Is there any way to fix the nasty red colors after voltages above 220 volts?
+ I'd like to remove the constant red background on up.
I don't understand why they did this? Is the device for children?
Or for people with very low intelligence?
This has significantly reduced the quality of the device, which is already far from perfect without this cheap Chinese fetish.
I didn't order background and font coloring!!!
I often work with high voltage. Do I have to constantly see this horror?
I used the search function on the topic, but I'm tired of reading... Sorry.
Suggestions...
I'd like to see an oscilloscope option switch to the voltmeter probes in the new versions.
It looks really strange to have separate inputs and not be able to see both at the same time.
