I've just tested firmware ZOYI-703S-FW-V164 ( from http://www.szzotek.com/h-col-159.html ).
And still no luck: wobbly waveform above few MHz.
For me some things improved compared to V1.57 like for instance better waveform display at higher frequencies and improved triggering on single events. But the triggering is still far from perfect depending on horizontal timebase, mainly in the ns range.
Also weird to me is that in the High Speed Run mode the frequencies above 20Mhz or so look worse compared to the Normal Run mode....
Somehow, in High Speed Runmode, at the higher frequencies, there seems to be noise on top of the waveform. Interestingly the waveform on channel 1 seems to improve if you also enable Channel 2, even when not using it???
For now I only use it in the Normal Run mode and have no big issues till frequencies around 30Mhz or so.
Hopefully the next firmware which will fix all issues without introducing new ones
But still love this meter for the simple scope functions and it's accurate multimeter functionality.
