Nice LA, congratz I see it's chassis similar to TDS7xxx/CSA7xxx scope.
Radisys i810 NLX motherboard for x86?
The motherboard is an 'Intel SU810', which I have yet to search for data on. Very likely custom. Haven't even taken it out of the carrier frame it's in yet. But will be. For one thing it looks like the board has a dual USB stacked connector, while the TLA614 case only has an opening for one of the USB connectors. Fingers crossed both USB ports are actually there.
I can imagine in 2000 someone at Tek saying "USB? Newfangled rubbish, will never catch on, why would anyone need more than one port? We don't want to confuse people, so just blank over the 2nd port."
Be sure to store NVRAM and c:/vxBoot (hidden folder with powerpc boot image and settings), or your LA will be dead when NVRAM battery loose it's charge
Now this is why I love eevblog!
I'd noticed there is an NVRAM (one of those Dallas 'battery and RAM in a block' things), and guessed I probably have to back it up. I have a TopMax device programmer so can easily do that, except the thing is soldered into the main data capture PCB, and I'm highly unenthusiastic about taking a soldering iron to that board. Can do it, but fear accidents. Both of the data loss and lifted pads kind.
Thanks for mentioning the hidden folder. The hard disk is annoyingly a 2.5" with the mini-IDE + power connector, so I now have to find where I put my IDE to mini-IDE adapter before I can mount the drive on a PC or USB external dock.
Will probably use partition magic to make an exact image, and also ZtreeWin to do an all-files copy. That does copy hidden folders.
I'm dreading finding whatever Tek may have have done to lock their software to this machine in it's exact present form, and whether that will make upgrading it (eg bigger HD) either impossible or a pain in the butt.
Btw, i personally run TLA714 remotely, just have PCMCIA Intel 100 adapter connected to my main workstation PC (Win2008), where i run TLA App 5.8 (I tried all versions on my Win2000 in TLA, and so far 5.8 was latest to work).
GUI is much faster remotely on powerful PC, then locally running on LA with slow PC. Also TLA screams with bigger screen to fit all those waveform signals
Good idea. I'd noticed it runs like a dog compared to newer PCs, but didn't make any judgment yet whether part of that is maybe 'grandfather Windows' effect (bloated registry and other junk) or just really old, slow hardware.
I mentioned WinXP because I have a stripped-down version, with CPU-cycle wasting stupidities like WFP removed, and it runs very nicely. Also I'm used to it. Really hoping I can transfer to that. But of course, on a new hard disk, keeping the original as fallback.
The screen in the TLA614 is 800x600 I noticed. Not too bad. So far I didn't find any way to adjust the brightness; maybe it's just fixed at 'bright as can be'.
Do you know if there's any kind of service manual available for these? I kind of doubt it, but might as well ask.
Also are there any good Tek LA user group forums for this gear? For instance where did you get the various versions of the TLA App? That's something else I need to do.
