: April 09, 2024, 11:13:28 pm »
Dont double post or triple post
« Last Edit: April 09, 2024, 11:16:01 pm by coromonadalix »
  • Country: br
« Reply #3 on: April 10, 2024, 01:03:13 am »
I thought it might be the EFI glass.
Offline gnif
  • Views and opinions are my own
    • AMD
« Reply #4 on: April 10, 2024, 02:43:39 am »
Posting the same thing to multiple sections of this or any other forum is very poor form. Please refrain from doing this again in the future.
SMTS Software Development Engineer @ AMD
