Author Topic: New Uni-T UT61 series (UT61e+)  (Read 57195 times)
Offline Messtechniker
Re: New Uni-T UT61 series (UT61e+)
« Reply #25 on: November 02, 2020, 10:23:04 pm »
1) Is that a camera mount on the back?
    Looks like the thread size of a tripod for cameras.
Nope. Its an optical input and output to which an USB adapter can be connected. Well known from the tried and tested UT71D, for example.
Agilent 34465A, Siglent SDG 2042X, Hameg HMO1022, R&S HMC 8043, Peaktech 2025A, Voltcraft VC 940, M-Audio Audiophile 192, R&S Psophometer UPGR, 3 Transistor Testers, DL4JAL Transistor Curve Tracer, UT622E LCR meter, UT216C AC/DC Clamp Meter
Offline Fungus
« Reply #26 on: November 03, 2020, 02:46:18 am »
Yet the BD-99 is about 40-50% more expensive  :-// . Maybe the specsheet is omiting something...
The 870 doesn't have dual display, that's a brand new model that Aneng doesn't have yet.    :-DMM
(nb. Aneng isn't always the first to get these meters, they often appear under other brands first)
Edit: you can get them for about the same price as the 870:
https://www.aliexpress.com/item/1005001626549650.html
« Last Edit: November 03, 2020, 02:54:33 am by Fungus »
Offline sot010174Topic starter
  • Country: br
« Reply #27 on: November 03, 2020, 03:57:44 am »
Aneng (Richmeters, ZOYI, etc) meters are made by ZOTEK. But this BD-99 does not appear on their product page. I wonder if they forked one of the schematics...
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #28 on: November 03, 2020, 11:02:32 am »
As I mentioned in the Aneng thread, this meter is physically identical to the terrible Surpeer AV4 - an unfinished product that should have not reached the shelves.
If this is a meter with a revamped firmware that fixes some of the issues, then it should be a start. Otherwise, it could be simply offloading of the same old crap in a different dressing.
The following users thanked this post: Trader
Offline Fungus
« Reply #29 on: November 03, 2020, 01:43:51 pm »
https://www.eevblog.com/forum/testgear/surpeer-av4-true-rms-4-5-digit-multimeter/
  • Country: br
« Reply #30 on: November 03, 2020, 02:46:55 pm »
http://lygte-info.dk/review/DMMZeast282%20UK.html
Display updates around 3 times/sec
Bargraph works at same speed as the numeric readings.  :=\
Offline rsjsouza
  • Eternally curious
« Reply #31 on: November 03, 2020, 04:47:09 pm »
I just tried to find some references about this "Borbede" and I found this meter is older than I expected: I found an attempt of a review from Youtube dated from Jan 2020. One can't see much of the meter, as the guy did not have a 9V battery to turn it on.
At any rate, given the date I suspect it is the same turd dressed differently.
It is worse than that. If I recall correctly, the bargraph has only 5 subdivisions.
  • Country: br
« Reply #32 on: November 03, 2020, 05:01:04 pm »
It's really a shame. If the Zotek ZT219 (Aneng 870) had a good bargraph I would order a couple on a heartbeat. I'm still tempted to buy one though (MAS-19) to replace one of my 8009s.
The following users thanked this post: rsjsouza
Offline Fungus
« Reply #33 on: November 03, 2020, 06:05:58 pm »
Does it change by individual segments?
That should be a standard multimeter test these days - connect up a potentiometer and check out the bar graph segemnts.  ;)
Offline Trader
« Reply #34 on: November 03, 2020, 11:00:57 pm »
All the same:
  • HY-19E
  • Zeast 282
  • Surpeer AV4
  • Borbede BD-99
  • Winhy 28 II
  • Kaisi K-9033
https://lygte-info.dk/review/DMMHY-19E%20UK.html
https://lygte-info.dk/review/DMMZeast282%20UK.html
Offline xavier60
« Reply #35 on: November 05, 2020, 09:07:09 am »
I need to know if it beeps in a useful way on Diode test range.
From the UT161 Series user manual,
https://www.uni-trend.com/uploadfile/2020/1101/20201101050905917.pdf
"Open circuit voltage: About 3V
For normal diodes, the buzzer will beep once.
For short circuit, the buzzer will beep for a long time."
Hopefully, it will test white LEDs.
HP 54645A dso, Fluke 87V dmm,  Agilent U8002A psu,  FY6600 function gen,  Brymen BM857S, HAKKO FM-204, New! HAKKO FX-971.
Offline xavier60
« Reply #36 on: November 05, 2020, 10:27:28 am »
Going from the UT161D to the UT161E, the type K thermocouple range is replaced by a less useful hFE range.
I will not be giving these meters any more thought.
Offline Wytnucls
« Reply #37 on: November 05, 2020, 10:59:23 am »
Light goes green for voltage drop between [0.12V;2V]
Light goes red for short circuit <0.12V
Light off for voltage drop above 2V
Offline Stinger
« Reply #39 on: November 13, 2020, 08:24:30 pm »
Good news from UNIT who offer backlight and bigger digit size for UT61E. :-+
Offline Trader
« Reply #40 on: November 15, 2020, 06:17:57 am »
Offline CDN_Torsten
  • Professional electron whisperer
« Reply #41 on: November 15, 2020, 11:41:45 am »
This video shows responsiveness:
https://www.bilibili.com/video/BV1h54y1r7d3
...and here is a tear-down:
https://www.bilibili.com/video/BV1AV411a7ew
...now where did I put my Babel fish?  :)
Offline CDN_Torsten
« Reply #42 on: November 15, 2020, 11:53:27 am »
Offline xavier60
« Reply #43 on: November 15, 2020, 12:07:00 pm »
Replacing the  K Temperature range on the UT61e+ with a useless hFE range is so dumb and a deal killer for me.
It annoys me even more, now seeing how well the meter generally performs.
They need to correct this very poor decision.
Offline xavier60
« Reply #44 on: November 15, 2020, 12:45:20 pm »
 To use the hFE function, the adapter first needs to be inserted into the input terminals.
This exercise will soon become tedious.
Offline Fungus
« Reply #45 on: November 15, 2020, 03:05:02 pm »
a) Insides look MUCH better than the old one
b) Damn, that's a big meter!
Does anybody even measure hFE these days? It seems like a 1970s measurement to me.  :scared:
The following users thanked this post: CDN_Torsten
Offline Trader
« Reply #46 on: November 15, 2020, 03:15:50 pm »
Teardown
The following users thanked this post: coromonadalix, CDN_Torsten
Offline Trader
« Reply #47 on: November 15, 2020, 03:16:53 pm »
Teardown
Offline Trader
« Reply #48 on: November 15, 2020, 03:22:41 pm »
Cyrustek ES232 2013-GD2X - 30,000 counts
http://www.cyrustek.com.tw/spec/ES232.pdf
Offline Fungus
« Reply #49 on: November 15, 2020, 03:24:10 pm »
Ew! That flux/soldering is NOT good for long term reliability.
