Author Topic: New Uni-T UT61 series (UT61e+)  (Read 57175 times)
Offline joeqsmith
Re: New Uni-T UT61 series (UT61e+)
« Reply #125 on: October 30, 2021, 10:34:51 pm »
Nice fuses and larger PTCs.  Looking at the ad previously posted, I see no mention of the frequency counter.   That's a shame as the UT61E+ is advertised to read up to 200MHz.  Maybe they learned a lesson?
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #126 on: October 30, 2021, 11:07:34 pm »
Maybe they couldn't stretch their BS that far with a cert agency breathing in their necks... :-DD
Offline Saskia
« Reply #127 on: October 31, 2021, 02:44:39 am »
I can check the feature list. It did come with test leads, a USB adapter and a component test adapter. I did not see a temp probe, though. Did not check official pricing. Found this one on the returns shelf of a distributor in a torn box which lead to a below 50€ price. Is it worth it ? I don't know. It will not be able to compete with my Fluke 179 or my MetraHit. But those are in different price ranges.
Offline Trader
« Reply #128 on: October 31, 2021, 04:09:07 am »
Please, could you check the burden voltage (A, mA, uA)? Thanks.
Offline Trader
« Reply #129 on: October 31, 2021, 04:14:19 am »
Compare a conventional UNI-T UT61E+ DMM and the UT161E version for Europe
« Last Edit: October 31, 2021, 04:19:07 am by Trader »
Offline Saskia
« Reply #130 on: October 31, 2021, 07:12:34 am »
Currently I have no opportunity to measure anything, I am moving and need to pack all my stuff. Sorry.
Offline AndrewBCN
« Reply #131 on: October 31, 2021, 09:40:04 am »
The burden voltage on the current ranges is exactly the same as that for the UT61E+.
The UT161 is the same as the UT61E+ except for the improved input protection and having undergone a certification process. The plastics are the same, the main IC is the same, the features are the same, most of the PCB layout is identical, it probably comes from the same assembly lines, etc. And it's very slightly more expensive (the price difference is under 5€), imo that means it's better value.
@Saskia, thank you for the photos. It looks much more put together than your typical Chinese meter. Obviously that, to be absolutely certain of its robustness, testing would have to be made.
joeqsmith already tested the UT61E+ for "robustness". This is exactly the same meter except for a slightly different input protection.
I did actually open it.
I'll leave it to folks more qualified to judge on the cat-worthiness of the meter.
Thanks for the pics.
Offline Fungus
« Reply #132 on: October 31, 2021, 09:53:39 am »
Still no big surge rated resistor so those PTCs and MOVs are going to take a hammering.
Offline Adrian_Arg.
  • Country: ar
« Reply #133 on: October 31, 2021, 02:29:55 pm »
I'm going to buy one in aliexpres on November 11, since the unit is going to make a good reduction, since I only have the ut61C, you always have to have two or more meters. Maximum voltage with which I work 250V and currents that do not exceed 5 or 7 amperes, to measure more I use a homemade probe that measures the voltage drop through a resistance of 1oHms 50w.
Yo voy a comprar uno en aliexpres el 11 de noviembre, ya que unit va a realizar una buena rebaja, ya que me quede solo con el ut61C, siempre hay que tener dos o mas medidores. Maximo voltaje con el que trabajo 250V y corrientes que no superan los 5 o 7 amper, para medir mas uso una sonda casera que mido la caida de tension a traves de una resistencia de 1oHms 50w.
Offline AlexTee
« Reply #134 on: November 07, 2021, 06:53:10 pm »
Obtained UT161D (the certified version of UT61D+). What I noticed immediately after initial testing is how badly it behaves in continuity test mode. Yes, it latches fast enough but then it interrupts beeping momentary if you go on keeping the probes shorted. This is not the case with the more expensive UT61E+, but the D(+) version is probably quite slow at measuring resistance, which causes beep interruption until reading drops below 50 Om to engage it back, indicating a shorted circuit.
This is quite annoying as it stops someone from reliably judging about the circuit condition.
Uploaded short video to visualize the issue:
https://youtu.be/0HC-WeQ5inA
« Last Edit: November 07, 2021, 08:54:52 pm by AlexTee »
Offline Gyro
« Reply #135 on: November 07, 2021, 07:08:11 pm »
The UT61D isn't the certified version of the UT61E+. It has a 6000 count display rather than 22000 counts and uses a different chip.
Best Regards, Chris
Offline AlexTee
« Reply #136 on: November 07, 2021, 07:50:55 pm »
It is 161D, not 61D.
161D is cerified independently by Intertek, it is clone of 61D+, with modified input (better protection, high energy Bussmann fuse etc.)
Nevertheless, the question was related to continuity test.
« Last Edit: November 07, 2021, 07:53:28 pm by AlexTee »
Offline Gyro
« Reply #137 on: November 07, 2021, 07:55:20 pm »
Ah, sorry, missed the '1'.
Nonetheless, it still uses different silicon for the different display count, apparently with different continuity response time (as was the case with the 61D and 61E).
« Last Edit: November 07, 2021, 08:01:08 pm by Gyro »
Best Regards, Chris
Offline AlexTee
« Reply #138 on: November 07, 2021, 08:06:39 pm »
I am aware of that. The question is would you keep such meter or is it just me who gets pissed off by such a crappy continuity test mode implementation?
P.S. corrected typo in my first post, should have been 61D+, not 61E+, obviously.
