Author Topic: New Zoyi multimeter+oscilloscopes - ZT-70xS, up to 50MHz/250MSps (nov 2022)  (Read 602616 times)
dn1983 and 23 Guests are viewing this topic.
Offline SlCKB0Y
Received the ZT-703S+ today, seems like there is not much changed internally between these models. My original ZT-703S has PCB revision 2.2 and this one has 2.5. Can't seem to find any major component differences. Seems like the difference is mostly in software and the color of the housing.
The flagship features of the ZT-703S+ appear to be a far more capable signal generator. It’s now a user selectable amplitude (0.5v - 5v) with a frequency up to 10Mhz! (Up from a 500Khz fixed at 2.5v).
Isn’t this like 20x the frequency range of the ZT-703S? You are thinking this is just being done in software?
Offline Faeren
So the 706S is available here (https://www.aliexpress.com/item/1005012105196323.html), and the 703S+ available here (https://www.aliexpress.com/item/1005011775300304.html).
And to get this straight, the 703S+ is a 703S with an improved signal generator, and the 706S has the improved DMM, but the two are mutually exclusive?
Lol
Offline Skander
Lol
The 706 carries the improved signal gen from the 703S+ according to specs.
So we have 703S (25K DMM - toy sig gen) / 703S+ (25K DMM - capable sig gen) / 706S (66K DMM, capable sig gen).
Identical oscilloscope hardware on all three it seems.
Weird lineup.
Offline Faeren
At the rate these are being iterated on I'd hold out for the 707S with a 80MHz scope ;D, 706S is quite tempting though, is there any info as to how many bits the siggen DAC is? I'd be assuming 8, could save me buying a dedicated siggen if it's 12 though.
Offline Masterm
  • Country: ru
Hello! Please help me with a problem with my zt-703s device. It worked fine, I used it to measure 2032 batteries, and the firmware was updated. One day, I turned it on and it started up as usual, using the last mode I used, which was the constant power mode. Now, it beeps once a second and doesn't respond to buttons (only in F1+PWR mode do the buttons work), but it's still possible to take measurements in this mode. I tried formatting the flash drive and updating the firmware, but that didn't help. What should I do?
Online tunkTopic starter
  • Country: no
Probably won't work, take out the battery for maybe 5-10 minutes.
Offline FixyMixy
I've bought my 703S for 46$, but 706s is 105$ at start !! WHY !!??  :-//
2800149-0
2800153-1
« Last Edit: April 22, 2026, 07:20:05 am by FixyMixy »
Offline Skander
(Attachment Link)
(Attachment Link)
They raised all prices significantly since last year (or even early this year).
Offline GnatGoSplat
(Attachment Link)
(Attachment Link)
Could be worse.
2800295-0
Shawn
Offline slavoy
So it seems that Zoyi is starting to follow in FNIRSI’s footsteps and instead of improving their previous device, they are releasing another one? Their multimeters turn out great, but they seem to have trouble making a good oscilloscope. I guess they are cutting costs too much and not using an FPGA, which is why there are issues like slow performance and artifacts/triggering problems.
And looks like it's not so cheap anymore.
« Last Edit: April 22, 2026, 06:02:01 pm by slavoy »
The following users thanked this post: liutas
Offline Carbedd
At this point we wait for someone to do a teardown of the new ZT706s to understand what direction the company has taken |O
Offline phazei
Offline Emo
Inside this packet is the already known ZOYI-703S-FW-V1612.ZTK version
Offline TheDefpom
  • YouTuber Nerd - I Fix Stuff
    • The Defpom's Channel
Zoyi sent me the ZT-706S to review, video will be published on Tuesday/Wednesday this week.
Cheers Scott
The following users thanked this post: mebel, 4lfre1re, FixyMixy, liutas
Offline Skander
Seems there's a new v1.8 firmware?
https://www.dt830.com/forum.php?mod=viewthread&tid=8468&highlight=
No, that's the date, the 8th of January.
There is no new firmware release.
Offline FixyMixy
It's ready... I guess.
Offline mkononets
44:24 into the 706S review, the same charger IC model 4086B
Offline liutas
  • Country: lt
My Zoyi 703+ motheboard V2.5   this Zoyi 706s motheboard V2.7, 42:17 into the 706S review,
« Last Edit: May 13, 2026, 04:19:10 pm by liutas »
