No, that is not what I am saying. "aliasing" isn't the issue here, I agree with you... I put it in " " because it's what it was being referred to in this thread. I believe it is a color grading/pallet inversion choice they have made, that would be solved IF they did a complete inversion, and were not trying to keep the trace color BLUE in both Normal and Inverted modes. (The "Noise" is still drawn in white, and shouldn't be). I don't believe what we are seeing has anything to do with the bit depth of the scope or anything other than a color pallet inversion choice, made in the firmware, that they have not got working well so far.
If the "noise" (white-ish color areas surrounding the blue trace) you refereed to were also inverted, it would look more like my manually edited image (attached), and it would look like my other 8bit scopes that look fine in dark theme or inverted modes. I am happy to see the noise - but I want it to be drawn in an appropriate color (white is not good on a black background!). Maybe they simply missed this?
I don't want to run the averaging modes in my use case (audio and RF analysis), so if they do add your suggestion (which would be good regardless), I still think the original issue can solved by working on the inversion method. Or, even adding it as a 3rd option. Normal / Invert 1 (blue trace) / Invert 2 (true invert with yellow trace as per my image attached - this still includes all the noise but looks much better).
Cheers