« Last Edit: November 07, 2021, 08:09:20 pm by AlexTee »
The following users thanked this post: Gyro
Offline Gyro
« Reply #139 on: November 07, 2021, 08:14:36 pm »
No it's not just you, fast and reliable continuity indication is an essential.
Best Regards, Chris
Offline AlexTee
« Reply #140 on: November 07, 2021, 08:51:42 pm »
It is fast, indeed, but not reliable enough. Being a minor issue, it still bothers me every single time I conduct continuity testing. Maybe I'll get used to it with time...
Offline AlexTee
« Reply #141 on: November 07, 2021, 08:57:51 pm »
I suggest you look for 161E version. Surprisingly, it is sold cheaper at official store and at another store in AliExpress, while being absolutely same meter, but with a better input protection and independent certification, unlike the 61e+.
The following users thanked this post: Adrian_Arg., Trader, hmscott
Offline AlexTee
« Reply #142 on: November 11, 2021, 01:01:00 pm »
JFYI, the UT161E (certified version) is on sale today at AliExpress for 58.60 USD when shipped to USA and PayPal selected as payment method.
The shipping is free, btw.
https://www.aliexpress.com/item/1005003223302877.html?spm=a2g0o.placeorder.0.0.811c321e5QM90U&mp=1
« Last Edit: November 11, 2021, 02:12:12 pm by AlexTee »
The following users thanked this post: rsjsouza, Trader, hmscott, AndrewBCN
Offline Caliaxy
« Reply #143 on: November 12, 2021, 10:23:13 pm »
FWIW, Newark has a small stock left of Tenma 72-10415 on sale for $55.44 (plus taxes and shipping). That's a rebadged version of UT61E with better protection. The innards look very similar to the ones of UT61E reportedly sold on the EU market (German GS, as shown here: https://www.eevblog.com/forum/testgear/uni-t-ut61e-multimeter-teardown-photos/msg581051/#msg581051).
Unlike UT61E, it comes with both RS232 and USB computer interface cables (and a CD with software).
https://www.newark.com/tenma/72-10415/dmm-hh-10a-1kv-22000count/dp/94AC6580
« Last Edit: November 12, 2021, 10:36:46 pm by Caliaxy »
Offline AlexTee
« Reply #144 on: November 13, 2021, 04:00:16 am »
161E is the better version of the newest 61E+,  not the old 61E.
Offline Caliaxy
« Reply #145 on: November 13, 2021, 06:26:32 pm »
I know. The old UT61E was infamous for inconsistent input protection. Most versions sold on Aliexpress, Amazon and eBay had only partially populated boards (missing some components), smaller fuses and false CAT ratings. Other than that, they were fine meters - people liked them. Some complained that the IR/USB cable was optional (an IR/RS232 cable was included by default). Reputable dealers such as Newark sold better versions, with proper input protection, fuses and true CAT ratings. Unfortunately, you'd have to pay almost 3x the Aliexpress/Amazon price for that, which was hardly worth it for an UT61E.
With UT61E being phased out, Newark is selling their remaining stock at almost 1/3 of the price. As one of the ways the new UT161E is better than its predecessor is, allegedly, better input protection I thought some people might be also interested in a properly equipped UT61E with an IR/USB cable for a fair price (I was).
« Last Edit: November 13, 2021, 06:28:14 pm by Caliaxy »
The following users thanked this post: AndrewBCN
Offline Lado
  • Country: hr
« Reply #146 on: March 24, 2022, 10:13:15 pm »
Today my 61E+ came and I'm bummed.
I did research before buying it since I wanted a good multimeter for a while. I finally decided to bite the bullet and I bought it on sale.
Now I see not only is the 161E better, but also cheaper  :palm:
Can someone explain me the difference since I don't understand the Russian video?
Are the fuses the only difference or is there more?
Should I sell the 61E+ since it's unused and get the 161E?
Offline AlexTee
« Reply #147 on: March 24, 2022, 10:26:16 pm »
The fuses, Intertek certification and the box content; the 161E comes with bag and a smd/thermocouple adapter. No huge difference, but yeah, they do sell them cheaper, I bought mine for just $55 last year from AliExpress. One thing to note is that 61E+ PCB has been updated with new revisions unlike 161E, which probably won't see any updates since it is a certified device, meaning Uni-t should pay for inspecting every new revision, which probably won't happen. If you ask me, sell it and get a Brymen, period.
« Last Edit: March 24, 2022, 10:41:15 pm by AlexTee »
The following users thanked this post: llg, Lado
Offline Lado
  • Country: hr
« Reply #148 on: March 27, 2022, 06:36:30 pm »
Mine came with probes ofc, transistor tester adapter, smaller bag which is more convenient for transport and a UNI-T voltage detector. Not terrible but I wish I went for the 161. Keep in mind that I'm from Europe so the price automatically includes 25% VAT in top.
My local electronics store has those exact fuses. Are they worth upgrading?
Also, I get a dead battery notification although I've inserted new, freshly charged NiMH batteries. 950 mAh or so. Don't tell me it doesn't work on rechargables  :D
Doesn't the 61D come with the thermocouple adapter?
Offline AlexTee
« Reply #149 on: March 27, 2022, 07:10:25 pm »
I beg your pardon. Both 61E+ and 161E come with transistor testing adapter, not thermocouple adapter, obviously. It is the 161D, that comes with smd/thermocouple adapter, but the 61D+ comes without, you just plug the thermocouple directly into jacks.
You can't directly replace the fuses of 61E+ with ones that come with 161E, they are of different sizes. You'll need to first replace the fuse holders. Not worth it if ask me.
I never tried the nimh batteries, can't comment.
The following users thanked this post: Lado
